Old 11-14-2012, 10:07 PM   #29
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Great mod and glad it's being offered.
I loved when I swapped from 3.42s to 4.10s in my Corvette, gearing can REALLY wake a car up
seven is offline   Reply With Quote
Old 11-14-2012, 11:01 PM   #30
s2kdrew
Drives: 2013 hot lava FRS
I swap from 4.1 to 4.78 for my S2000. Huge different in accerleration, only around 10% different of MPG. This is what I want to do to my FRS in the future.
Our car is not that big of HP and TQ. I don't think without any special treatment the final will blow up on us. But I am worry about the gear would be too short. AP1 S2000 3rd gear stock can hit 148-150km/h. After I did 4.7 drop to around 125. And speedo is another issue, for S2000 we could order yellow box to adjust the speedo, nothing for this car yet.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 11-14-2012, 11:23 PM   #31
Opposed
Drives: 2013 Asphalt FR-S
Agreed. I had 4.77's on my AP1. It was a nice upgrade, but say good buy to highway comfort for daily driving. My S was around 4k at 60 mph. Top end did suffer quite a bit too. Wasn't much faster than a stock geared s2000 from a 60+ roll. But from a stop it was a pretty big difference.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-14-2012, 11:45 PM   #32
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Might just get those 4.30 toyota one's myself if the price is right, i'll check tomorrow.
The Following User Says Thank You to JoeBoxer For This Useful Post:
RYU (11-15-2012)
Old 11-15-2012, 12:41 AM   #33
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Your call obviously, but that's a small change for dollar spent. Roll the dice again.
4.7 or 5.11 for me if I go this route.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 11-15-2012, 03:09 AM   #34
serialk11r
Drives: '06 AM V8V Coupe
Changing the diff could be thought of as a small change for the dollar spent at any rate since you're not increasing power, and you're not making the gear ratios closer :P The only place where you gain acceleration is 1st gear, outside first gear it's not much improvement overall since you have more power available at some speeds, less at others.
For people wondering about mpg, around town it shouldn't change much if you aim for the same revs and load, on the highway the mpg drop should be about half the gear ratio change. So going down to 3.727 gears is maybe 5% increase in fuel economy, going up to 4.5 is maybe 5% decrease, and this extrapolates pretty well.
Old 11-15-2012, 07:15 AM   #35
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I would personally find bolt on mods that can add about 10-20 lb ft of torque before adding this. I feel the combination will feel significant enough for a daily driver. I rather do this than go F/I and have to worry about the long term effects.
SUB-FT86 is offline   Reply With Quote
Old 11-15-2012, 07:40 AM   #36
Captain Insano
And I'm wondering about this too. Besides the speedo, for the folks with AT thinking of doing this I'm not sure how that would react (good, bad or neutral) with the AT software/ECU settings. Interesting question.
Captain Insano is offline   Reply With Quote
Old 11-15-2012, 08:47 AM   #37
2forme
Who's going to be the first to play with gear ratios in GT5 for comparison :-p
Old 11-15-2012, 09:15 AM   #38
s2kdrew
if pulling from a dead stop I agree the car pull really hard, especially 2nd gear.
me too was revving 4K while doing 60mph with a loud exhaust. Crusining on the was not a fun part for me.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
Old 11-15-2012, 09:21 AM   #39
s2kdrew
AT folks might get a problem, since the TCM will monitor the speed of the vehicle and gives you the proper gear. But with final drive install the gear would be a lot shorter, the TCM might not know how to react due to the value is out of its preset range.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
Old 11-15-2012, 10:33 AM   #40
xwd
There are a number of JDM tuners who have come out with final drives as well.
Old 11-15-2012, 10:40 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by xjohnx View Post
anyone? or is this diy-able?
Definitely DIY-able. It's more involved than many DIYs but it's not that hard.
Install prices, like the other poster mentioned, should be around $300.
An old ITR Expo sponsor sells MFactory so I did get some info from him:
-FDs are forged from SAE8620 steel and should be good for at least 300whp. MSRP $749.95. Ratios 4.5 and 4.7 as already stated.
-Other Ratios are possible, but a close gear set may come first (6MT only)
-Helical LSD is forged from SAE 4320 steel, rated for 1,000whp. MSRP $684.95
-Meta-Plate LSD is also SAE4320, but rated for 500whp. Available in 1.0, 1.0/1.5 and 2.0. Adj for pre-load and lock up. MSRP $899.95.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-15-2012, 10:53 AM   #42
JoeBoxer
JoeBoxer's Avatar
$750 seems really high for a ring and pinion to me compared to other platforms where i've looked at them.
4.5 final drive, 4.7 final drive, final drive, mfactory, ring gear and pinion
Considering going to 3.727 gear/pinion in 6MT HotLavaMann Engine, Exhaust, Transmission 83 01-10-2015 10:34 AM
Final Fantasy jay4prez Off-Topic Lounge [WARNING: NO POLITICS] 66 08-25-2013 10:31 PM
Final 13' BRZ brochure poormans_LFA BRZ First-Gen (2012+) -- General Topics 29 03-31-2012 02:43 AM
Brand new FT-86 video w/ring tone link - Final reveal ezmayo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 12-01-2011 06:40 PM
Possible Final production cuts. Syldrin Scion FR-S / Toyota 86 GT86 General Forum 46 11-23-2011 09:02 PM
