03-29-2023, 06:00 PM | #6847 |
Drives: GR Corolla
Wow. Kudos to you for being able to put up with it.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post: | Spuds (03-29-2023) |
03-29-2023, 06:50 PM | #6848 |
義理チョコ
OMFG
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (03-29-2023) |
03-29-2023, 07:39 PM | #6849 |
The Dictater
Drives: '13 Red Scion FRS
Meh, I just had a good laugh. It's quite comical considering it may or may not be an ironic situation.
I would categorize this person as weird but otherwise very personable. It wasn't like an angry discussion, just "here's some fun things you might not know" that started with pointing out old tobacco barns and how things have changed. Theeennnn sudden turn into fantasyland.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
03-29-2023, 07:52 PM | #6850 | |
Drives: Crapcan
03-30-2023, 04:36 AM | #6851 | |
I've been working on this challenging project for the last month or so.
It's taken me longer than probably would've taken for other members of my team due to learning curve issues and then also in the beginning having issues getting access to software I needed. About two weeks ago, I was pairing on it with the most senior member of my team because she's the one who originally wrote and built this "feature" that I was adding to. At the time, she told me to test it this one way, and that to do what I needed to do, I had to do it a certain way. So I finally got everything working in the past week, tested it using the method she told me to use, wrote test cases based on that, etc. Submitted my stuff for review. She approved it. Today I find out it doesn't work in the real life website. Fortunately customers don't currently use that new thing so it doesn't affect customers, but it looks bad that I pushed it through in a broken state because now I have to continue spending more time on it to fix it. When I brought it up in my team discussion today i mentioned what I think is the problem and that it hadn't been an issue when I tested it, but that it currently isn't working in our pre-production or production systems. So she replied saying "I thought in the change I reviewed that we tested it in pre-production and it worked?" So I described the testing process I used, but didn't mention how she was the one who told me to do it two weeks ago. Then she says in this situation for this kind of change she wouldn't use that testing process. Also she still thinks the way I did it originally should work, based on her knowledge of the system, which is how she explained it to me originally. I try not to put coworkers under the bus but it's kind of ridiculous that now she says _not_ to test it in exactly the way she told me to before. I even have special configuration stuff setup specifically because she told me I needed it for this. And I feel like with all the trouble I've had the past six months ramping up to all this new stuff, this doesn't look good on my part. Fortunately I just had my annual performance review and things are fine on that end; I got the normal default 6 months on the job rating, so at least for now I'm "safe" but it does make me uncomfortable going into this first full year if I keep having fumbles like this.
Instagram: @spike.brz
The Following User Says Thank You to spike021 For This Useful Post: | soundman98 (03-30-2023) |
03-30-2023, 11:17 AM | #6852 |
Drives: Crapcan
It's taken me till now to realize the genius that was Dilbert's Desktop Games. At the time I was just a teenager playing a silly game on my parents first computer.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Dadhawk (03-30-2023), soundman98 (03-30-2023) |
03-30-2023, 11:25 AM | #6853 | |
Drives: Crapcan
I prefer to bring things up privately first, cause in the end you want to have some kind of working relationship with a coworker, but if they can't learn and it makes you look bad then they are free game. I also like to outline things in email and send it out to others if I am working on a project. That way there is no " I don't remember that" or questions about procedure or responsibility.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
03-30-2023, 11:30 AM | #6854 | |
Drives: 2018 Subaru BRZ
One thing I've learned over the time in my job is to always, always receive action items via some sort of correspondence (email). Save it as PDF, and Forward whenever someone appears to suffer from long term or short term memory loss. It also ensures proper QA in the long run, and covers your behind in case you get blamed of something.
The Following 4 Users Say Thank You to spcmafia For This Useful Post: |
03-30-2023, 12:17 PM | #6855 | |||
03-30-2023, 12:19 PM | #6856 | |
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post: | Clipdat (03-30-2023) |
03-30-2023, 12:33 PM | #6857 | |
The answer to conversations on the phone or xoom is to create a "Meeting Minutes" email. May seem like overkill, but serves that QA process.
03-30-2023, 12:49 PM | #6858 | |
Proud of BOXER
Drives: Subaru Boxer
Laughed loudly at this cuz most of the time it's true.
03-30-2023, 12:54 PM | #6859 | |
Hate to break it to you but the fact she's female doesn't really change things. In my experience when working with men and having similar communication problems they take it even more passive aggressively.
03-30-2023, 12:56 PM | #6860 | |
Proud of BOXER
Laughed again, cuz also true! In general men are horrible at communicating.
The Following User Says Thank You to Clipdat For This Useful Post: | NoHaveMSG (03-30-2023) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
