Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) -- General Topics
BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ
Old 01-20-2022, 01:23 PM   #71
DarkSunrise
DarkSunrise's Avatar
Originally Posted by ZDan View Post
IMO this makes it even more annoying. The car gained ~40 lb. while removing the spare, so it's more like +65 lb. with vs. with or without vs. without. Adding weight to the rear of the car will hurt rather than help performance while barely "improving" F/R distribution.
FWIW I run to a minimum weight for my class, so I run with all the trunk junk, sub-5 lb. battery, 2-piece front rotors, catless header, empty washer reservoir, around 55 lb. off the nose of the car, still ~53.5F/46.5R.
Just wish they'd make a shorter-wheelbase version with rear wheels moved forward ~10". Or same wheelbase with both fronts and rears moved ~4" forward. That would give it a decent 50/50 - 52/48 F/R weight distribution for an FR car. Also, it looks frankly ridiculous having the rear wheels shoved way far aft, as if that's what people who miss the Scion tC might want!
For NASA TT, I remember some guys needed to ballast to meet weight. Apparently weight lifting plates fit well into the spare well and could be secured down pretty easily. Sucks to have to add weight but at least there’s an ideal place to mount it!
Agree it’s not worth adding weight to try to improve the weight balance. It was more of if the change from the 1st gen bothers you, there are useful ways to bring it back inline with the 1st gen (especially if you value having a spare). For me my BBK prevents me from using the spare anyway so I deleted my spare.
Agree it’d be great if they offered a 2 seat SWB version of the car.
2022 BRZ Build
2013 FR-S Build
The Following 3 Users Say Thank You to DarkSunrise For This Useful Post:
OkieSnuffBox (01-20-2022), PBR (01-20-2022), ZDan (01-20-2022)
Old 01-20-2022, 01:25 PM   #72
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Engine feel Gen1 vs Gen2 comparison
Yea not when you compare MT to MT for the same trim:
EDIT YEP I WAS WRONG. Looks like I’ve had the 2815 lbs stick in my head for a long time and I misread the chart I linked
Fixed:
2020 limited MT: 2798 lbs
2022 limited MT: 2835 lbs
37 lbs.
https://static.fzinternal.com/pdf/br...subaru/brz.pdf
https://www.subaru.com/vehicles/brz/models.html
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
ZDan (01-20-2022)
Old 01-20-2022, 01:45 PM   #73
PBR
PBR's Avatar
Drives: 2022 BRZ Limited 6 speed manual
Originally Posted by OkieSnuffBox View Post
Adding weight to the rear to change the distribution seems silly. Lightweight battery and AP Sprint brakes alone on the front pulls 40+ lbs out. Lightweigh 17" wheels will pull even more.
Not to mention, on the street or for the average HPDE driver, I seriously doubt you'd even notice the small change in weight distribution by adding the "trunk junk" back.
I've spent a lot of time in shifter karts, placing ballast and changing set ups. I know these minor things may seem ridiculous to many but I don't care. Even just for my piece of mind, mods will be made and so will mistakes.
PBR is offline   Reply With Quote
Old 01-20-2022, 01:56 PM   #74
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
You're looking at 2019 "premium" weight vs. 2022 limited.
From your links to Subaru brochure data:
2019 Limited MT: 2798 lb
2022 Limited MT: 2835 lb
Difference = 37 lb
Closer to +40 lb. heavier than +17 lb.
Car and Driver "as-tested" BRZ Limited weights:
2017: 2777 lb.
2022: 2843 lb.
Difference = a lot more...
It's a heavier car despite the removal of the ~26 lb. spare tire
2022 limited MT: 2815 lbs
17 lbs.
ZDan is online now   Reply With Quote
Old 01-20-2022, 02:04 PM   #75
sds
Drives: '22 BRZ Limited 6MT
sds is offline   Reply With Quote
Old 01-20-2022, 03:04 PM   #76
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Difference = 37 lb
2017: 2777 lb.
2022: 2843 lb.
In addition to that, the weight claims from the manufacturer have never stood up to people placing these things on scales. Below is a good example, with the gen 2 coming in at 2744 with low fuel and empty trunk.
Gen 1's came in at constant low 2700's and high 2600's. Anthony (who gave his BRZ the biggest diet on this forum) is a good example and had his car weigh in at about 2680 prior to any modifications.
Dzmitry is online now   Reply With Quote
Old 01-20-2022, 03:16 PM   #77
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Not a good idea to mix sources... Brochure weights should at least be somewhat consistent in reporting weights at a given fuel level. But I usually just go by Car and Driver as-tested weights to be sure...
That 2744 weight at 1/4-tank and with "trunk junk" removed is consistent with the brochure weight of 2815 lb. for the Premium model, minus 60 lb. of fuel and 11 lb. of trunk junk. But *damn* at that weight distribution, 56.3% front... We are verging on pickup truck territory here, way worse than modern nose-heavy V8 musclecars...
Again you have to be consistent with fuel level. My '17 PP, totally stock with full fuel was 2820 lb. My minimum competition weight over the years was ~2665 lb...
Dzmitry (01-21-2022)
Old 01-20-2022, 03:25 PM   #78
Yoshoobaroo
TRACKBREAD
Difference = 37 lb
2017: 2777 lb.
2022: 2843 lb.
Wow I’ve had that 2815 number wrong for a long time then.
Old 01-20-2022, 03:33 PM   #79
sds
You're really stretching here. The Gen 1 and Gen 2 have effectively the same weight distribution.
Here's a 2013 (I think Limited?) model in comparison from Vorshlag. 3/4 tank of gas and includes a spare
55.9/44.1 F/R distribution. Drop the spare and remove some gas and you'll get to the same distribution as a Gen 2. I'm really not sure how it's any worse than Gen 1.
Old 01-20-2022, 03:46 PM   #80
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
It's close but from what I've seen, the new car is about 0.5% worse. Which wouldn't be a big deal except that it was already so bad at ~55/45... Basically the new car added ~65 lb. of weight and then tossed the spare to keep overall weight gain ~40 lb., but with *slightly* "worse" weight distribution.
Again, not a huge deal except I would have loved to see it move in the other direction...
Still number 1 car on my list of new cars I would buy.
Old 01-20-2022, 05:33 PM   #81
OkieSnuffBox
Drives: '23 BRZ Limited
Comparing a pure race machine with a wheelbase shorter than most people are tall isn't really a good comparison to a street car.
I bet if you did a blind test with the car with and without the trunk junk, you'd never know.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
PBR (01-20-2022)
Old 01-20-2022, 05:39 PM   #82
PBR
PBR's Avatar
I bet if you did a blind test with the car with and without the trunk junk, you'd never know.[/QUOTE]
Probably but I intend to find out. Can I just do that, please? I'll follow the 86 platform experts around here but I'm also going to do my own thing. Stupid or not because it makes me happy lol.
The Following User Says Thank You to PBR For This Useful Post:
racingfool (01-20-2022)
Old 01-20-2022, 05:47 PM   #83
OkieSnuffBox
No one is stopping you. I'm sure no one cares if you want to waste your time.
PBR (01-20-2022)
Old 01-20-2022, 05:53 PM   #84
ThomasJ51600
Drives: GMC Yukon XL -tow rig
It makes complete since to try stuff out on your own. That way you know if it works/makes a difference or not.
ThomasJ51600 is offline   Reply With Quote
The Following User Says Thank You to ThomasJ51600 For This Useful Post:
PBR (01-20-2022)
Search this Thread:
Advanced Search
Gen2 Transmission swap? OtherDude Engine, Exhaust, Transmission 29 03-30-2022 09:24 PM
WTB: STi (Real or Not) front Lip for Gen1 BRZ Just Drive Canada Classifieds 0 02-05-2018 11:43 AM
New hybrid drivetrain for Gen2 86? Mim Scion FR-S / Toyota 86 GT86 General Forum 28 09-17-2013 09:59 AM
Comparison to the MX-5 Engine Chemist Engine, Exhaust, Transmission 10 07-29-2010 11:52 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2023 DragonByte Technologies Ltd.
