04-06-2020, 12:24 AM | #183 | |
Drives: LS Swapped Scion FRS = 440HP
I am not running converters and my engine is far from stock so it will sound quite different, but it is slightly louder than a SS Camaro when driving casually. Running converters on it will help significantly.
The Following User Says Thank You to spitsnaugle For This Useful Post: | TRS (04-08-2020) |
04-08-2020, 04:06 PM | #184 |
Drives: 2013 FR-S Ultramarine
04-09-2020, 01:34 PM | #185 | |
Though for the week its running without the MAF connected, its running MAP only (luckily its tuned for both situations). It is a connector change and changing the order of the pins in the connector. Then a minor voltage change/remap with HPtuners.
04-10-2020, 01:52 PM | #186 |
Whats the reasoning for keeping the MAF around if you can run SD?
04-10-2020, 03:12 PM | #187 |
low speed accuracy and air intake temps.
04-18-2020, 02:24 AM | #188 |
Drives: Whitout FR-S 6MT
04-19-2020, 01:06 PM | #189 | |
They're both my friends but I'm looking to pick up one here in the next couple weeks.
04-21-2020, 01:27 PM | #190 |
An updated engine bay photo with new intake below:
New dyno run put it 453hp @6100rpm 440lb ft torque at 4300rpm. 13HP increase over the previous intake with its relatively long/gentle sweeping 90° right off the throttle body. Intake temps have dropped SIGNIFICANTLY over the filter in the engine bay.
06-18-2020, 02:50 PM | #191 |
Some updates:
The car is in the body shop right now, I had some minor repair work done to fix a dent and replace the bumper middle of last year after some damage from a trailer. Unfortunately the shop didnt do the job up to spec, so its at another shop now getting redone.
06-19-2020, 12:27 PM | #192 |
Drives: Q5 + BRZ + M796
Maybe I missed it. Did you ever determine the cause of the engine failure? Fluke? Oil starvation? Knock event? Bad bearing?
If so, did you do anything new to mitigate it from reoccurring?
06-19-2020, 12:39 PM | #193 | |
High G-force cornering caused oil starvation. Steps to prevent:
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post: | GrabTheWheel (06-20-2020), Irace86.2.0 (06-19-2020) |
06-20-2020, 12:07 PM | #194 |
Drives: 16' BRZ
I hope this is enough for you! I had an almost identical setup minus the accusump. I know some people swear by them.
06-20-2020, 01:09 PM | #195 | |
Road-hole
Drives: 2013 Whiteout FR-S
ummm...
Did you miss the fa20 torque dip or something??? LOL just messing with ya... JAden |
The Following User Says Thank You to Jaden For This Useful Post: | BigTuna (06-22-2020) |
07-10-2020, 05:02 PM | #196 |
Drives: 2013' Toyota 86 (EU spec)
Hi @spitsnaugle, I need your assistance. I'm expiriencing some serious heat issues when driving with AC at high outside temps, especialy when driving slow.
Load of the engine has an effect, but minor compared to switching AC on/off. I know you modified your hood. My issue here is that the mod you did would be massively illegal in Germany. As well it would not suit my design concept for the car. So what are your expiriences with that? Did you try different radiators/fans etc and maybe collected some data? I'm running the skunk2 ultra which is pretty much the biggest rad I could imagine to fit the frs. I know that surface area is much more decisive than size, but I dont see a very big difference betwenn the skunk ultra and EG the Jackson racing. Some thought? BTW, are you running a under flor liner? |
Tags |
cx racing, ls swap, ls2, pure automotive |
Similar Threads | ||||
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP | ILLSMOQ | Engine Swaps | 172 | 11-24-2022 07:01 PM |
LS2 swap by KAB Customs with Pure Automotive Motec | Sportsguy83 | Engine Swaps | 254 | 10-17-2018 12:45 PM |
Pure Automotive's MoTeC Plug and Play V8 Swap Thread | Pure Automotive | Engine Swaps | 51 | 11-25-2017 11:10 AM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Engine, Exhaust, Transmission | 23 | 05-15-2016 04:21 PM |
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive | Pure Automotive | Mid-Atlantic | 9 | 01-31-2013 01:03 AM |
