Old 03-29-2017, 03:29 PM   #1135
CSG Mike
CSG Mike's Avatar
CSG can (and will) provide the studs for the OP upon request with the Ace header at no charge.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
2015firestormFRS (11-10-2017), AceHeader-MT (03-30-2017), brzaapi (03-29-2017), Hicklinc (03-29-2017), johan (03-29-2017), ThatAsianBradah (10-31-2017)
Old 03-29-2017, 03:44 PM   #1136
johan
Drives: '14 981CS, '99 NB1
Yeah if bolts are the concern from ACE, makes sense to me that they just include the studs instead with every header.
johan is offline   Reply With Quote
Old 03-29-2017, 04:50 PM   #1137
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Originally Posted by jmark View Post
Which ACE header did you go with? Thanks.
I went with the Ace/421/350 collector.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 03-30-2017, 01:27 AM   #1138
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
While we look into stud options we've updated our website to show OP to FP hardware is required along with part #
AceHeader-MT is offline   Reply With Quote
The Following 2 Users Say Thank You to AceHeader-MT For This Useful Post:
jasonojordan (03-30-2017), tony-brz (03-30-2017)
Old 04-17-2017, 10:31 AM   #1139
blindfold
Drives: brz
Originally Posted by blindfold View Post
first track day with A-350, it was definitely a pleasant surprise and the header itself is quit nice both performance and quality. However I blew a gasket that seats between the header and the up-pipe, it is a two hole gasket that is made of a metal sandwich with asbestos like materials in the middle. I do not believe it is a common gasket so I am having trouble finding a better quality piece to replace it with. Is there a way to purchase a full metal gasket? I foresee this happening again if the same material gasket is replaced.
For the second time, gasket between the header and the up-pipe broke off, it just seems the gasket itself does not handle heat well as the material between the two metal pieces is actually deteriating due to heat. My car is running hks supercharger kit, happened again on lap three on a 2km track first session, anyone else run into this problem and how was it solved? Thank you
blindfold is offline   Reply With Quote
Old 04-17-2017, 12:13 PM   #1140
Trust86
Drives: 2016 Halo FRS
I have. my gasket didn't break off, just deteriorated on the side that has the one stud the corner. Have a small leak there.
I have a new one, bought from CSG, just can't decide on what I wanna do before I replace it, to re use studs or get bolts.
Trust86 is offline   Reply With Quote
Old 04-25-2017, 07:49 AM   #1141
Bobster
Drives: GT86 GTS
Whats the best intake to go with the ACE CS400, to make max torque
Bobster is offline   Reply With Quote
Old 04-25-2017, 08:15 AM   #1142
Reamer
Drives: 2015 FRS
Stock box with a better air filter and an intake tube from the airbox to the manifold.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
The Following 2 Users Say Thank You to Reamer For This Useful Post:
AceHeader-MT (04-25-2017), MaximeT (04-25-2017)
Old 04-25-2017, 10:05 AM   #1143
AceHeader-MT
Drives: 2012 FR-S
Stock box all plugged up with good panel filter and one of these.
After install you can't see it from behind the bumper
http://aceheader.com/index.php/produ...r-scoop-detail
Reamer (04-25-2017), Ultramaroon (04-25-2017)
Old 04-25-2017, 10:19 AM   #1144
Reamer
Drives: 2015 FRS
The next thing from ACE to take my money.
Old 04-25-2017, 10:23 AM   #1145
jasonojordan
Drives: 2013 satin white brz limited
I'll wait for the testing and proven gains dyno graphs :P
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
rookie (04-25-2017), Teseo (04-25-2017)
Old 04-25-2017, 10:28 AM   #1146
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
^ Want to see dyno as well.
rookie is offline   Reply With Quote
Old 04-25-2017, 10:33 AM   #1147
Reamer
Drives: 2015 FRS
I'd like to see the logs on the effects it has on cooling as well, since the intake portion is kinda secondary to it being a rad duct.
The Following User Says Thank You to Reamer For This Useful Post:
jasonojordan (04-25-2017)
Old 04-25-2017, 11:34 AM   #1148
AceHeader-MT
Drives: 2012 FR-S
Talk to your local tuner and they'll tell you why this is good for everything. If they can't, you need a new tuner
Better yet just contact @DeliciousTuning for their Ace v6.8+ tune and feel for yourself.
Besides the ridiculously cooler intake temps, we no longer need an oil cooler as oil and water doesn't get above 110*C. This is not recommended, but that was a main design requirement.
For a $200 part, we're not going to spend thousands for dyno time.
The Following User Says Thank You to AceHeader-MT For This Useful Post:
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
