Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-26-2014, 12:41 AM | #1 |
OOH KILL EM
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
Front swaybar endlink problem
I was trying to install my coilovers today but I could not remove the bottom bolt to remove the endlink, it feels like it's impossible. How did you guys do it?
I am trying to install stance coilovers but the factory endlinks are too long for it. Any help would be appreciated
Instagram: 8as6
09-26-2014, 01:03 AM | #2 |
Drives: 04 Evo 8 SSL, 13 Brz Limited
You might need to use an allen key
09-26-2014, 08:19 AM | #3 |
Depending on how old your car is, you'll probably have to cut it off. Even with the proper tools, mine wouldn't come off at all, they were rusted solid.
09-28-2014, 12:04 PM | #4 | |
Drives: 2013 DGM BRZ Ltd
use a 17mm open ended wrench and a 6mm allen key to stop it from spinning. my allen stripped out because it was so rusty so i ended up cutting it off with a sawzall |
09-28-2014, 08:24 PM | #5 |
That's EXACTLY what happened with mine.
09-28-2014, 09:15 PM | #6 |
Drives: '13 DGM BRZ Limited
I removed mine using a Milwaukee M12 Fuel cordless impact. If you don't have an impact, you'll have to do as suggested above and go the open wrench (or pass-through socket if you have it) and allen wrench method to keep it from spinning.
Similar Threads | ||||
FS (MI): Front strano swaybar, rear wrx swaybar | Aznsky | Brakes, Suspension, Chassis | 4 | 11-04-2014 02:09 PM |
BC Racing Front Adjustable Sway bar Swaybar End Links - $100 shipped | STS-V | Brakes, Suspension, Chassis | 3 | 08-31-2014 10:01 AM |
Stance USA Front Adjustable Sway bar Swaybar End Links - $100 shipped | STS-V | Brakes, Suspension, Chassis | 3 | 08-31-2014 10:00 AM |
Strano Performance Parts 22mm Tubular front swaybar | Sam Strano | Tracking / Autocross / HPDE / Drifting | 276 | 05-20-2014 02:54 PM |
Knocking after lowering *Solved, swaybar endlink* | atledreier | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 02-25-2014 11:59 AM |
