go_a_way1, MisterSheep
Old 12-13-2020, 05:48 PM   #22695
jflogerzi
jflogerzi's Avatar
Originally Posted by ddevl_86 View Post
Today, I learned the true importance of fastener clips used in the wheel wells...
Saw this monstrosity last night when inspecting the passenger headlight for a ballast/bulb issue on my brand new VLands.
I was fearful if I fucked somethin up with the wiring. I didn't, all is secure thankfully! At the same time, I wondered if something caught fire and I had further troubles coming my way... after messing with the flap, I now understand that the vibrations/wind loosed the bottom clip and made the fender flap hit/rub the tire in some fashion, thereby also removing the bottom portion of the encasement and shredding the wall.
Now I gotta get under there and ziptie some loose wires that I thought were safe from elements, and now are not.
In the case of the passenger headlight not firing properly, they've got a pair of new ballasts and D2H bulbs coming at no cost to me! I cannot recommend Fuji Racing Co. https://fujiracingco.com (from Dallas, TX) enough! John there, has been one of the most sincere and coolest people I've had the pleasure of doing business with, especially when it comes to customer service. He's gone above and beyond any measure of excellence in helping me.
Ill be stopping by Home Depot/Lowes tomorrow to pick up a ton of new clips for the front bumper cover, since I'll need to remove it again anyways to fix the headlights. Gonna go through and replace every last one of those suckers so its done proper and I dont have this problem again. Although Ive already received damage to one side of the wheel well, its better safe than sorry at this point.
Anyone got a link to just the passenger plastic wheel well for cheap? also, thanks for reading this essay hahah
I got mine for 36$ direct from dealer
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
ddevl_86 (12-13-2020), Spankopotomous (12-17-2020)
Old 12-13-2020, 08:30 PM   #22696
Decep
Drives: 2013 FR-S Series 10
Originally Posted by jflogerzi View Post
Installed a Perrin transmission and whiteline bushing... Huge mistake if you daily drive your car... The amount noise, vibration and tone change is bad unless because race car.
the perrin rear mount is nice for daily, basically no change in noise. the whiteline bushing definitely makes your car whiney and sound like a 30 year old truck with a worn out transmission/rear end.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-13-2020, 09:20 PM   #22697
soundman98
ProCrastinationConsultant
soundman98's Avatar
just a note-- those aluminum valve caps can and do seize onto the valve stems.
i had a pair a while back that did that. took me something like 2 hours to grind them off with a dremel.
just beware, the price of admission is quite steep with those..
ddevl_86 (12-14-2020)
Old 12-13-2020, 09:25 PM   #22698
Compelica
Compelica's Avatar
Drives: 86 GT
Pulled out the front bumper today to install a DRL enabler kit (Japanese models do not have DRL as part of regulations, hardware is all there sans wiring). The push pins underneath the bumper were terrible things, especially without a jack. Some just went brittle and snapped right after it was removed, have new ones coming in.
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
Old 12-13-2020, 10:37 PM   #22699
jflogerzi
jflogerzi's Avatar
Are you talking about the rear diff or Trans mount?
Old 12-15-2020, 12:55 PM   #22700
DarkSunrise
DarkSunrise's Avatar
Mounted a new set of tires. These are Federal SS 595 in 235/40/17. The SS apparently stands for Super Steel, but they should be “Super Steal” since these were only $55/tire.
I’m not too concerned about grip since these are just my daily/canyon tire, but road manners are great so far. Not sure why people complain about noise. Probably helps that my track tires are Hankook RS3’s so these are actually slightly quieter in comparison on the highway.
As people have noted, these run a bit wide for their size. I’ll update with some more impressions after taking them to the canyons this weekend. As mentioned I’m not expecting huge levels of grip (actually less grip would be more fun to me), but hoping for good tread life and decent consistency across a wide temperature band.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
MJones_RB (12-15-2020)
Old 12-15-2020, 03:33 PM   #22701
MJones_RB
MJones_RB's Avatar
I was going to get some 595 RS-Rs for my 17x7 Enkeis, only $87.50 each. For the price the reviews are great! Michelins have just become too pricey for a daily driver.
MJones_RB is offline   Reply With Quote
Old 12-15-2020, 04:18 PM   #22702
DarkSideFRS
Drives: 2013 pearl white FR-S
Federals are crap tier 3 tires lol... u'll get annoyed with the road noise in no time at all
DarkSideFRS is offline   Reply With Quote
The Following 3 Users Say Thank You to DarkSideFRS For This Useful Post:
DarkPira7e (12-22-2020), KR-S (12-15-2020), MJones_RB (12-16-2020)
Old 12-15-2020, 06:21 PM   #22703
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
What wheel size you have. I'm running 235/40/17 as well.
Sent from my Pixel 4 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 12-15-2020, 06:28 PM   #22704
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
How exactly is gas mileage since you're using it as a daily? Pretty sure mine tanked when I was running my SS 595s.
If using them for drift tires, then hell yeah they're cheap.
Originally Posted by klearfade View Post
Is that gel in your hair?!
Originally Posted by HueyLooie View Post
Nah, homes. It's your dadda's hot goopey goop.
Old 12-15-2020, 09:27 PM   #22705
DarkSunrise
Nice, post up a review if you get them. At that price it's hard to go wrong. I was actually thinking of getting 595 RS-RR's, but to use as track tires.
Those are 17x8 +42.
Haha I don't actually log gas mileage but it's bad for sure. I'm on E85 and do a lot of "spirited" canyon driving, plus some track days. Probably for the best I don't know lol.
2022 BRZ Build
2013 FR-S Build
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post:
KR-S (12-16-2020), MJones_RB (12-16-2020), Rican_D (12-15-2020), soundman98 (12-19-2020)
Old 12-15-2020, 09:33 PM   #22706
Ashikabi
Ashikabi's Avatar
Those are 17x8 +42.
E85 costs less per gallon so mileage doesn't matter right?
Old 12-15-2020, 09:46 PM   #22707
DarkSunrise
Yeah around here it's currently $3.30/gal for 91 and $2.30/gal for E85. So E85 is 30% cheaper and gets ~25% worse gas mileage.
Honestly though, the power difference alone is worth it. This engine loves E85.
2022 BRZ Build
2013 FR-S Build
jflogerzi (12-21-2020)
Old 12-15-2020, 10:09 PM   #22708
Ashikabi
Ashikabi's Avatar
See. You're saving money. And your car is greener now too! Aren't racecars great?
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
DarkSunrise (12-15-2020), soundman98 (12-19-2020)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 10:19 PM
