Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-26-2014, 05:47 PM | #15 | |
building life
Drives: Raven Black, 6MT
I'll check it all & update the thread.. Something I'll be looking at this weekend Sent from somewhere |
07-26-2014, 05:48 PM | #16 |
Flux capacitor is bad, you should probably change your headlight fluid!
07-28-2014, 01:35 PM | #17 |
building life
this morning started looking into it..
had the ecutek plugged in so i can see how the numbers are running.. it started after the 2nd time, ran fine till it warmed up. once warmed up after about 18 minutes of running, cylinder 1 misfired once cylinder 2 misfired twice and cylinder 4 misfired once and the car just automatically died on its own |
07-30-2014, 01:56 PM | #19 |
I'ts probably either a bad fuel pump or bad install on the fuel pump.
Fix that and you'll fix your fuel pressure. You need to take your car to a competent tuner/shop IMO. |
The Following User Says Thank You to mike the snake For This Useful Post: | Sportsguy83 (07-30-2014) |
07-30-2014, 03:59 PM | #20 |
Drives: 2014 Whiteout M/T
Seriously man... stop trying to kill your car. Call a towing company near you and have it towed to a local tuner before you wreck something.
07-30-2014, 05:33 PM | #21 |
building life
07-30-2014, 05:34 PM | #22 |
building life
Figured out what was wrong with a local tuner/shop. also from these forms. car will be getting towed to his place tomorrow
10-08-2015, 10:41 AM | #23 |
Drives: 2013 SWP BRZ Limited
@PolishFrs13 sorry to bring this thread back from the dead but any update on what your problem was? I'm having the same exact issue on my car right now. Turns on but dies on its own after about 5-10 mins. I too have a FBM fuel pump. Any help?
10-08-2015, 10:48 AM | #24 |
Drives: 2013 Brz C38 (bought not built :P)
the issue was: IT WAS A BASE TUNE!!!!!!!!!!! OP kept trying to find issues that don't exist (kill his car) instead of listening and getting a damn tune done as base tunes are not made to be driven on they are made so you don't detonate your engine on the way to the tuner.
did you even read the thread!? |
10-08-2015, 02:34 PM | #25 |
@fumanchu1 jeeez guy why you so mad lol. I did read the thread but OP said he found out what was wrong with a local tuner/shop. Wanted to know what the shop told him. Thanks anyway tho for your help.
@PolishFrs any update? |
10-08-2015, 03:39 PM | #26 |
God damnit the tiny emoticon didn't type (or maybe I only typed it in my head?). I was just messing around but yeah I'll go with 99.99999999% sure it was because it was running on a base tune with modded parts. The fact that he didn't say local shop but local tuner/shop suggests it was indeed tune related.
10-08-2015, 03:42 PM | #27 |
@jmelgar23 are you turbo'd? are you running the base tune? have you checked all the connections to ensure they are tight and no leaks? If you answered yes to all of these then my suggestion is..../drum roll..... get it tuned
10-08-2015, 04:16 PM | #28 | |
Thanks! |
Similar Threads | ||||
P087 Code and Car Dies, EcuTek Tuned, FI---Help! | kmbkk | Software Tuning | 34 | 04-05-2014 10:53 PM |
Car Dies at 170 Miles Check Engine Limp etc CASE CLOSED | learnerspermit | Issues | Warranty | Recalls / TSB | 38 | 11-06-2013 02:51 PM |
Famous Giorgi Tevzadze dies in Car accident | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 06-25-2013 01:28 PM |
Cape Town Man Dies after Crashing Toyota 86 | light | AFRICA | 20 | 05-10-2013 04:41 PM |
Toyota 86 in 10 minutes. | KKaWing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 03-28-2013 09:06 PM |
