Old 07-25-2014, 10:07 AM   #113
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by FR-S Matt View Post
I installed my Mishimoto Radiator last week and Mishimoto hoses. Filled up the coolant, burped the system. Radiator is still full. I keep checking the overflow tank and I swear my car is just drinking coolant. I'm going to check the water pump connection by the crank, but I'm pretty sure I am not seeing any leaks.
About to have to buy a third gallon of coolant because the aftermarket ones take a ton!
How many gallons of coolant did you use when you filled up the radiator?
N1rve
Old 07-25-2014, 01:42 PM   #114
FR-S Matt
1 and a half about. More needs to go in my reservoir as I've been monitoring it losing coolant.
Old 07-25-2014, 03:16 PM   #115
N1rve
N1rve's Avatar
It should take 8 quarts roughly or 2 gallons to complete this. You may be on the low end.
N1rve
Old 07-25-2014, 08:55 PM   #116
FR-S Matt
I had only a partial gallon or so with a backup full gallon. Think I'll order one more. Good news is I'm just above the low marker and it appears to be staying there, so I just need to top it off.
Removing my intake in the morning to check all my worm clamps and specifically that water pump hose to the lower radiator. Stock spring clamps sucked ass to use on the lower radiator. Didn't fit over the Mishimoto hose while on the lower inlet.
Old 07-26-2014, 12:33 AM   #117
litemup
Drives: around
Ok, everybody stop. Just stop.
Put your degrees back in your pants. Jeeeeezus!
Ideal gas law? Are you shitting me?
Are there people here that know better and are just watching this slow train-wreck?
~~~~~~~~~~~~~~~~~~~~~When it works~~~~~~~~~~~~~~~~~~~~
The cooling system is a CLOSED system.
In normal operation there is NO PHASE CHANGE.
In normal operation the LIQUID coolant expands a little until it reaches a specific pressure. Then, at a constant elevated pressure, continues to expand through the high-pressure check valve into the reservoir until the engine reaches operating temperature.
When it cools down, as the LIQUID contracts, it sucks liquid back through a much weaker check valve.
~~~~~~~~~~~~~~~~~~~~~When it's broken~~~~~~~~~~~~~~~~~
Now, assume your radiator cap has even a tiny leak in the big check valve. Big problem.
Eventually, pressure bleeds down to the point at which the solution will boil at engine operating temperature...
...and, like a pressure cooker will continue to BURP VAPOR into the reservoir at a rate relative to the size of the leak and the engine operating temperature. From there, it will escape out the little hole in the top.
Ok, so, forgive me if someone already mentioned or implied it, not only must the system reach a certain pressure, it must hold it.
Any questions? I'm here all night. If I don't know, I will admit it.
litemup is offline   Reply With Quote
The Following User Says Thank You to litemup For This Useful Post:
M1K3 (07-26-2014)
Old 07-27-2014, 05:25 PM   #118
Ubersuber
Drives: BRZ Pearl White
Don't add just water to the overflow tank if you live in freezing conditions, the overflow tank may freeze and crack. Mix at least 50% coolant with the water or just use pure coolant as that will do no damage if it "freezes".
It takes a long time for the engine coolant to mix with the expansion tank coolant enough to freeze protect the overflow tank.
Ubersuber is offline   Reply With Quote
The Following User Says Thank You to Ubersuber For This Useful Post:
litemup (07-27-2014)
Old 10-11-2014, 08:04 AM   #119
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
FRS uses a lot of coolant?
I have a similar problem and after checking around i keep coming back to this thread. My reservoir coolant level keeps dropping. I last filled it, once cold to the full mark the 5th of october and now its already half way between low and full. Only six days after and half of it in the reservoir is gone?? There are no leaks anywhere that i could see, the radiator is completely full, any ideas? I really dread the trips to the dealers as i honestly think they are the worse people to work on the car but i don't have a mechanic and the car's got 7k miles on it.
For reference and future help to anyone with a similar problem. I took the car to the dealer and they did a pressure leak test. They found nothing, they say as long as the coolant in the reservoir doesn't go below the "low" mark, it's ok. If the coolant level drops below the low mark at any time then they'll have to perform other tests.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 12-07-2014, 12:56 PM   #120
exE36M3
Silly thought...
My old BMW E36 M3 used to drop coolant... about a liter a season... some factors to consider...
1. Evaporation - between the heat of the engine and weather, it happens. After all, what's right under the reservoir? The catalytic convertor.
2. The heater core - if you've been using this lately, and haven't ever topped off the coolant tank, it can hold an easy quart of fluid.
Hope this helps.
exE36M3 is offline   Reply With Quote
Old 12-08-2014, 06:54 AM   #121
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I have the Mishimoto radiator and hose kit. I also bought the tbolt clamps they had as well. My previous coolant issue loss with the stock hoses is now gone. Thinking the seal on the stock system is bad because my coolant has been full for 2 months now when hot.
2016 Camaro SS is offline   Reply With Quote
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
finch1750 (12-11-2014)
Old 12-08-2014, 06:34 PM   #122
slim blanco
slim blanco's Avatar
Drives: 2017 86
this thread got me all nervous last night haha. i bought my frs used on june 9th with 36k on it, and i do remember seeing the coolant level at 'full' when i brought it home. it was in the high 60's that day. i checked it this morning before leaving for work at 6am, it was just above the 'low' lettering...it was probably mid to low 20's outside. when i got to work, it was about half an inch under the full line. it did the same thing when i left work and got home as well, so i'm going to assume mine is acting normal. i'm definitely going to keep an eye on it though. all oem on my car.
slim blanco is offline   Reply With Quote
Old 12-09-2014, 08:04 AM   #123
2016 Camaro SS
Drives: Fast
I just checked my coolant again yesterday and it's still at the full mark.
I think the key is two things:
Silicon hoses
Clamps that aren't worm clamps (T-Bolt, or Constant Tension Bolt, Spring Bolt)
I'm willing to put more on the clamps being the key. Some FR-S/BRZ's I've checked in my area do not have coolant issues being newer models (2014/2015) but it is not consistent. It all depends on how well it is sealed and the clamps are the first place I would start.
Old 01-19-2015, 07:55 PM   #124
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Seem familiar? Maybe the leak is at the inlet to the reservoir. Going to check it out tomorrow in detail. It doesn't seem serious as I've only reached the 'low' mark 3 times since 2012.
n8dog11914 is offline   Reply With Quote
Old 01-23-2015, 06:34 AM   #125
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Originally Posted by ahausheer View Post
If a pressure test checked out ok and you are still looking coolant, that narrows the possibilities. The pressure test if done properly should rule out leaks due to hoses/connections etc. So that leaves either escaping through the top of the reservoir or escaping through something that requires more pressure than what the pressure test can reproduce. For example a crack in the head gasket or engine block, something that may be affected by heat or stress. Or am I wrong?
I imagine you guys that are loosing coolant have checked the oil or looked under the oil cap for milky residue?
Be advised
That milky residue can also be condensation from not driving the car to operating temperature.
Young_makaveli is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 05:13 PM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 09:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:23 AM
