Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
03-28-2016, 01:46 PM | #15 | |
03-28-2016, 05:57 PM | #16 |
Drives: '13 SSM BRZ Limited 6MT
I'd follow what @humfrz mentioned, shift at 4k rpms, don't slam the shifter and push the clutch all the way in. I used to shift around 3k rpms and could rarely ever get it smoothly. Oddly enough, when I drive lazily and on the streets, I shift at 2000-2500rpms and can get it smoothly. It's so slow since I have to go easy on the throttle.
The Following User Says Thank You to tracerit For This Useful Post: | humfrz (03-28-2016) |
03-31-2016, 12:12 PM | #17 |
Drives: 2013 Subaru BRZ Limited (WRB)
Yep, any time the weather is below 60F until the car gets to operating temp. I've given up trying to fix it. There is no fix. It's just a garbage gearbox.
I've tried several different kinds of fluid including Amsoil and now using Motul Gear 300. Nothing improves it, and it always feels the same until the car warms up. If it's really cold, it gets bad enough where it won't go into 2nd sometimes or it grinds going in. So, I've got into the habit of skipping 2nd completely. |
The Following 2 Users Say Thank You to Apex_BRZ For This Useful Post: | Uplink (04-04-2016), ZionsWrath (03-31-2016) |
03-31-2016, 01:25 PM | #18 | |
Drives: 2013 WRB BRZ 6MT
03-31-2016, 02:52 PM | #19 |
hey you, yeah you <3
Drives: 2014 37J FR-S
I had this issue on 2012-2014's.
Stalling also felt like a daily issue as well. I think it's a mixture of lubrication and pedal feel. What solved my stalling issue was changing oem intake for TRD. Concerning the clunk or 'chunkiness' sound...kind of softened up with 20k miles. Most forum members lessened the sound and feel with oil change to transmission, but it did not completely erase it. AKA make shifting buttery smooth.
04-01-2016, 11:18 AM | #20 |
Drives: Whiteout FRS
I had this issue before but changing fluids to Motul 300 helped out a lot. I don't get the clunky 1-2 or 2-3 shift anymore even in the morning. I usually shift from 1 to 2 at 3500-4000 rpm and I always get that nice "snick" noise. 3rd goes in smooth when I shift around 3000-4000 rpm.
04-01-2016, 02:14 PM | #21 |
Drives: 2015 AOZORA EDITION
best way to not feel the clunk is use a heavier knob like a raceng
04-01-2016, 06:22 PM | #22 |
04-01-2016, 11:29 PM | #23 |
The OEM shift knob is 198g. Raceseng Slammer is 635g and the Ashiko is 735g. I myself have the Ashiko and my shifts are smoother. However, there is still a bit of "clunk" while shifting but I think it's a good thing since it's just feedback letting me know I'm shifting right. The Raceseng shift knobs or any other heavy weight shift knobs for that matter won't make your gear shifts feel like butter but it helps.
The Following User Says Thank You to Regalo For This Useful Post: | shellslinger (04-02-2016) |
04-02-2016, 12:11 AM | #24 | |
humfrz (jest ah messen wich ya .... ) |
04-02-2016, 01:35 AM | #25 | |
I am now a little over 50K miles and still have the original oil in the tranny and quite frankly I am a bit nervous about changing it and ruining my issue free run.
04-02-2016, 07:12 PM | #26 |
Drives: car
My shifts got better with the right maintenance and the proper shifting behavior. Replacing the fluid (motul 300) and the original throw out bearing, which was shot, fixed most of the issues.
Sometimes yeah the gearbox does not feel crisp, mine is pretty worn in and has some play though so that's probably just my problem. But I am still always confident that I'll go in gear on a quick upshift or downshift and I don't have a grind issue, except for 5th sometimes but that just might be me accidentally engaging the clutch too early. |
04-04-2016, 06:50 AM | #27 | |
Because compromise ®
Drives: Red Herring
so improving shifter feel site:ft86club.com notchy shifter site:ft86club.com etc
04-04-2016, 05:04 PM | #28 | |
Drives: anything you let me
OP- Seriously though, the positive engagement feel you get with this car is worth the price of admission. I've got a ZF that shifts the same way and it's so satisfying. If you have plans to go with one of the aftermarket single piece drive shafts, the clunk will become more pronounced. The only issue I've ever had *knocks wood*, and it's probably been stated a thousand times before as 'normal', is the 1-2 shift on cold days before the transmission is fully warmed up (driven warmed up, not idle warmed up). It's annoying with regular fluid and downright unbearable with Motul. Most of this winter standard operating procedure was 1-3-4 exclusively until about 3-4 driven miles when 2nd gear 'unlocks'. Prior to that, any attempt at second gear with any forward movement of the car and it will act like a locked gate. You will also notice a little more gear rattle using Motul with the car idling if you listen carefully. In a garage it's very obvious and goes away when you press the clutch pedal. |
The Following User Says Thank You to Uplink For This Useful Post: | Tcoat (04-04-2016) |
Similar Threads | ||||
Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 10:44 AM |
Automatic Gear Ratio change | Toyota86.ir | Engine, Exhaust, Transmission | 31 | 05-10-2016 03:10 AM |
Gear Ratio Change | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 06-26-2014 10:20 PM |
This kind of explains how I feel in sixth gear | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 11-03-2013 12:52 PM |
any way to change the gear ratios in manual? | SuperDave | Engine, Exhaust, Transmission | 17 | 10-19-2012 10:07 PM |
