01-11-2016, 06:22 PM | #2941 | |
Perpetually Sideways
Drives: '14 DGM BRZ, '94 Volvo 940 Turbo
Sorry, I'm new to tire measurements. The main reason I mentioned 215/50R17 was because I found a really good deal on tires in that size but will certainly keep the narrower option in mind as well. |
01-11-2016, 09:29 PM | #2942 |
Drives: 2014 GT86
carczar87: IIRC there is only +2% difference between 205/50R17 and stock 215/45, so rather close. And yes, higher sideprofile/lesser width tires on average cost less, and yes, in winter it's often advised to have narrower tires for more pressure per contact patch, to less snow-slush-planing, to better get studs in ice and so on. I'm sometimes thinking of 195/55/R17 (+3.25%), or it's too much stretch for stock 7" rim width?
01-12-2016, 12:44 PM | #2943 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
Been hunting for 245 tires for a few weeks without success. Shop picked up some nitto NT01's for me but turns out they are 235 and not 245. I'm gonna put them on 17x9 +35 wheels. I'm not a fan of stretch and not using the wheel to its fullest, but will this be a big compromise at the track/canyons until I wear out the set and try again?
01-12-2016, 12:59 PM | #2944 | |
The Following User Says Thank You to swarb For This Useful Post: | Toyarzee (01-12-2016) |
01-12-2016, 01:05 PM | #2945 | |
Shibby!
01-13-2016, 03:23 PM | #2946 |
Drives: 2015 FRS
I've seen what will fit, etc. However, I want to know what is the ideal 18" in terms of maintaining the current driving dynamics? I'm afraid to go too wide and change the way the car turns in and corners. Is 18x8 or 18x8.5 preferred? I assume 18x9 would be too wide and affect dynamics? I'm stock power, and in terms of suspension I'd like to add some lowering springs along the lines of TRD/Eibach/RCE Yellows.
Also, would spacers vs staggered be a better option? Going squared just doesn't fill the wheel wells evenly the way I would prefer. |
01-13-2016, 03:47 PM | #2947 | |
Spacers are better as you can rotate the tires. Stagger will ruin whatever balance you wanted to keep. |
The Following User Says Thank You to swarb For This Useful Post: | KidRed (01-13-2016) |
01-13-2016, 03:53 PM | #2948 |
@Toyarzee I couldn't find much details on the tire, but the section(outside to outside) width is 9.49. Wheel width is measured inside to inside of the lip, so the outside of the lip may be near 9.5 or 10inches. There will be a tiny stretch if any.
Also take note that tire reviews for R-compounds are usually from racers who have very high standards and only want the best. At that price, the nitto's are bang for the buck and good for what they are. From Summit Racing- Tire Diameter: 24.40 in. Section Width: 9.49 in. Minimum Recommended Wheel Width: 8.00 in. Maximum Recommended Wheel Width: 9.50 in. |
The Following User Says Thank You to swarb For This Useful Post: | Toyarzee (01-13-2016) |
01-13-2016, 05:31 PM | #2949 | |
Drives: 2015 FRS
Thanks. It doesn't have to stay exactly stock, but I don't want to lose too much of the go cart type steering response we have on these. At what width does the grip start to affect the steering? If I went 8.5, what tire would you recommend, 235/35? |
01-13-2016, 05:43 PM | #2950 |
01-13-2016, 05:44 PM | #2951 | |
Drives: FR-S Firestorm 6MT
235/35R18 is not an available tire size. 235/40 or 245/35. 245/40 is too tall so stay away from that size. |
01-13-2016, 06:06 PM | #2952 | |
Shibby!
Edit: not sure why I didn't get the mentioned notice, glad I check this forum frequently |
01-16-2016, 05:24 PM | #2953 |
Drives: Fupa Rider
I been searching the forums. I can't seem to find the answer I was looking for. I was wondering if 18x9.5 +38 fit fine in the front with lowering springs? Also what would be the best recommended tire size, thinking about getting 235/40/18. Please let me know TIA!!
01-20-2016, 07:47 PM | #2954 |
I just got new wheels that measure 18x8.5 with a 33 offset and I was wondering what size tire I should put on. I was thinking 245 but will that rub? Should I go smaller?
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
