Tracking / Autocross / HPDE / Drifting What these cars were built for! |
03-26-2022, 10:24 PM | #1 |
Drives: Gr86
$5K for track build
About to pick up a GR86. Will use it mostly for track duty…must be street legal so I can drive it to/from the track.
If you had $5K for upgrades, what would you do? |
03-26-2022, 10:28 PM | #2 |
Drives: '13 Whiteout
The Following User Says Thank You to TommyW For This Useful Post: | soundman98 (03-27-2022) |
03-26-2022, 11:16 PM | #3 |
Drives: 2015 Scion FRS Release Series 1.0
18x8.5 +40 rims with tw200 tires…2000
Rcr ss1 coilovers…1600 Proper brake pads and fluid…400 The remaining 1k up to you. |
03-27-2022, 04:27 AM | #5 |
Drives: '13 FRS - STX
Camber plates, camber bolts, rear lca, alignment -3 and -2 degrees camber F/R to start: $1k-$1.5k, car will probably want more camber but you’ll figure it out in time.
Use up the factory ps4s, pick next tires as desired $1k give or take. Brake pads $500 Brake fluid $50 Real oil cooler $750 Use the rest on gas. |
The Following User Says Thank You to strat61caster For This Useful Post: | Icecreamtruk (03-28-2022) |
03-27-2022, 07:32 AM | #6 |
If I was to completely start over again, this is what I'd do:
The Following 6 Users Say Thank You to SCFD For This Useful Post: | BigTuna (03-27-2022), Icecreamtruk (03-28-2022), Re_Invention (04-01-2022), smg1138 (03-29-2022), strat61caster (03-27-2022), treedodger (03-30-2022) |
03-27-2022, 09:31 AM | #7 |
ProCrastinationConsultant
the BEST first question.
also, $5k what? $5k per track day? $5k per month? $5k per year? $5k all-in(and no one is ever all-done paying for track stuff)?
The Following User Says Thank You to soundman98 For This Useful Post: | CSG Mike (03-28-2022) |
03-27-2022, 10:07 AM | #8 |
Drives: Gr86
~20 track days in a modified Miata.
Already have a helmet, Hans, camera, data logger, and tools. I have $5K for initial upgrades. I’m seeing a lot of recommendations to start with an oil cooler. How serious are the overheating problems on track? Besides the oil cooler, would hood vents help? - oil cooler - wheels/tires - coilovers - camber plates / alignment - brake pads, fluid, lines - sway bars |
03-27-2022, 10:15 AM | #9 |
Drives: 2013 frs base
If the suspension is in decent shape, you might run it stock for a while. Spend the extra $1k on a header and a tune. In Va? Are you going to run Summit Point and VIR?
03-27-2022, 10:41 AM | #10 | |
03-27-2022, 02:46 PM | #11 |
Nothing but Brake Fluid, pads, and camber adjustments. They are really good stock already.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | blsfrs (03-27-2022) |
03-27-2022, 03:19 PM | #12 |
Drives: 2014 Subaru BRZ
So, the response depends on how many days per year you want to do and what your goals are. If you're doing fewer than 10 days per year and are just looking for some fun trackdays, $2k for a set of RS4's and some wheels (17s to keep the costs down) then some camber plates/bolts for the front and some good pads. Keep the rest to do more events.
If you're looking to do more events then I'd get the AP Racing sprint kit, the pads are cheaper and last longer plus you'll never have to worry about brakes. I'm also in the pro-oil cooler camp, I ran one on my 2014 and only had to tighten the connectors once over 6 years with 30 or more days per year. You'll probably also want some coilovers, I'd recommend doing it right the first time so you don't feel like doing it a second time. Unfortunately, wheels and tires, AP brakes, oil cooler, and suspension is going to run about $7k. |
The Following User Says Thank You to 14stu For This Useful Post: | blsfrs (03-27-2022) |
03-27-2022, 09:45 PM | #13 | |
Drives: Gr86
Any other good ones near VA? |
03-27-2022, 09:48 PM | #14 | |
Drives: Gr86
The AP Racing Sprint Kit is $2,300. I’m all about the brakes, but that’s a lot. Agree on the coilovers. Will go with a good set the first time. |
Similar Threads | ||||
Mr. Frs Trd track build | Mr.Frs | Member's Car Journals | 24 | 06-20-2018 06:20 PM |
dp1 track build (NY) | dp1 | NY / NJ / CT / PA | 114 | 07-19-2017 01:47 PM |
What's your Track Build? | neroman98 | BRZ First-Gen (2012+) -- General Topics | 4 | 08-06-2015 04:16 PM |
FRS Track Build | smoltz | Tracking / Autocross / HPDE / Drifting | 27 | 07-08-2015 09:17 AM |
mrharry 86 Track Build | mrharry | Member's Car Journals | 5 | 08-10-2014 01:44 PM |
