Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
01-05-2021, 03:41 PM | #15 | ||
Drives: 2015 BRZ Series Blue WRB
Already remove the throttle body and cleaned it. Before and after doing that, issue is still there. And yes i should get a CEL! very frustrating to know there is a problem but cant figure out where is it. |
The Following User Says Thank You to Jfheisenberg For This Useful Post: | JesseG (01-12-2021) |
01-05-2021, 03:53 PM | #16 |
01-05-2021, 08:01 PM | #17 | |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | JesseG (01-12-2021), Jfheisenberg (01-06-2021) |
01-06-2021, 02:15 AM | #18 |
Software Hobbiest
Drives: 2015 FRS
I was having the same issue, after checking both my o2 sensors and in the process of verifying that the other sensors all worked correctly I unplugged my maf sensor while the car was running and it started idling correctly. This is a sign of a bad maf sensor that needs to be replaced. Now I'm having from finding the issue but sad because toyota wants 200 for a maf sensor. Hope my problems help your problems
01-06-2021, 05:56 PM | #19 | ||
What is happening is the following: 1- When driving the car, i can feel a sluggish/hesitant acceleration. The interesting/weird part is that i can only feel this at around 3k RPM up to 4k RPM. Its possible that the issue is throughout the RPM band, but i can only noticed/feel this problem on such range. 2- The second issue is some rough idle when car is stopped. For this, i have tried to clean the MAF sensor, remove and cleaned the throttle body. It's important to note that this problem got 'better' after i remove my CAI entirely and put my OEM stock box and new air filter. I have recorded two more logs during driving. (The car was warmed up on both cases) Same .CSV format: Run 2 Run 3 Quote:
What i did try, was to swap my MAF sensor with a friend's MAF sensor (he also has a BRZ), but this didn't make a difference. Unless, i swapped it and forgot to do an extra step that i'm not aware. |
01-07-2021, 10:48 AM | #20 |
Have you looked into potential fuel pressure issues?
01-07-2021, 11:56 AM | #21 |
Drives: Crapcan
Yeah something like that is going on. In the parts of the log where there is a steady idle for 10 sec the AFR is all over the place but maf voltage and load are pretty close to steady.
01-07-2021, 09:34 PM | #22 | |
I wouldn't know what to look about fuel pressure. I do recall that few weeks after this problem started, i borrow my friend's scan tool and it showed a trouble code "P0462 - History - Fuel level sensor 'A' circuit low input". Looks like it was on a history log as i never got a check engine light for this. I mentioned this code to the shop that checked the car and they said it shouldn't be the issue. Its possible that the issue is related to fuel, but so far the shop i been to were not able to find the problem. Also, on the OFT i do not have any fault codes or codes shown on history. |
01-08-2021, 01:54 AM | #23 |
Can you do this. Take a log of a few WOT pulls starting around 2500-3K to Redline and post the logs. Use datazapp to view the logs. I am curious through the pull does the car feel sluggish.
What were any changes does to the car prior to it doing this? Whats your IAM at? Any knock in the engine?
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | JesseG (01-12-2021) |
01-08-2021, 10:06 PM | #24 |
Drives: 2017 subaru brz
Curious how did you find a leak? Do you literally just put your hand near the gasket and feel for air with the car running? I'm suspecting a leak somewhere in my exhaust but don't know the symptoms.
01-09-2021, 06:24 PM | #25 | |
Drives: 2013 Fr-s
Sent from my SM-G781U using Tapatalk |
01-09-2021, 06:30 PM | #26 |
Drives: BRZ 2018
Common symptom when MAF sensor has problem in Subarus.
Cone filters, excessive oil in the filters, vibration etc can cause MAF degradation, try a MAF from a fellow car and see if this is your issue! Last edited by JIM THEO; 01-09-2021 at 06:44 PM. |
01-09-2021, 07:21 PM | #27 | |
Drives: 2013 Fr-s
The Following User Says Thank You to Uncle86 For This Useful Post: | JesseG (01-12-2021) |
01-11-2021, 07:47 PM | #28 | ||
Its possible that the issue is still there, but since i'm accelerating hard i do not notice it on those cases. Seems like the issue is mostly felt when i drive the car 'normaly', when i hit the gas hard, it appears i dont feel the problem. I did noticed that after driving hard for a bit, my idle problem got a bit worse. It's all strange That datazap.me tool is great, i was able to upload the two pulls and it shows a graph: https://datazap.me/u/jframonex/brz-pull-1?log=0&data=1-13 https://datazap.me/u/jframonex/brz-p...og=0&data=1-13 Does this mean anything? |
Similar Threads | ||||
Rough idle | edwardry2019@gmail.com | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 10-14-2020 01:28 PM |
Rough Idle | DeathToocher | Engine, Exhaust, Transmission | 18 | 03-20-2020 10:45 AM |
Took my car in for rough idle... | Da Brz | Issues | Warranty | Recalls / TSB | 34 | 10-29-2016 12:57 AM |
'14 BRZ Ltd. - Rough Idle | leicaboss | BRZ First-Gen (2012+) -- General Topics | 20 | 05-22-2014 06:40 PM |
Rough Idle & CEL *video | JiB | Issues | Warranty | Recalls / TSB | 5 | 10-04-2012 10:28 PM |
