Software Tuning Discuss all software tuning topics. |
05-23-2017, 11:36 AM | #15 |
Drives: UK GT86
That would be my understanding, yes.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Tor (05-23-2017) |
05-24-2017, 07:17 AM | #16 |
Drives: Toyota GT86
Thank you. How do you go about getting it started? E.g. I see you put 30 as the first CAL value and chose 0.9 in Exp Base. Can you explain what you are looking for when picking those numbers? And do you settle on Exp Base from the start or are you revising it as you go along? Thanks a lot for your help!
05-24-2017, 03:21 PM | #17 | |
Drives: UK GT86
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Tor (05-24-2017) |
05-24-2017, 08:29 PM | #18 |
Drives: Toyota GT86
Thanks a lot again.
I flashed your values and here are some the results. Full throttle from 1200 rpm in 3rd gear: http://www.datazap.me/u/tor/tor-218-...zoom=8955-9105 Above at IAT 20 down to 15 C. And after about 60 km driving. Here earlier at IAT 30 down to 25. And after mayby 30 km: http://www.datazap.me/u/tor/tor-218-...om=11873-12006 Stock A01G IAT compensation was reenabled in the above logs. My reason for doing this was that my LTFT kept changing. One day +2.5, the next day -1. Lowering the OL timers didn't help. And setting them at 0 felt horrible. My previous MAF was scaled at fairly low temperatures and without disabling the IAT compensation. Could the swings have been caused by IAT compensation influencing the scaling and subsequently messing up the trims when driving at different temperatures? In any case, the engine seems to like it and it must be the flattest AFR curve I have had so far. It might be placebo and wanting to feel a difference, but it certainly pulls very smooth now. Now waiting in anticipation what the LTFT are going to do. Hopefully, they will stick around 0 and remain stabile. Last pull I did on the way home had -0.05 LTFT.
11-25-2017, 09:31 PM | #19 |
Drives: Toyota GT86
I'm looking for your AVCS tool, but can't find it. Did I miss it being incoporated in one of your other tools?
11-26-2017, 04:27 AM | #21 |
Drives: UK GT86
Added to the 1st post.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Tor (11-26-2017) |
11-26-2017, 07:07 AM | #22 | |
Drives: Toyota GT86
I was just curious where my cams are according to the useful information from @arghx7 on nasioc. Thanks. That was the one.
The Following User Says Thank You to Tor For This Useful Post: | steve99 (11-26-2017) |
11-27-2017, 01:01 PM | #23 | |
Drives: Toyota GT86
I think this can indeed be extremely helpful to blend in the adjustment from Vgi's too into the rest of the table. I'll post later how I use it in the AVCS thread I started.
The Following 2 Users Say Thank You to Tor For This Useful Post: | Kodename47 (11-27-2017), Vin (11-28-2017) |
Similar Threads | ||||
Pulley tool rental? | Asian Delight | Southern California | 0 | 01-01-2014 01:37 AM |
Favorite car tool | brillo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 23 | 09-18-2013 09:19 AM |
What basic tool set to get? | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 09-05-2013 11:46 AM |
pry tool | jazztennor | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-15-2012 02:02 AM |
What does this tool use to | carscat | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 06-27-2012 09:24 PM |
