01-18-2021, 03:54 AM | #1975 |
Drives: GTS 86
Hi Guys,
I've got a Turbo AVO Stage 3. What do you think. I don't think it's knocking much... First tune with it and it's driving real nice. Getting a bit of boost creep going up to 10PSI but apart from that, it's running real nice. https://datazap.me/u/nutgud/2000-750...?log=0&data=14 |
01-18-2021, 06:23 AM | #1976 | |
Drives: brz 2017 hksv2
01-18-2021, 06:48 AM | #1977 | |
Drives: GTS 86
Avo says the tune is trying to target 11.3 but obviously you can't tell with the stock sensor Didn't realise the fuels and timing is all over the place. Might need to get a dyno tune sooner then I thought Sent from my HD1900 using Tapatalk |
01-25-2021, 05:57 PM | #1978 |
Barred
Drives: My18 wrxsti My19 brzts
This is the 2nd tank of e85. It would have 1-2 litres of 98 fuel still mixed. Driving up a mountain.
Should I be happy,What do you think? https://datazap.me/u/gen3v8/log-1611614147
Wait until my Flex capacitor hits 88
01-25-2021, 06:24 PM | #1979 |
maf is a little off on open loop
Probably would run better fuel-wise with some more petrol mixed in and less ethanol |
The Following User Says Thank You to tomm.brz For This Useful Post: | gen3v8 (01-25-2021) |
01-29-2021, 12:11 AM | #1980 | |
On my logs, here is one large KC event that caused IAM to drop to 0.88: https://datazap.me/u/darksunrise/202...zoom=6097-6225 I cut about 4-5 degrees of timing from the base timing there and that helped, but still occasionally see knock there: https://datazap.me/u/darksunrise/202...4&zoom=621-923 I doubt it's false knock since it happens at a specific load and RPM range, but seems odd to me that it would knock like that on E85. Also are you using a catted header?
2022 BRZ Build 2013 FR-S Build |
01-29-2021, 01:23 AM | #1981 | |
Drives: FR-S Whiteout
I've been hunting down the cause of that knock for years, bro.. Chalk it up to "phantom knock". Although I've found that a catted front pipe vs a straight one, the catted OE pipe will always register less amount of knock correction at the .6 load area in the sub 3600rpm range. I'm not sure if you recall. That "knock" only happens half the time that I hang the load and RPM's in that load and rev range. pretty much 50/50. Half the time it does nothing. Same on petrol. I haven't hooked up knock ears to it, since I dont have much experience with them. If you're worried, maybe give that a shot and see if that help you correctly categorize whatever it is thats is triggering the sensors. Besides the original equipment that come on the car. I've ran 3 separate catless headers. If a 17 up header falls in my lap, I will likely develop a flex fuel tune for it. I think cams might have something to do with it. Loose exhaust components will obviously exacerbate the problem. (thats from experience)
Intent > Content
cowardice is the mother of cruelty. |
The Following User Says Thank You to solidONE For This Useful Post: | DarkSunrise (01-29-2021) |
01-29-2021, 10:48 AM | #1982 | |
The knock ears is also a good idea but I don't have experience with them unfortunately. I've cut so much timing out of those load cells/RPMs that I'm actually running less timing there than the stage 1 gas map. Seems like it may have helped, but hard to say since like you said, the knock seems to appear randomly. I might eventually take your approach and just view it as phantom knock, but going to try one more thing first. If I find something that eliminates this annoying KC, I'll let you know.
The Following User Says Thank You to DarkSunrise For This Useful Post: | solidONE (01-29-2021) |
01-29-2021, 04:13 PM | #1983 | |
With a 2.75" straight front pipe, I had all sorts of false knock. I'm guessing perhaps extra vibration at that load or the "harmonics" of the pipe amplifies whatever it is that is causing it to pull timing. That is my best guess, and I'm sticking with that theory until proven otherwise. The trick is.. not look at it too much. lmao the more you try to reproduce this in logs and staring at it the more annoying it will get. You can play with the cams, fueling or timing to try to reduce (which I did as well). I ended up doing a bit of richening of the fuel map at those loads, pulled a bit of timing and called it done. I also tried adjusting the cams a bit, but after I saw I wasnt really effecting that KC, I decided not to pursue that rabbit down the rabbit hole any further. But if you figure it out, let me know. I would really appreciate it. lol Edit: while adjusting the cams I did notice where it’s “triggered” seems to move up or down the revs by a couple hundred rpms. It stil had the same KC same amplitude just at a slightly different spot. Now if you manage to make it occur, say, only 20% of the time as opposed to half the time. I’ll call that a win.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 01-31-2021 at 01:00 AM. |
01-29-2021, 10:35 PM | #1984 |
Barred
Wayne roms e85 tune 3rd tank, 700kms 2 pulls and some driving. Before I touch any thing. I`ll wait for recommendations. cheers.
https://datazap.me/u/gen3v8/log-1611976832
01-30-2021, 02:10 AM | #1985 |
it's very good, maybe you can try with his version +2% rich
since your open loop is a bit lean (even if e85 is keeping strong, i would enrichen a bit |
The Following User Says Thank You to tomm.brz For This Useful Post: | gen3v8 (01-30-2021) |
01-30-2021, 10:53 PM | #1986 |
Barred
Rescaled my maf from my last Log and these are my 2 new logs 1xCL and 1xOL.
I think they are good but I will wait for the comments from people that have more than my limited experience. Comments welcome! https://datazap.me/u/gen3v8/maftest1 https://datazap.me/u/gen3v8/3rdgearpull
01-30-2021, 11:30 PM | #1987 | |
Drives: Toyota 86 GTS
You can try increasing the rpm range for CL like this. |
The Following User Says Thank You to Wayno For This Useful Post: | gen3v8 (01-30-2021) |
01-31-2021, 05:27 AM | #1988 | |
Barred
Similar Threads | ||||
RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
