Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-28-2021, 12:09 AM | #1 |
Drives: 2017 BRZ w/PP
built block options
so i blew my engine today cruising on the highway. oil all over the place and none in the engine. its totally seized. so now i guess i build the block and throw the super charger on which i get monday. so what are my options? I guess IAG closed deck?
03-28-2021, 08:42 AM | #2 |
Rust bucket enthusiast
Closed deck is unnecessary, our cylinder walls are not thin like EJ motors. Stage 1 IAG is fine
The Following User Says Thank You to DarkPira7e For This Useful Post: | Breadman (03-28-2021) |
03-28-2021, 08:56 AM | #3 | |
for heads and cam do you just run stock? i have a c38 showing up tomorrow and i am extremely tempted to just say fuck it and go full project car and get an RS pulley and cd009 swap. im kind of glad this happened now vs when i would be tuning it with zach |
03-28-2021, 10:08 AM | #4 |
Drives: '13 Whiteout
I used the IAG S1 but stayed NA. Have the stock heads machined and if you have an oil cooler trash it and get a new one.
03-28-2021, 10:17 AM | #5 |
03-28-2021, 10:46 AM | #6 |
Yep, everything works with stock. Stock headgaskets as well
03-28-2021, 11:41 AM | #7 |
03-28-2021, 12:41 PM | #8 |
I would recommend upgrading the valve springs. I meant as far as boring them out, upgrading cams, etc
03-28-2021, 12:54 PM | #9 | |
cool thanks for the info. now at least i know where to start looking. this whole situation fucking sucks. i knew i would blow my engine eventually but i figured it would be on the track after supercharging now cruising the highway NA |
03-28-2021, 12:56 PM | #10 |
helmholtz resonator
Drives: '15 ultramarine
03-28-2021, 01:02 PM | #11 | |
Make certain that you run all of your purchases choices by the tuner before making them; the last thing you want is something your tuner/builder doesn't recommend and they don't want to deal with figuring it out. Biggest thing to be certain of is that you get a checklist of everything they're going to need- headstuds, fluids, gaskets, etc.
03-28-2021, 01:13 PM | #12 |
03-28-2021, 01:14 PM | #13 | |
yep calling csg during lunch tomorrow assuming some asshat didnt schedule a lunch meeting. also already making the sheet |
03-28-2021, 09:02 PM | #14 |
Drives: 13 White MT FR-S
I would recommend Element tuning to build block or just drop the FA20
Similar Threads | ||||
FS: FA20 Fully Built Short Block | MicheleAbbate | Engine, Exhaust, Bolt-Ons | 24 | 08-28-2019 09:57 PM |
FBM stage 1 built block questions | Matey | Engine, Exhaust, Transmission | 5 | 03-24-2017 07:39 AM |
Crawford Built Short Block | texasbound972 | Engine, Exhaust, Transmission | 26 | 05-15-2015 03:39 PM |
Built B18B Short Block | C130NAV | Miscellaneous | 0 | 01-04-2014 12:15 PM |
