12-02-2013, 02:23 PM | #505 | |
i'm sorry, what?
Drives: Canada
your choice for coilover spring rate should have been fit for your intended use... you put thicker/thinner bars on front/back depending on whether you're over/understeering at a specific track or day. there is NO magical formula, you tune according to what what you desire the car to do.
12-02-2013, 02:23 PM | #506 |
That depends. What are you trying to achieve? What do you like and dislike about your setup?
The Following User Says Thank You to CSG Mike For This Useful Post: | PRORICAN (12-02-2013) |
12-02-2013, 02:36 PM | #507 |
Yeah I kinda guessed these questions where coming, lol. I want to autox next season and want to prepare for it, but I'll leave it as is, autox it and figure out what the car is doing good or bad. I guess I wanted to see if anybody has experience with these and figured they needed swaybars for autox. Thanks
BeastCoast.US feature http://beastcoast.us/2013/11/28/all-the-right-moves/
Build Thread http://www.ft86club.com/forums/showthread.php?t=8204 |
12-02-2013, 02:53 PM | #508 | |
12-04-2013, 01:38 PM | #509 |
Regional Moderator
Drives: VADER 86
I'm at work and don't have time right now to read through 24 pages to possibly find my answer haha. So, here's my Q...
I currently rub on my rear tires. I am hoping that getting LCA's to adjust the camber will fix this as I have already slightly rolled the fenders. Will I have to also get toe arms with the LCA's? Please tag me in the answer (@vader). Thanks in advance! |
12-04-2013, 05:25 PM | #510 | ||||
Drives: EVO
I am curious about this idea that a big front bar improves response though. I recently tested out removing the sway bars all together on another light RWD platform. What I found was a car with instant turn-in and remarkable front grip. It almost felt like the car knew where to go before I even turned the steering wheel...It also over steered so greatly that it slowed the car down considerably. Putting on the front bar balanced the car back out but KILLED the turn-in response up front. I'm now on a mission to match the no-bar turn in but keep it balanced. My wheel rates are fairly high too with a lot of front bias (580F/380R) with a 53/47 weight balance, yet the car was still crazy loose. |
12-04-2013, 05:39 PM | #511 |
Drives: Mazda 3
i think its because the front bar is much stiffer than the rear when motion ratios are calculated. so the balance changed a lot by removing them.
12-04-2013, 06:06 PM | #512 | |
Senior Addict
Drives: 86 GT
12-04-2013, 06:45 PM | #513 |
Drives: EVO
Autobrz, as mentioned, this was not on the GT86 platform. Just another lightweight RWD. I included the wheel rates of the springs alone for comparison purposes. For reference, it was a 680lb/in spring on an 2400 pound E36 BMW setup...LOTS of spring to control roll. Wheel rates of 580/380 should tend towards understeer considering the weight balance of the car, but that wasn't the case.
It would be interesting to see how the twins responded to removing the swaybars while using high spring rates. As I said, the turn-in and front grip was phenomenal without the bars on, maybe the GT86 would respond beter with it's more advanced rear suspension? |
12-04-2013, 07:06 PM | #514 | |
If you're rubbing on the outer edges, then the LCAs MAY help. It depends on the magnitude of the rubbing. You won't need toe arms. |
The Following User Says Thank You to CSG Mike For This Useful Post: | VADER (12-04-2013) |
12-04-2013, 10:07 PM | #515 | |
Drives: Mazda 3
12-05-2013, 08:14 AM | #516 |
Drives: '14 SWP BRZ Limited
May as well,
I don't have a BRZ/FRS yet but I'm doing research on them now and plan on buying in March/April. I'm looking at suspension setups and I'm getting a bit lost when it comes to camber setups. I'm coming from a s2000 which has some factory adjustment so I've never had to worry about it (my wheel setup works within factory adjustment at my ride height). If I want to run 18x9.5 +40 w/ 255/35's all around with a decent drop (not slammed) and I want the car to perform/handle well, what kind of setup would you recommend? I've been looking at the KW v3 and Tarmac 0/2 mostly. From my understanding I'd at least need something like the whiteline camber adjustment kit for the rear. The car will see mostly street driving with backroads twisties and I'll make it out to an autocross/track every once and a while but not terribly often. |
12-05-2013, 10:41 AM | #517 | |
Even without camber plates you'll be able to get plenty of camber. Just the cheap factory camber bolt will get you over -2 with KW or RCE coilovers. For the rear, rear LCAs or the WL rear camber bushing kit. I like the bushing but it's a pain to install and adjust. I'd recommend rear LCAs, maybe with the nonadjustable version of that bushing. - Andy |
12-05-2013, 12:37 PM | #518 | |
What kind of suspension did you run on the S2000? You don't necessarily need to have additional adjustability, depending on how you set up the FRS/BRZ. We don't run ANY additional arms, links, etc. on our shop car; we simply don't need them. |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
