Old 12-18-2013, 12:26 PM   #1
Titanmotorsports
Titanmotorsports's Avatar
Drives: Supra
Send a message via AIM to Titanmotorsports
MoTeC FT86
MoTeC is happy to announce the release of an M1 Package for the Toyota 86 2012 FA20D.
Currently compatible with the Manual Transmission versions of the following vehicles: Toyota 86, Subaru BRZ and Scion FR-S models from 2012 onward.
A licensed Toyota 86 2012 FA20D Package together with an activated M150 ECU and optional loom, combines to become a fully programmable replacement for the factory-fitted Toyota 86 ECU.
No rewiring is necessary with the optional loom, which plugs into the stock wiring harness using the original sensors and fuel system. All original functions are maintained
Works with all of the stock componentry, including:
Power steering
ABS
Stability control
Air conditioner
Dashboard
Adds powerful extra capabilities, including:
Turbo or supercharger control
Launch control
Traction control
Gear Shift ignition cutting
• Pre-configured physical settings for Engine Displacement, Fuel
Density, Stoichiometric Ratio, Fuel Pressure, and Injector
Linearisation, which allow for simplified engine start-up prior to tuning.
• Pre-configured control of OE coolant fans with 3 temperature
• Fully integrates with these original systems: Direct Injection, thresholds.
Stability, Dash, Power Steering, ABS, Air Conditioner, Purge • Pre-configured transient fuelling compensation using physical
Canister, and Alternator control. Cruise Control is not supported. Lambda Control is supported with optional
LTC and Bosch LSU4.9 Sensor.
• Pre-configured wheel speed detection via CAN from OE ABS
system, allowing gear detection via engine speed / wheel speed estimate.
• Pre-configured sensor calibrations for Original Equipment (OE) speed estimate.
sensors and engine triggers.
• Gearbox position detection via optional sensor.
• Pre-configured control of port and direct injectors with a
tunable balance table.
• Configurable boost control for a single turbo.
• Pre-configured reference mode for engine synchronization and • Configurable anti-lag for single turbo with Ignition Timing Limit,
control of 4 camshafts with tunable inlet and exhaust timing Fuel Volume Trim, Ignition Cut, Engine Speed Limit, Boost Aim
tables. and Throttle Aim tables.
• Pre-configured on-board knock control for each cylinder with 2 • Gearbox shift request via Up Shift Switch / Down Shift Switch
OE knock sensors and selectable center frequency. or Gear Lever Force sensor.
Contact me for more info
Sean@Titanmotorsports.com
Titanmotorsports is offline   Reply With Quote
Old 12-18-2013, 02:14 PM   #2
Visconti
Drives: 05 STi
Very Nice
Visconti is offline   Reply With Quote
Old 12-18-2013, 03:51 PM   #3
arghx7
Drives: car
Can you explain how the DI + Port fuel mapping and control logic works? On the most basic level: is it pulsewidth and fuel pressure lookup tables? Or does it calculate a fuel quantity and then figure out what injection is needed to get there?
How is the DI injector flow characterized with regard to pulsewidth and fuel pressure? How much tuning is going to be needed to get the high pressure fuel pump to control fuel setpoint accurately?
Does the system support multiple DI injections? How is the split between the two injections controlled and the start of injection? How does that relate to the port injection control?
How is the tip-in acceleration fuel handled in both port and DI injection modes?
The Following User Says Thank You to arghx7 For This Useful Post:
SkullWorks (12-18-2013)
Old 12-18-2013, 05:44 PM   #4
Titanmotorsports
Drives: Supra
As mentioned please contact Sean@titanmotorsports.com
Old 12-18-2013, 06:04 PM   #5
SkullWorks
Drives: SSM LT MT BRZ
Would it be too mch to ask that you simply make the info (as you understand it) public knowledge?
It is information that would benefit more than the person asking the question.
Old 12-18-2013, 06:14 PM   #6
Titanmotorsports
Drives: Supra
As i do not know the info, which im sorry. Sean knows the motec system more than i do, im still learning.
I will try to have him respond on the forum, but he works mainly with emails.
Old 02-25-2021, 02:24 AM   #7
pro_turbo
Drives:
i also bought this product from TItan..
recommended ECU
also recommended Seller
pro_turbo is offline   Reply With Quote
Old 02-25-2021, 02:11 PM   #8
gt7877
Drives: turbo frs
5570$ Just fo motec
gt7877 is offline   Reply With Quote
FT86 vs. RX-7 FD FutureFT86 FR-S / BRZ vs.... 148 01-05-2020 09:48 PM
Evasive FT86 Service & Maintenance Thread Discount Labor for FT86 Members Evasive Motorsports Southern California 423 10-01-2018 12:49 PM
Motec M1 Plug N Play FullBlown Forced Induction 89 05-09-2014 12:45 PM
FT86 new look Kimsey47 Site Announcements / Questions / Issues 5 11-19-2013 09:36 PM
What do you like other than the FT86??? Coconut Off-Topic Lounge [WARNING: NO POLITICS] 59 04-15-2011 02:23 PM
