Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
12-31-2011, 07:18 PM | #15 |
Drives: Some rust bucket
12-31-2011, 07:22 PM | #16 |
Seems like you're pretty familiar with brakes.
The JDM low-spec comes with ventilated fronts and non-ventilated rears, and the high-spec has ventilated discs for both. I think the FR-S comes with ventilated fronts and rears. Are ventilated much better? Do they cost a lot more? I think their reasoning is because the JDM low-spec comes with 16'' wheels instead of 17''. This means you don't need as much stopping power compared to the heavier 17'' wheels. It will also decrease cost. |
12-31-2011, 07:28 PM | #17 | |
Drives: 2009 BMW 335i
By Jeremy Cato, eHow Contributor Vented car brake rotor Your vehicle's braking system involves a fairly complex arrangement of parts. One of the most important of those parts is the brake rotor. This can be either vented or non-vented. Related Searches:
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma |
12-31-2011, 07:34 PM | #18 | |
Site Moderator
Drives: Stuff
Solids are just fine in the rear, but I'm good with ventilated as well. The S2000 uses solid rear rotors and it's just fine on the track. The rear rotors aren't much different on the low spec (although I haven't seen numbers, it seems logical that the WRX rear 11.3" solid units would be used, both seem to use the 11.6" WRX fronts). Both realistically should fit with 16" wheels, not every 16" probably but many of them. The larger wheel size will make brakes work harder but either brake setup will have the power to lock up the tires, and if you can lock up the tires than you have more than enough brake force. Whether or not you have large enough heat sinks (rotors) for repeated high speed stops is the question, and the reason for the larger vented brakes all around.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
12-31-2011, 07:35 PM | #19 | |
Site Moderator
Drives: Stuff
I would actually just remove and ignore that entire post, it's so unclear and potentially misinforming that it's not worth having. Oh, and tires stop the car, not the rotors :P (ok unless the wheels and tires have fallen off...)
-Dave
12-31-2011, 07:37 PM | #20 |
Yeah I noticed, I think that E-how just tosses pics up as representation
12-31-2011, 08:39 PM | #21 |
Very good info. Is this an accurate picture showing vented vs. non-vented rotors?
I'm guessing vented is on the left and non-vented is on the right. You can see slots on the right rotor. |
12-31-2011, 08:54 PM | #22 |
Drives: 86 GT
Good info guys.
I hope will be able to put BBK into a 16" aftermarket wheels. Just need to check out the local available tire selection. |
01-01-2012, 02:48 AM | #23 |
Site Moderator
Drives: Stuff
Yep
-Dave
01-01-2012, 02:49 AM | #24 |
Site Moderator
Drives: Stuff
A bbk will definitely not fit under 16s. The stock brakes will.
-Dave
01-01-2012, 03:25 AM | #25 |
Oops, I meant to say vented rotors on the left.
Similar Threads | ||||
Powder coating vs painting Rims | Giccin | Other Vehicles & General Automotive Discussions | 36 | 01-28-2015 07:44 PM |
More pix of blue 86 w/aero+ rims | Alfie | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-29-2011 08:17 PM |
Five-Axis rims? | blackknight.ktn | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-29-2011 03:23 PM |
What rims are these? | CyberFormula | Other Vehicles & General Automotive Discussions | 9 | 10-04-2011 05:27 PM |
Ferrari 458 style rims | CyberFormula | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 04-13-2010 11:20 PM |
