Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
10-04-2020, 10:11 AM | #1 |
Drives: 2014 Firestorm FRS
Need expertise advise, wrecked wheels
Hello,
I currently got into an accident and bent both my RPF 1’s beyond repair. They were 18x8.5 + 35 offset, matte black and unfortunately that size has since been discontinued. 2 out of 4 wheels/tires are still in good shape. What are my options? Trying not to buy all 4 new rims + Tires at the moment so I was thinking of doing a staggered set up. Currently the closest size I can get to the same wheel is 18x9 +40 offset. Would that work? Worried it might throw the ABS sensors. Thanks! |
10-04-2020, 11:48 AM | #2 |
LMGTFY
Drives: 13 FRS, 91 Miata
https://www.ft86club.com/forums/showthread.php?t=67345
Different sized tires can throw all kinds of stuff off on these cars. If money is an issue, find some stockers for stupid cheap and run those till you can get a proper replacement set, or buy all 4 now. |
10-04-2020, 11:50 AM | #3 |
When buying the tires, make sure the diameter (or Hight) are the same and the ABS will not care.
10-04-2020, 10:43 PM | #4 | |
Drives: jrsc_brz
when your fronts are different color than the rears, it looks ratchet/drift setup. dont like that. but when the lefts are one, and rights are another, 1/10 people notice you have 2 different color wheels. can you get an rpf1 in that size at all anymore, in a different color??
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
The Following User Says Thank You to HaXx For This Useful Post: | Ohio Enthusiast (10-05-2020) |
10-05-2020, 09:15 AM | #5 |
Drives: 17 Asphalt 86
For an additional cost I would consider having the replacement wheels powder coated black to better match what you have.
10-05-2020, 06:07 PM | #6 |
Drives: 2014 FR-S Monogram
Buy the 18x9s and use them on the rear with the 8.5s in front. Run a 245/35/18 tire on all four corners, the rears will have a very mild stretch versus the fronts but it will be barely noticeable. You won't be able to rotate, but it's the best solution short of buying a whole new set of wheels.
10-05-2020, 11:29 PM | #7 |
Drives: 2014 GT86
I'd rather try to get square width, other pair also 8.5, even if of different offset. Some offsets can be "fixed" using spacers. Would hate to get extra understeer from staggered setup.
Similar Threads | ||||
Just ordered a set of 18x9.5 +45 wheels, need suspension advise | stlgrym3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-16-2018 10:15 PM |
Need your expertise(clutch and tranny) | WatchmaN | Issues | Warranty | Recalls / TSB | 18 | 12-31-2014 08:32 AM |
Advise Needed Wheels | USMC -FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-03-2013 09:39 PM |
Made my drama on the FRS side, want some Subaru expertise and feedback. | alrashwa | BRZ First-Gen (2012+) -- General Topics | 30 | 01-15-2013 02:25 PM |
