08-31-2014, 06:17 PM | #856 |
That Guy
Drives: 2013 asphalt FRS MT
I laughed much more than I should have. :thumbsup
08-31-2014, 07:25 PM | #858 |
Drives: 2013 DGM BRZ
Whats the normal amount of boost that this kit puts out? Ive been looking everywhere and have yet to find a set "this is what it is" number. If someone could enlighten me that would be great.
"Don't ask me...I just work here"
08-31-2014, 07:29 PM | #859 |
Drives: Soon to be a BRZ
Saw the Jackson Racing rep state that it's 9psi with the 110mm pulley and can be increased up to 14 with a smaller one. I think it was in the original JR SC thread
"My other ride is a 175mph bus"
08-31-2014, 09:54 PM | #860 |
OK sweet. You would think when you google Jackson Racing Supercharger boost output it would show something other then just tech specs about the charger and give me actual outputs.
08-31-2014, 10:40 PM | #861 | ||
Drives: 2013 CBS BRZ
08-31-2014, 11:18 PM | #862 |
And what do you mean by unknown bonus.
08-31-2014, 11:19 PM | #863 |
You might expect that, but the answer isn't so specific. With centrifugal superchargers, boost depends on engine rpm. So you will get 9psi for a portion of the rpm range, but boost will always be 9psi at that rpm. If the given pulley will produce 9psi at 7400 engine rpm, then as revs are lower so is boost.
09-01-2014, 01:08 AM | #864 | |
PSI is one of those YMMV things. You will never see the same PSI everywhere, no matter what forced induction kit you go with. |
09-01-2014, 02:56 AM | #865 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
09-01-2014, 03:54 PM | #866 | |
Drives: Toyota
Y Last edited by Yui-Chan; 09-01-2014 at 04:12 PM. |
The Following User Says Thank You to Yui-Chan For This Useful Post: | CSG Mike (09-01-2014) |
09-01-2014, 07:41 PM | #867 |
Drives: Toyota
Here's some questions (after finally updating myself with and finishing this lengthy thread lol):
I know it hasn't been made official and introduced yet (the upcoming Stage 2 or Version 2 JRSC upgrade)...but: 1. Will it still be CARB legal? 2. If No, then can you easily switch the "upgraded" Ver2/Stage2 parts, back to the original Ver1 parts and CARB tune, for when Smog day comes? I know it hasn't been made official yet, but its obvious the key parts to improve power in the future upgrade update will include a smaller pulley (more boost), a new tune (CARB legal or not??), and maybe even a catless header and maybe a MAF or MAP upgrade. Which are all very easy parts to de-install, and revert back to the CARB/Ver1 parts, come smog day, fortunately. Fututre upgrade Wishlist: - Offer various JR Factory tunes with different header/exh configurations (EG: catless header with oem fp...catless header with catless fp...full catless system header, fp and catback..etc). CARB tune maps available on the side for people needing it on smog day. From what I've read so far, the JR CARB tune is quite impressive, which is why I am interested in more JR Factory tunes for diff header/exh configs. Not to mention making this kit completely plug-n-play - Smaller pulley option. |
09-01-2014, 08:05 PM | #868 | |
You can always revert to CARB form with the CARB tune. All you need to do is put in the time or money required to swap the parts and tune. Jackson Racing will not be releasing any additional tunes for various bolt-on setups. There are simply too many permutations. With just 5 header options, 5 overpipe options, 5 midpipe options, and 20 catback options, you're already at 2500 permutations. I'm just throwing out numbers; there are more than 5 of each of the above options. If you need a custom tune, then just go to the tuner of your choice, and get a tune. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Yui-Chan (09-01-2014) |
Similar Threads | ||||
Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
