Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
06-04-2021, 07:02 PM | #1 |
Drives: 2013 WR blue sport tech BRZ
BRZ Clutch clicking noise/tick
So I haven't found any answers on here describing my problem accurately and want to see what you guys think this noise is. It's definitely not the pedal making noise, it's clutch related. Here's a video of it.
Gonna try to get someone to help me out and take a look at it, but in the meantime I figured I'd check to see what you guys think. Clutch and assembly only have 15000 kms on it. Comes and goes when the car is running. Also the clutch needs to be fully released to get it to make the noise again. |
The Following User Says Thank You to Nfsundrgrnd For This Useful Post: | humfrz (06-05-2021) |
06-05-2021, 03:00 AM | #2 |
It could be:
* the clutch hydraulic system is low on fluid or has air in it * the master or slave cylinder is messed up * the clutch fork is dry * the TOB is sticking * the pressure plate is shot I'd suggest you bleed the clutch hydraulic system and replace the fluid with new fluid. I'll now refer you to our clutch expert @Ultramaroon for his recommendation. |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | Nfsundrgrnd (06-05-2021), ScoobsMcGee (07-01-2021) |
06-05-2021, 07:22 AM | #3 |
Thanks! I'll look into all of these options, very useful information!
06-06-2021, 12:33 PM | #4 |
Drives: 2013 frs base
Is the noise in the cabin or under the hood? If in the cabin, take out the clutch assist spring and see if the sound goes away.
06-07-2021, 01:09 AM | #5 |
It's coming from the clutch area underneath my car. I drove her hard for a couple days since then and the issue seems to have gotten better but not fixed.
06-07-2021, 01:51 AM | #6 | |
義理チョコ
That being said, It could be a couple things. A ridge could be worn on the quill where the TOB is hanging up. Or more likely, it's a flat spot worn on the main pivot of the fork. I had that. Poor design.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Nfsundrgrnd (06-07-2021) |
06-07-2021, 09:56 AM | #7 |
The flat spot on the fork sounds like a likely culprit.
Did you replace your fork? Or do you just keep driving with it? I don't think it's damaging anything at the moment so I'm sure I'd be safe to ride it out for a while. |
06-07-2021, 11:38 AM | #8 |
義理チョコ
I ground it off with a dremel. It's not a showstopper.
06-07-2021, 12:02 PM | #9 |
I might just do that haha
06-07-2021, 01:58 PM | #10 |
義理チョコ
Nice! There's a flat spot on the face of the pivot ball. I think the wear actually comes from vibration at that joint when the clutch is NOT being operated. The ball and socket lap together leaving a high spot in the middle of the socket. I ground a divot in that area and it has been great so far. That was in late summer of 2019 and I've only burned two and a half tanks of gas since then. We'll see how long it lasts.
06-07-2021, 02:15 PM | #11 |
Thanks for the info! Gonna see what I can do.
06-30-2021, 04:20 PM | #12 | |
The grab point seems very inconsistent when shifting, as in sometimes it grabs near the bottom and sometimes it grabs at the top. It also slipped 2nd gear for a split second when doing a quick 1 - 2 shift the other day. I know the clutch is good because it only has 20k kms on it and doesn't slip when flooring it in higher gears. It also makes a weird chirp noise when letting the clutch out on a hard shift. Almost sounds like the ac compressor chirp our cars are known for. Just trying to figure out what could be causing all these issues since I can't find similar issues mentionned anywhere. My two guesses is either something is failling somewhere in the line (slave, master or TOB) Or possibly my clutch diaphragm release spring is cracked. Any info helps! |
06-30-2021, 04:30 PM | #13 | |
義理チョコ
Someone posted it last week-ish and, unfortunately, I blew past it without subscribing. I strongly supect that it's relevant here.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Nfsundrgrnd (06-30-2021) |
06-30-2021, 05:02 PM | #14 | |
Tags |
click, clutch, noise, pedal, tick |
Similar Threads | ||||
Clicking noise while Driving stops when Clutch is pressed | Inteze | Engine, Exhaust, Transmission | 12 | 04-09-2020 01:07 PM |
Clicking noise from clutch when depressed/released? | BaeK | Issues | Warranty | Recalls / TSB | 29 | 02-10-2020 01:48 PM |
Clutch Pedal "Clicking" Noise on new BRZ | Shizuka | Engine, Exhaust, Transmission | 6 | 05-31-2019 01:57 PM |
Clicking / tapping sound + fuel pump noise + clutch grinding | Mikeez | Issues | Warranty | Recalls / TSB | 11 | 04-26-2015 11:19 PM |
LOUD TICK-TICK-TICK sound on right hand side | PoRco | Issues | Warranty | Recalls / TSB | 16 | 07-28-2014 12:55 PM |
