05-06-2020, 12:34 AM | #8975 |
Drives: 2017 BRZ
Measuring boost mechanically
For those who run boost gauges like the Defi, where do you guys measure the boost from?
I am currently running a MAP spacer with a nipple to measure it, but I'm kind of baited out by it.
Regular guy... Not so regular car
05-06-2020, 05:37 AM | #8976 |
Drives: brz 2017 hksv2
have you tried it yet? what values you re getting?
05-06-2020, 09:21 AM | #8977 | |
Drives: 2017 toyota 86
with 69mm pulley + wmi i get 13psi at redline, and get instantly 10+ psi pretty much any RPM i go WOT. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Regular (05-06-2020) |
05-08-2020, 01:34 PM | #8978 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
What differences, if any, are there between the Sprintex and the Cusco kits? I assume they are the same, just rebranded?
05-09-2020, 12:43 AM | #8979 |
05-13-2020, 04:41 PM | #8980 |
Just joined the flex fuel band wagon.
Running E40 + WMI, got another 3.3 degrees of timing from the E40. At about the same amount of timing now as full E85 but with better fuel economy, cooling, and less stress to the fuel system so still on stock pump/injectors with no issues. It was a pleasant surprise how much harder it pulls now, probably another 10-12whp if i was to guess. Fully maxed out the capabilities of the 210 system now. Guess it’s time to save for the 335 and a built long block. |
05-13-2020, 06:00 PM | #8981 |
Bout time. Not sure the 335 is worth it. My next move will be a turbo kit but for now I will stick with the 210
2013 Series 10 FRS #553
05-13-2020, 07:43 PM | #8982 | |
My goal would be 300ft lbs from 3500-7000rpm 320ftlbs at 5-5.5k rpm. 400+whp at 7k rpm. Assuming 210 69mm E85 dyno is 220ftlbs/285whp With head work, oversized valves and maybe cams should be doable. 100ftlbs/115whp more on this setup would be crazy. Thats like the same increase going from stock to the 210 with 69mm. If i could go back in time I’d probably turbo, but now I'm too invested. And the instant throttle response and low end torque is fun. Don’t think anything could rival the 335 under 5500rpm, or throttle response. Last edited by 86TOYO2k17; 05-13-2020 at 11:35 PM. |
05-18-2020, 08:45 PM | #8983 |
Drives: '14
https://www.ebay.com/itm/Vented-Plug...YAAOSwp1RZgljQ
Found this interesting listing on eBay. You won't have a dipstick if you use this on your unit.. Wondering if this would really help those who have oil consumption issues. |
05-18-2020, 08:57 PM | #8984 | |
Me and another member tried experimenting with something similar but we DIYed couldn’t keep the oil from spewing out. But this is probably much better. Also save your dipstick, use it when you want to check the oil level. Don’t need it in 24/7. As long as it doesn’t let oil leak out of the plug i see no downside in running it. Especially for only 20$. |
05-28-2020, 01:11 PM | #8985 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
There's a tiny allen head screw on the side facing the rear of the car in the middle lower area. I unfortunately stripped it as it's on there really tight and it was only something like a 2 for allen sizes, thus super hard to get turning if torqued too much to get loose. I don't have a picture but remember seeing one on here somewhere.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
06-01-2020, 10:49 PM | #8986 |
Well I might have found something that is holding on tapped thread for my Jon bond oil consumption breather... High temp blue locktite thread sealer up to 650f
06-12-2020, 12:25 AM | #8987 |
Drives: '14
So the connector that connects the bypass valve tube to the nipple broke. Cheap plastic.. had to get another one from Autozone. It's going to eventually break again. Anyone know where to get a quality replacement?
I didn't notice until now. God knows how long I've been driving with it disconnected. I didn't notice any crazy AFR's or fuel trims with it disconnected. Surely it would throw my AFR off because of the vacuum leak.. Question is how come I didn't notice any power less with it disconnected?! Last edited by kev0; 06-12-2020 at 06:58 AM. |
06-12-2020, 12:34 AM | #8988 |
You can brass replacements.
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
