Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-27-2020, 07:22 PM | #15 |
Drives: jrsc_brz
i dont know if ur dead set on more power, but coilovers and a more race inspired seat will make you feel like you are on a fast and furious special mission.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
04-27-2020, 07:26 PM | #16 |
Drives: Crapcan
04-27-2020, 08:20 PM | #17 |
Drives: 2017 toyota 86
Water methanol injection.
Methanol is almost identical to E85, the water portion adds increased cooling vs ethanol and especially regular pump gas, which allows for continuous consistent power pull after pull with no heat soak issues. Methanol has similar “octane rating” to ethanol but you are obviously using a lower % since you are spraying in addition to your normal fuel instead of replacing your fuel entirely. |
04-27-2020, 11:09 PM | #18 | ||
Drives: 2017 BRZ - WRB - PP
I was also not too familiar with the Billet Power Blocks, those are intriguing for a few more HP. Most of the info I've found was done pre 2017. Is there any data on the effect when compared to the revised intake manifold on the 2017+? I may end up just putting a few more dollars into aero, bushings, etc and go on a vacation. Idk if I'm ready to take the FI plunge. Decisions, decisions. |
04-28-2020, 01:18 AM | #19 | |
Not sure how much testing has been done on 17+ Aluminum manifold with the BPB. But the same principle and functionality still applies. You would need to research if the runner length changed from plastic manifold to aluminum manifold to really determine. But It works by increasing runner length to shift the power band down a little to meaten it up a bit. And with vvt tuning you can regain most of the top end so you effectively gain about 4whp for about 1400rpm of your peak power band 5400-6800rpm at the cost of about 2whp lost for the last 600rpm 6900-7500rpm. Still a total net gain since double the increase for double the time vs the decrease. You already have the 2017 4.3 FD ratio so less beneficial than if you had a 4.1 FD ratio but switching to a 4.44 or 4.56 is a great NA option, makes the car a little faster to top of each gear making it feel a lot faster. Weight reduction adds up and goes a long way. From a power to weight standpoint so not exactly the same as just increasing power. But going from say 2800lbs with 200whp to 2600lbs with 200whp would effectively be like giving you 15whp. Meaning 2800lbs + 215whp = same power to weight ratio as 2600lbs + 200whp. This effect is slightly enhanced when it is rotational mass IE lightweight wheels or willwood 4 pot bbk. |
04-28-2020, 01:31 AM | #20 | |
I'm going to keep looking into the BPB. I do a lot of secluded highway driving at 5am, so I'm often cruising at 85mph. Can't go any shorter on the gearing. I've already done a lighter battery, lighter wheels, lighter header, lighter spoiler. I'd like to keep some of the DD comforts, so there isn't a ton more to gain without going pretty extreme. The willwood brake kit would save weight vs the PP, but isn't cheap and hard to justify when I already have brembos. |
04-28-2020, 08:11 AM | #21 |
Drives: FR-S,GTI
04-28-2020, 10:56 AM | #22 | |
I would love to try one of those electric turbos, but not going there. |
The Following User Says Thank You to Ernest72 For This Useful Post: | imprezive (04-28-2020) |
04-28-2020, 11:19 AM | #23 | |
04-28-2020, 11:23 AM | #24 |
Drives: Bone stock
04-28-2020, 11:25 AM | #25 |
04-28-2020, 11:41 AM | #26 | |
Drives: Crapcan
Pet peeve of mine, but wtf does stage 2 even mean? It's like it implies there is a standard that nobody follows. Who decided what stage 2 is? Is my stage 2 the same as your stage 2? Do you have to have a stage 2 clutch if you are modded to stage 2?
04-28-2020, 11:52 AM | #27 | |
Rust bucket enthusiast
It can be dangerous, but honestly if someone is buying things without consulting others, they will learn that a "stage 2 clutch" from one company does not mean it is in any way comparable to another's. When their stage 2 eBay clutch slips and their stage 2 Exedy clutch does not, they'll learn to look for the torque rating and ignore the stage completely. The arbitrary staging behind a group of modifications will always be impossible to quantify unless an entire platform and its enthusiasts adhere to it. I'm sure you know this, but it also frustrates me and I had to find a productive way of venting. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | why? (04-29-2020) |
04-28-2020, 11:54 AM | #28 |
Drives: 2013 frs red
Similar Threads | ||||
2017 BRZ "sti performance package" worth it? | funeralpolis | BRZ First-Gen (2012+) -- General Topics | 5 | 06-02-2017 01:05 PM |
Perrin intake tube "worth it"? | ANTLAY | Engine, Exhaust, Transmission | 60 | 10-11-2014 06:41 PM |
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
SUBARU 4Pot Calipers "Bremboed" Direct Bolt On- SD, CA CHEAP! | virjose | Brakes, Suspension, Chassis | 32 | 07-12-2013 12:40 PM |
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" | JDMinc | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 04-17-2010 03:58 AM |
