03-17-2022, 09:06 AM | #2409 | |
Drives: '13 FR-S Firestorm
What are you swapping to? The whole TRD kit looks sweet.. Joining dark side? I just installed STI Rep kit & lowered mine on RCE Yellows. I've gone full subaru on my FRS lol |
The Following User Says Thank You to FSFRS For This Useful Post: | Wally86 (03-18-2022) |
03-17-2022, 11:17 AM | #2410 |
Drives: 2017 Toyota 86 (860 SE)
Baby got some new shoes yesterday.
03-17-2022, 09:06 PM | #2411 |
Drives: 2014 FR-S
@FSFRS I’m doing a bumper conversion to the 17+ 86 bumper with an added TRD lip.
Professional Car Breaker
The Following User Says Thank You to rbfr.s For This Useful Post: | Wally86 (03-18-2022) |
03-18-2022, 01:45 PM | #2412 |
Be Kind
Drives: 2020 86
30k service at 29726 today.
The manual says you have to remove the metal under pan and the fiber one to change the trans fluid but I found the fiber one being removed to be more than enough room. Verus rear diffuser by itself isn't enough to block the rear diff to change it's fluid either. I was surprised to learn the oem magnet on the diff sticks way out versus the trans magnet that is under flush with the plug itself. Air filter swap is super easy. Funny enough, most of the rest of the 30k service, I've actually been doing in the last few weeks leading up to the big fluid changes. Thanks again to the forum for instructions and advice. Air filter part number: SU003-06405 Drain plug gasket 12157-10010 Plug gasket SU003-03626 Drain plug gasket SU003-00122 Redline MT90 GL-4 Trans oil (3 qts for 2.3) Redline 75W85 GL5 Rear diff Gear oil (2 qts for 1.2) Rear diff torque 36.1ftlb Trans torque 27.3ftlb
03-25-2022, 06:22 PM | #2413 |
Be Kind
Drives: 2020 86
Aerocatch install will be happening in the morning after a little wash
(thanks to @Nitro22 for posting your hood latch setup so I can essentially copy it) EDIT: Adding a pic
The Following User Says Thank You to Wally86 For This Useful Post: | soundman98 (03-25-2022) |
03-28-2022, 02:32 PM | #2414 |
Be Kind
Drives: 2020 86
After throwing a CF hood on the car and then washing it... there are two areas under the hood that make me nervous for no good reason. I know the engine bay can handle the water that will come at it but... the MAF sensor wires are just below the opening and the oil filter mount collected a good amount of water before I grabbed the compressor to gently blow it out. SO
Solution No 1 for giant holes in hood: O-Ring, 70A Durometer, Round, Black, 3" ID, 3-1/2" OD, 1/4" Width This should keep the water out. Apparently perrin had a solution for this but no longer makes it. I sent them an email and they said they were looking to bring them back in new colors so hopefully this giant o ring is a stop gap until they make some billety goodness.
The Following User Says Thank You to Wally86 For This Useful Post: | Ultramaroon (03-30-2022) |
03-28-2022, 04:21 PM | #2415 |
Drives: 2013 GT86 fully standard
Its still winter here, so dirty roads and still risk of snow and freezing, and winter tyres on. But it didn't stop me from swapping in very low milage 2019 BRZ dampers and whiteline springs. I always disliked the damping characteristics of the 2013 dampers and these are much better over small bumps, much better ride even though it also got lowered(trimmed bump stops). Now ill need to sort new front ARB links which had to be angle grinded away, rust protection on these car is a joke sadly.
2013 GT86, fully standard daily and occasional track day car
The Following 2 Users Say Thank You to CedN For This Useful Post: | Ultramaroon (03-30-2022), Wally86 (03-28-2022) |
03-28-2022, 07:35 PM | #2416 |
Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to Cedric For This Useful Post: | Wally86 (03-28-2022) |
03-28-2022, 11:55 PM | #2417 |
has a funny hat
Drives: 2014 BRZ Limited
The Following User Says Thank You to pope For This Useful Post: | Ultramaroon (03-30-2022) |
03-29-2022, 10:19 AM | #2418 |
If this was my only enthusiast car i would definitely do the same, and buy one that haven't been winter driven. Keeping it from the salt makes it million times nicer to work on.
My last daily drivers have been Renaults, which are one of the best in the business at rust protection. They looked like new underneath compared to my 86, even though it had endured twice the mileage. Ive seen it on friends jap cars, but it was a bit of a shock anyway to get under my 86 😂
The Following User Says Thank You to CedN For This Useful Post: | Ultramaroon (03-30-2022) |
04-04-2022, 08:20 PM | #2419 |
Be Kind
Drives: 2020 86
Car wash goodness. Aerocatch latches installed
The Following User Says Thank You to Wally86 For This Useful Post: | ACT86 (04-05-2022) |
04-05-2022, 02:37 PM | #2420 |
Drives: Neptune Blue 2019 Toyota 86
Got the Eibach Sportline springs and 25mm front / 30mm rear spacers installed and had to do a little shoot. Over the moon!
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
04-05-2022, 06:08 PM | #2421 |
18s with 245/40s look so big definitely downsizing to 225 or 235 when these die |
04-05-2022, 07:50 PM | #2422 | |
Drives: 2014 Ultramarine FR-S
Should've gone 245/35/18 (~24.8") to get close to stock diameter (~24.7") if you still want the width of 245. 235/40/18 (~25.4") is still kinda big. 225/40/18 (~25.1) is the next closest option. |
Similar Threads | ||||
WRC Car: TMG GT86 CS-R3 | riyal | AFRICA | 8 | 11-19-2013 02:03 PM |
XXR 527 on GT86 | jesperswe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 10-27-2013 10:17 PM |
GT86 FOB KEY | SPEEDGOD | Canada Classifieds | 0 | 07-29-2013 10:17 AM |
GT86 OEM Option Pin Stripes (anyone done this to their 86/GT86/FRS/BRZ)??? | jbsali | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-28-2013 11:10 PM |
MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) | RadOnc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-23-2012 08:42 AM |
