#3067 | |
Drives: 2017 BRZ
#3068 |
Drives: Many
What seat did you use? I couldn't really get either Buddy Club or PCI bracket to work with my Sparco Evo II. I think the wider seats like that just require a custom fabbed bracket.
#3069 |
Drives: 2013 FRS
So I'm seeing both options advocated in different threads and I'm wondering if there is a consensus among STX racers on this matter...
Pedal dance or button press for racing? I'm new to racing the twin and so far my limited experiments have indicated that the long button press allows me to drive well beyond the fast angle of slip without detecting any electronic assist and also that the brake bias seems to be much better with the pedal dance. I supposed the preference is a matter of if one's braking techniques tend to trigger ice mode? If not then go pedal dance but if so then go long press? |
#3070 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The long press method still leaves the electronic diff-assist active, but it almost never intervened when I ran in CS trim last year. (Twice over the course of the whole season IIRC) The long press method leaves EBD active which suits me well.
The Pedal Dance apparently kills the diff assist *and* EBD. |
#3071 |
Drives: 2013 FRS
Oh okay. I had been under the impression that the long press left traction and stability control functional to a minimal extent. That's good to know.
#3072 |
Drives: 2022 GR86
It's also different for 2017 cars (button functions). All I use on my 2017 is the button press (mode 4). I used pedal dance on my 2013 FRS.
#3073 | |
Low-Buck Ramp Truck
Drives: 2016 Scion FR-S Release 2.0 #502
https://gspeed.com/product/brzfr-s86...ro-seat-mount/ I believe there’s also a thread where they used the evo II with this mount. |
#3074 | |
Drives: 2017 BRZ
#3075 | |
Drives: Many
I may buy another seat to try it out, but for now I replaced the old Evo 2 in one of my other cars. |
#3076 | |
I used it for awhile but stopped, as mentioned it disables multi-channel abs so if you tap the brakes mid-corner to settle the car with pedal dance active it won't be nearly as effective as doing the same with the long-press, the long press will also give you better stopping power when trail braking while pedal dance mode will release brake pressure due to an unloaded wheel. The flipside is with the pedal dance it's super easy to put weight on the front of the car and get rotation under braking, if you're struggling to get the car to rotate on corner entry (and you've already tried maxed out front camber) it might be a useful tool. Maybe if you've got equal spring rates front and rear it'll help there. If you're getting ice mode with pedal dance adjust your braking, you don't need to be so abrupt on the pedal, it can be driven around and you can brake just as hard in a straight line as without pedal dance. I went back because I felt that the only advantage was corner entry rotation while losing how effective the brakes can be in adverse conditions (poor grip, too late on the brakes, or mid-corner) and after testing the long press again I realized I was happy with corner entry without the pedal dance. It'll be mostly a driver confidence/preference thing imho. |
#3077 |
Drives: 2013 FRS
Thanks for the responses on this. The Dixie tour in March will be my first event in the car and I'm thinking I'll just go with the long press without having had much opportunity to test out the differences for myself.
#3078 |
Drives: 2013 Satin White Pearl BRZ
#3079 |
#3080 | |
Sent from my Pixel using Tapatalk |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
