Old 01-24-2018, 02:53 PM   #3039
Racecomp Engineering
Originally Posted by oinojo View Post
Swaybars are a speed sensitive device in terms of rate, springs are not - they are linear.
What do you mean by this? I think I'm misreading where you're going with that...
- Andrew
Old 01-24-2018, 04:02 PM   #3040
cjd
cjd's Avatar
Drives: 2017 BRZ
Thanks, right about where I thought the swaybar would need to go. Either I'm good at guessing, or punched numbers into a spreadsheet and interpreted it reasonably well...
I imagine the overall ride could improve in some use cases with the greater spring rate spread - there's a section of highway I encounter every time I head up to Milwaukee where the car starts to feel incredibly unsettled... it bobbles really oddly front/rear. I'll have to add a few more parts to the bin later this year and try it out I think. First I have to get the parts I already have on the car... and wait for a few items to even show up.
Old 01-24-2018, 06:39 PM   #3041
A BRZ with 5 kg/mm front springs + Perrin 22mm front swaybar on soft would have more front roll resistance than a BRZ with 7 kg/mm springs and an OEM 18mm front bar. I think an 8 kg/mm front spring + OEM 18mm bar brings them fairly close.
Either can work well with the right set-up...
From memory, a 16mm rear bar gets you something like a 1.0 or 0.5 kg/mm increase in rear roll stiffness vs OEM 14mm bar.
- Andrew
Old 01-24-2018, 07:31 PM   #3042
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
yes. swaybar is important and thankfully the aftermarket has a vast amount of bars available to meet the needs. I used a Perrin 22mm on full soft and MANN Rear bar on Stiff. Put power down like a champ... oh yah and a STX tuned OS Giken LSD
Springs were 280/504.
504 rear springs and bar on full stiff? You would think it would be hard to put down power......I never had the Giken on either of my twins though
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 01-24-2018, 07:33 PM   #3043
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Simmons
The Mann Engineering bar is smaller then stock
Old 01-24-2018, 07:47 PM   #3044
Simmons
Simmons's Avatar
Just looked it up, now it makes sense.
Thanks
Old 01-24-2018, 08:00 PM   #3045
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
Thanks
Just enough rear bar to get around the slow corners. I hated no rear bar when i tried it.
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
Old 01-31-2018, 09:40 AM   #3046
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
What seat bracket are people using?
Simmons
I have this coming in. I'll post how I like it when I get it installed
Sent from my Pixel using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 02-01-2018, 12:15 PM   #3047
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I need to get some new 200TW tires for the upcoming season. Are the 71R's still the top tire for STX? Also, what's the consensus here between the 245/40/17 and 255/40/17? I ran the 245's last season and sometimes had issues hitting the rev limiter in 2nd gear. Was thinking the 255's might give me some extra top end so I won't have to upshift in some of those fast finishes. Just not sure if it'll feel bogged down trying to dig out of corners or not.
smg1138 is offline   Reply With Quote
Old 02-01-2018, 12:51 PM   #3048
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
2nd gear limiter is a HUGE PITA for me as well, but from everything I've been told, 255 isn't worth it apparently.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 02-01-2018, 01:38 PM   #3049
strat61caster
strat61caster's Avatar
Lots of people seem to like the BFGRS 1.5, I'd give them a shot as my next tire if there isn't some new flavor of the month. Nexen is the oddball choice that some people seem to get good results out of, but it seems hit and miss. Reports are the Falken's aren't as quick as BFG/Stone.
ineedyourdiddly
Old 02-01-2018, 02:44 PM   #3050
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
You can be fast on the Bridgstones and BFGs, but it comes down to driver preference. People tell me the Nexens might be slightly off pace from the Bridgstones and BFGs. They behave like the BFGs but will heat up quicker, which may or may not be bad for you.
Accelerating out of low speed turns will probably be noticeable with 255s. If you had a 2017, 255s would be worth trying. Also, are you tuned?
A tune would help that
Raise the rev limiter a bit and have the RPMs be held at the rev limiter.
G_Ride is offline   Reply With Quote
Old 02-01-2018, 03:27 PM   #3051
justinco
justinco's Avatar
Drives: 2022 GR86
I've run both 245 & 255 on my 2017 BRZ. As well as both tires, Rival S 1.5 and the RE71R. I much prefer the 255 size. Couple more MPH in 2nd and with 7850 limiter it was good to go. In contrast, I ran the 245 the entire time on my FRS.
The tire make is pure preference on how you like the feel, both equally as fast IMO. I ran the Rival S 1.5 for most of last year, but may drive the RE71R again this year. Mostly because of its ability to work sooner/better in cooler weather. The slower heat up (of BFG'S) caused me some issues at a couple National events last year.
justinco is offline   Reply With Quote
Old 02-01-2018, 04:15 PM   #3052
smg1138
smg1138's Avatar
I've got a 2013 FRS and am currently using the OFT UEL Stage 2 tune. I didn't realize it could be edited to hold the RPM's at the rev limiter. Right now it cuts off power if I don't upshift soon enough after hitting redline.
Search this Thread:
Advanced Search
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
