#239 |
@KDad2 here is def for A00D rom with P0420, just unzip
read romraider tips link below http://www.ft86club.com/forums/showthread.php?t=79152 , |
#240 |
Drives: Brz
Just flashed the V4. Got weird bucking problem at low engine load just after startup. I did'nt reflash the previous V2 rom yet but if anyone can take a look at my log. Here's my analysis so far
- It shows -29 STFT but as soon as I touch the throttle pedal (2%), STFT jumps straight to 0 and AFR drops to 11.25. - It changes from Fuel System Status 2 to 4 as soon as I give any throttle. 2% throttle normally won't change to Closed loop - The problem will resolve itself when the car heats up a little bit but I can't get any power from the engine while it's doing that. - The problem is reproducible. It did not do it on 1st start after flash but after 3-4 runs. Now it does it pretty much every time the engine is cooled down. - AFR tend to stay at 11.25 for much too long. When bucking lessens, the AFR stays near for a couple minutes. It looks like it comes back to regular values as coolant heats up. - When coolant is up to 160°F, all seems pretty normal Can it be the upstream O2 sensor that's going bad? https://datazap.me/u/robzz/16-v4-02c Thanks! |
#241 |
Drives: 2017 Subaru BRZ Limited
Noobie question, once the tablet is married to your car, you do not need to perform the READ process again right? if i need to update the stage1 flash to a stage2 all i have to do is connect the tablet and do the WRITE operation of the appropriate tune file, correct?
#242 | |
Drives: BRZ SWP Limited -6MT
#243 |
Drives: 2017 Subaru BRZ Limited PP
Got a 17 brz with mxp sp exhaust and jdl front/mid pipe and have the v4 installed. Felt good at first but seems like my car is feeling sluggish now. Even just put in e85 for the first time and car doesn’t feel much faster. Any ideas why?
#244 |
Drives: frs
Let ecu to learn new parameters
#245 |
saw Shiv updated the OFT download page with the new v4.02 stage files. i wonder if those support K00D (2017 AT)? i emailed him already waiting for reply.
#246 |
Drives: scion fr-s
does any one know if where any changes from 4.01 to 4.02 tune ?
#247 |
#248 |
Drives: frs
#249 |
Drives: 2017 860
loaded OFT stage one tune on my 2017 860 and all is good . CAL was K00C
2017 Toyota 860
#250 | |
Drives: 14' FRS
anyone every has this problem with rom raider? just got a blank installation screen where it supposed the desktop shortcut option.
#251 | |
http://assembla.com/spaces/romraider...C3-windows.zip Then just extract it where ever you want and then double click on RomRaider.jar. This assumes you have JRE installed already. |
#252 | |
Huge E85 fan!
Drives: 2016 Scion FRS
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Software Tuning | 130 | 08-25-2020 07:29 AM |
| The latest EU/AU OFT tunes (D00G) don't come with launch control | jamesev93 | Software Tuning | 4 | 03-12-2018 04:14 PM |
| Openflash FLEXFUEL OTS Tunes! | Shiv@Openflash | Engine, Exhaust, Transmission | 3 | 08-27-2016 02:04 PM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 06:29 PM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
