FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
#15 |
#16 |
by its very nature you cant see contact patch. Patch shape will change but the size wont
#17 | |
Drives: anyone seen my steering wheel?
A tire is basically an air spring, therefore as long as the spring rate is the same ( which may or may not be at different PSIs) then the size of the contact patch will be the same. |
#18 |
Registered you sir
Drives: 99 impreza coupe
Lol at the guys who don't think larger tires have larger contact patches. Just keep on keepin on I guess.
#19 |
Drives: 2006 Subaru
#20 | |
Drives: Lexus IS300 Sportcross
Wider tires do not have larger contact patches given the same air pressure is used. Change in tire width only changes the shape of the contact patch, as long as the air pressure in the tire stays the same. Read this article. |
#21 |
Drives: 2006 Subaru
Lol... how about some real life experience. I can go blog an article on bigfoot. Doesn't mean he is real too.
#22 |
Kuruma Otaku
Please explain what real life experience we can use to evaluate contact patch area.
Because titanium. |
The Following User Says Thank You to Dimman For This Useful Post: | fatoni (05-20-2012) |
#23 |
#24 |
#25 |
Kuruma Otaku
Well I would love to be able to objectively measure my own contact patch myself, too.
Because titanium. |
#26 |
Registered you sir
#27 |
Kuruma Otaku
Way ahead of you. Heard of a 'polar compensating planimeter'? Now just trying to figure out a fast and convenient method to adjust camber and move large amounts of weight around...
Because titanium. |
#28 |
That will never work. You have to build a garage with a basement, then get some engineered glass to drive the car over so that you can look up and measure from the bottom. I mean really, why do stuff the cheap way when you can spend loads of money to get the same results?
Finally Got Mine...Yep Another One of These Threads! | kmbkk | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-25-2012 12:49 AM |
