Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 04-17-2019, 02:04 AM   #1
kyle32dean
Drives: 2013 Subaru BRZ (silver)
Tach Gone Crazy! Need Help
Hello everyone, I am super new. Just bought my BRZ and this has been a dream car for a long time. It is a 2013 BRZ with manual transmission. The issue I have been having is that about 50% of the time when I start the car up the idle RPM reads really high (like above 4500 RPM). Its idling where it should be but it's reading very high. As I rev it up it continues to climb way past redline and sometimes around to the ODO. I have been doing a lot of research and can't find anyone that is having the same issue. Also the other half of the time when it reads correctly it seems to be dead on. It seems strange that none of the other gauges are messed up at all. IDK what to do. please help.
The first pic is at idle and the second pic is about mid rpm. (obviously not 12,000)
kyle32dean is offline   Reply With Quote
Old 04-17-2019, 08:32 AM   #2
msaikhan
Drives: frs
i'm gonna take a guess on this.
I think the needle is just misaligned or loose from it's mounting.
You can probably take it apart and align the needle.
or just replace it as a whole assembly.
msaikhan is offline   Reply With Quote
Old 04-17-2019, 12:25 PM   #3
Welcome to the group!
Oh, I hope the engine isn't running at the indicated RPM?
Assuming it's not, I reckon a tune-er or the dealership should take a look see and see what is whacked out.
Or you could try disconnecting the battery for a minute and hook it back up, to see if the ECU will right itself.
humfrz is online now   Reply With Quote
Old 04-17-2019, 12:57 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Do the RPMs stay high all the time after you start the car or settle later? Does turning car off/on fix it?
Connect an OBD2 cheap adapter and see if the RPMs show correctly on the adapter vs. the cluster. If that is the case, you probably need a new cluster (ECU output is the right RPMs but the cluster is not delivering them right).
I rule out a misaligned needle because in that case you'd have a faulty RPM reading all the time, not 50% of the time.
If it's not isolated to the cluster, you have an electrical problem and those can be a pita to find.
Old 04-17-2019, 01:22 PM   #5
BirdTRD
analytical mooncalf
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
There appears to be tool marks above the speedometer so I would suspect that cluster has been out for one reason or another. You may want to look into that, maybe there's a loose connection back there.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Sportsguy83 (04-17-2019)
Old 04-17-2019, 06:56 PM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Most modern clusters are on the canbus, so it's possible to read internal faults, command the stepper motors and test display segments.
Checking that would be my initial instinct.
tach starts below 0 aquaman Electronics | Audio | NAV | Infotainment 17 07-01-2016 02:47 PM
Crazy Good Deal or just Crazy MJones_RB Subaru BRZ General Forum 31 05-06-2016 03:22 PM
HELP: Need Tach Signal!! Lil Abner Electronics | Audio | NAV | Infotainment 39 02-24-2016 09:59 PM
Cant see the top of my tach... MadFRS Scion FR-S / Toyota 86 GT86 General Forum 31 07-29-2013 04:11 PM
BRZ tach to FRS? lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-01-2013 03:48 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
