Old 11-06-2024, 08:17 AM   #155
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
My take is the oil cooler really comes into its own if you plan to push hard for more than 3-5 laps in a row. If you're happy enough to either pit in or do a cool down between push laps you shouldn't have much issue keeping temps in a safe window on a NA car. Can't speak to anything beyond stock power levels
I been tracking without an oil cooler for 2 years now and never seen issue with my UOA temps hit 240-255. I noticed at Oulton oil temp was sorta self regulating due to the longer straights.
270 does seem high but your UOA seems good. So unless you start seeing some sort of thermal runaway you're probably fine without one.
By the way thanks for sharing the report !
Oh all this is assuming you monitor oil pressure and those are also in a safe window at these temps. Which has been the case for me running 5w-30
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
Code Monkey (11-06-2024)
Old 11-06-2024, 03:26 PM   #156
Code Monkey
Drives: Subaru BRZ
Originally Posted by gnarjunkie View Post
What oil weight were you running?
Motul 300V 5W40
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
villainous_frx (11-07-2024)
Search this Thread:
Advanced Search
2017 Subaru BRZ hpde build Code Monkey Member's Car Journals 207 04-18-2022 11:11 AM
2022 BRZ JDM Spec build at HKS USA for SEMA2021 143 BRZ Second-Gen (2022+) -- General Topics 5 02-14-2022 01:27 PM
redSerpente’s HPDE/86CUP Street build redSerpente Member's Car Journals 10 04-26-2021 07:50 PM
LS3 HPDE / Time Attack Build RavioliG Member's Car Journals 17 02-11-2018 04:56 PM
86_Freak - Build for DD/C Street/HPDE duties 86_Freak Member's Car Journals 3 03-07-2016 10:15 AM
