Old 05-20-2016, 01:02 PM   #2549
Frs909
Drives: 2013 Turbo FR-S Java Pearl
add me to the list please and thanks!
http://www.ft86club.com/forums/showthread.php?t=106007
Frs909 is offline   Reply With Quote
Old 06-14-2016, 11:28 AM   #2550
robotichobo
Drives: 2013 Hot lava Two-tone FRS
Just bought a 2nd hand kit. The previous owners bought the car with turbo installed, but said that "it was way to much power " for them. All I need is a turbo manifold and I should be good to go!!
robotichobo is offline   Reply With Quote
Old 06-14-2016, 03:12 PM   #2551
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Hey @robotichobo just give us a call and we can help make your kit complete.
FullBlown is offline   Reply With Quote
Old 06-16-2016, 01:10 PM   #2552
robotichobo
I will definitely give you guys a call. I was planning on taking pictures of what I have, so that it can make it easier for us to discuss what exactly I need. I want to make sure that I have all my ducks in a row before I rip everything apart.
Old 06-26-2016, 12:21 AM   #2553
Eazy-V
I finally got my FBM turbo kit installed with GTX2867R. The wastegate is making 8.5psi, so I was able to get it tuned at the 8.5psi with 91 octane and stock injectors/fuel pump below 80% duty cycle.
I'll probably be upgrading the injectors/fuel pump later and be using 94octane/ethanol to E85, so what psi do you think the stock engine can handle?
Eazy-V is offline   Reply With Quote
Old 06-26-2016, 10:49 AM   #2554
Infinity
Drives: 2016 Scion FR-S
How does the powerband on the FBM kit with a small GTX turbo compare to the Full-Race kit with an equivalently sized EFR turbo?
Infinity is offline   Reply With Quote
Old 07-06-2016, 03:01 AM   #2555
extreme-86
Drives: 86, Nissan 200SX, Honda Civic
What kind of numbers have you made and on what fuel ?
extreme-86 is offline   Reply With Quote
Old 07-06-2016, 11:17 AM   #2556
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Congrats and thanks for the support! Our kit comes with injectors and fuel injectors. Why did you guys tune on the oem parts?
Old 07-06-2016, 08:33 PM   #2557
Eazy-V
No numbers yet, I just had it street tuned for a map 1
Old 07-06-2016, 08:38 PM   #2558
Eazy-V
It was just due to time contraints and did a street tune with stock wastegate spring of 8.6psi, which stock injectors handle fine.
I'm planning on finally getting the fuel pump injectors installed end of this month then doing a higher tune.
Btw, since I have not dyno'd mine yet, what WHP do you think 8.6psi is getting?
Old 07-09-2016, 07:53 PM   #2559
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Springs or reported by your boost gauge? I'm running a 7psi spring but my AEM failsafe reports a solid WOT of 8.1psi
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 07-10-2016, 02:30 AM   #2560
Eazy-V
The spring is 8.5psi with Greddy Profec with a 0 setting is reporting 8.6psi
Old 07-10-2016, 09:55 AM   #2561
GsxrMe
GsxrMe's Avatar
Hm... are you running from intake manifold or turbo inlet?
2014 Subaru BRZ
Old 07-28-2016, 04:53 PM   #2562
DHitHim
Drives: 2015 CWP Limited BRZ
Can someone please send me the installation manual?
DHitHim is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
