Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 11-10-2019, 10:59 PM   #1
zakman16
zakman16's Avatar
Drives: Man
Send a message via AIM to zakman16 Send a message via Yahoo to zakman16
Steering wheel locked car won’t start
my steering wheel is locked and wont unlock and my car wont start.
Every thing works inside and out of the car no fuses or relays are bad the starter,battery and key fob all work fine but the car still won’t even attempt to start just goes right to accessory, and I can hear the fuel pump turn on does anyone know what would cause this or how to fix it?
It’s been at a dealer for a week and they dint know what’s wrong with it or how to fix it and are waiting in Subaru tech support to figure it out
zakman16 is offline   Reply With Quote
Old 11-10-2019, 11:31 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So, just to be sure, you can turn the key all the way to "start"? And nothing happens?
Old 11-11-2019, 01:19 AM   #3
zakman16
zakman16's Avatar
Drives: Man
It’s a push button cause it’s a brz but yes if I push the button it goes to accessory and won’t attempt to turn over and the wheel will not unlock no matter what I do and the dealer can’t unlock it either
The Following User Says Thank You to zakman16 For This Useful Post:
Spuds (11-11-2019)
Old 11-11-2019, 02:24 AM   #4
alan.chalkley
Drives: 4wd zooks
Did you try the spare key fob? Auto or manual car?
They can do weird things when the fob battery is weak!
The safety switch on the manual clutch pedal?
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
Spuds (11-11-2019)
Old 11-11-2019, 02:56 AM   #5
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I'm suspecting weak fob battery of clutch pedal switch.
Spuds (11-11-2019)
Old 11-14-2019, 01:42 AM   #6
zakman16
zakman16's Avatar
Drives: Man
It’s a Manual car have already replaced the key fob battery’s and the clutch safety switch neither fixed it
NYNOMAD (11-14-2019)
Old 11-14-2019, 06:08 AM   #7
alan.chalkley
Drives: 4wd zooks
Use a multimeter to double check the clutch safety switch and the attached wiring.
Also use a multimeter to check every fuse in the car.
And make sure the new fob battery is good and is seated properly.
BirdTRD (11-14-2019)
Old 11-14-2019, 06:11 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
WTF, you have to insert a key into an ignition to start the car.. what are you driving? Something from the 80's??
Old 11-14-2019, 07:25 AM   #9
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Also make sure you also check the 2 in the fuse block assembly at the + battery post.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
alan.chalkley (11-14-2019)
Old 11-14-2019, 10:24 AM   #10
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
Pull the tension out of the steering lock!
NVM, didnt read. Happens all the time though.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 11-14-2019, 10:05 PM   #11
zakman16
zakman16's Avatar
Drives: Man
I visually checked all the fuses and relays and switches some around with ones that were similar I didn’t use a multi meter tho. And The dealer said there were fault codes linked to the ecu and it not communicating properly so I got a used ecu of a guy parting out 13 brz manual like mine and I’m having them recalibrate it to my car, hopefully this is the issue
**quick update changed out the ecu still doesnt start...
Old 11-20-2019, 04:51 PM   #12
wparsons
wparsons's Avatar
If the steering wheel isn't unlocking, it sounds like an immobilizer issue?
Was the new ECU programmed to work with your cluster and key?
flickr
Old 11-21-2019, 04:44 PM   #13
zakman16
zakman16's Avatar
Drives: Man
yes it was, both keys also work fine and the dealer programmed the ecu them self, if the immobilizer was the issue how would i know/ is there a way to bypass it to get the car to start?
Old 11-21-2019, 04:46 PM   #14
If there was it would totally suck as an immobilizer.
DandoX (11-21-2019), Leonardo (11-21-2019), spike021 (11-21-2019)
wheel locked, won’t start
Blue carbon steering wheel and steering wheel trim... installed! Pointmutation Cosmetic Modification (Interior/Exterior/Lighting) 15 02-07-2017 12:20 AM
Steering wheel locked Towed to dealer kmac_brz Issues | Warranty | Recalls / TSB 81 11-17-2015 03:33 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Steering wheel locked no start kmac_brz Issues | Warranty | Recalls / TSB 1 07-08-2015 11:35 PM
When doors are locked manually the car won't start whataboutbob Electronics | Audio | NAV | Infotainment 9 10-14-2012 12:10 PM
