Old 07-13-2012, 01:35 PM   #281
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
I figured I'd try what others have tried. I added about 6-7oz of 2T (Lucas Synthetic 2T) today when I filled up. If you do a little math 128oz/gal and 13.3gal tank, 8.5oz would be 200:1 (or close enough), so 7oz is like 243:1. I kid you not... no chirp immediately noticeable. Will moitor it and keep track tho, but the bottle of 2T will stay in my trunk for now (spare removed,so it's under the trunk floor with my quick detailer, jumper cables and microfibers).
Kwaziekeller is offline   Reply With Quote
The Following User Says Thank You to Kwaziekeller For This Useful Post:
Hanzo (07-13-2012)
Old 07-13-2012, 11:30 PM   #282
sierra
Drives: Skoda Yeti DSG diesel 4x4
Well done!
See if you think it's quieter, smoother and using a bit less juice too?
sierra is offline   Reply With Quote
Old 07-17-2012, 06:02 PM   #283
Kwaziekeller
Originally Posted by sierra View Post
Well done!
I have to admit, it seems quieter, smoother and so far I've got about 250mi to this tank (with about 3/8 remaining). Could all be placebo effects, but it does not chirp anymore. I plan to use less and less 2T until I find a sweet spot. Going to measure it out before hand as well. It's hard to get an accurate measurment from the markings on the side of the bottle. I'll try 5oz next time, then 4oz and so on, until I find it chirping again, then I'll know the minimum.
Old 07-17-2012, 11:49 PM   #284
sierra
Someone's already tried 500:1 and it worked then another tried 1000:1 and that worked too.
I mentioned the smoother, quieter and better mpg because that is the general opinion when added at 200:1, it's certainly been my experience.
The gain in economy will certainly pay for the 2T used + a bit more for the slight inconvenience.
They used to have a dispenser at the pumps with Redex upper cylinder lubricant. I can remember my dad always put a couple of shots in the tank of his motorcycle/side car combo when he filled up. It's time they brought that back with ethanol, as an option or better still, add it to the fuel.
Not Redex, i'm sure there's much better these days, especially the high tech 2T stuff.
Old 07-18-2012, 12:01 AM   #285
fistpoint
Drives: Supercharged Golf Cart
Chirptastic!
Thanks for your ongoing efforts...
fistpoint is offline   Reply With Quote
Old 07-18-2012, 05:54 PM   #286
W2
W2's Avatar
Drives: Firestorm FR-S
Noticed this noise for the first time today pulling into my drive way. I have about 1500 miles on the car and I had just filled up on my way home from work with Shell 93. I had been using Shell since new and never noticed an issue but put Sunoco in for the fill up last week but don't recall the noise starting then. I'll see if the noise goes away as I start using this new tank full of Shell gas.
If worse comes to worst I have more 2-stroke oil than I need right now. Thinking some Maxima Caster 927 should give the exhaust a nice scent.
W2 is offline   Reply With Quote
Old 09-13-2012, 08:45 AM   #287
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by Suiris View Post
Unfortunately I'm not going to be able to get the case # right away but I can tell you what parts they ordered...
SU003-00328 PMP AY-FUEL.H PRS $1302.00
SU003-02187 O RING-31.5x2.0 $6.78
SU003-00347 GSKT-FUEL PIPE $9.44
All on "Special order".
I'm pretty sure the dealer is accurate is saying Scion is aware... I mean, would Scion REALLY authorize a warranty repair of this cost (parts/labor) simply from visual inspection?
And we'll find out if it fixes after the repair...
So this was back in June, did this fix the cricket ranch?
Spartan65 is offline   Reply With Quote
Old 01-23-2013, 08:55 AM   #288
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Chirping since Day1. Chirping stops after 1800miles. Fuel used are 93,95,97,100 octane.. no more chirps even in super hard driving. IT JUST STOPP
Margovincent_22x is offline   Reply With Quote
Old 01-25-2022, 09:40 AM   #289
Benedict
Benedict's Avatar
Drives: 2019 Subaru BRZ greddy turbo kit
Originally Posted by robo_robb View Post
Thanks for the input guys. I'll have the dealer look at it.
I'll keep you guys posted.
I'm a visitor from the future
not sure if you still have the car, but the ticking is 100% normal. I drive a turboed 2019 BRZ and it makes the exact same noise. Same noise as my first 2014 FR-S. Its the direct injection system shooting fuel into your engine. I asked a "Subaru specialist" about it when I was getting my car tuned. As far the squeaking/squealing goes, that's probably a problem. I have a chirping noise from a recalled fuel pump, but my vin is out of range so :/ can't get a replacement right now.
hope this helps for the people who were concerned and anyone this "problem" affects in the future.
Benedict is offline   Reply With Quote
Search this Thread:
Advanced Search
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
