GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
02-22-2022, 02:28 AM | #1 |
Drives: '04 STi, '12 Mazda 3 Hatch
Lightest Stock Size Wheels
I'm looking for the lightest wheels with the exact same width and offset as the stock 17s. Feel free to list 18s too for anyone looking for those. This doesn't seem like a difficult find but searching through old posts some wheels are no longer available and others are 8" wide or slightly different offset. Coming up empty searching retailers too. Am I being silly wanting exactly 48mm offset?
I just want bronze wheels that are lighter than stock but don't change the tire shape or suspension geometry. Last edited by Lelandjt; 03-10-2023 at 01:02 PM. |
02-22-2022, 02:43 AM | #2 |
Drives: GR86 RC
Rpf1 17x7.5 et48 silver 6.93kg 3797758048SP
Rpf1 17x8 et45 gold 7.1kg (tyre rack), 7.3kg (oem brochure) 3797808045GG Tc105x titan 17x7.5 et45 6.8kg OZ Alleggerita HLT 17x7.5 et48 7kg W0182320176 BBS RF 17X7 et48 6.4kg BBS RF 17X7.5 et48 6.6kg Ce28n 17x7.5 et50 6kg Ce28sl 17x7.5 et48 6.8(unconfirmed)kg Ssr gtf01 17x7.5 et48 7kg (potentially discontinued?) Sgd630 Advan tc4 17x7.5 et45 7.5kg sgd537 stock is 7.5 et48 so i exercised some +/- hahaha. your best bet is OZ Alleggerita, many colours avail in tire rack. |
02-22-2022, 03:02 AM | #3 |
I thought stock is 7" wide. It seems like offsets between 43-50mm are okay.
02-22-2022, 01:52 PM | #5 | |
Drives: 2022 GR86
As others have already pointed out, gen.2 stock wheels are 7.5" in width. Won't hurt to consider 17x8 either. It will also be better for 225/45R17 tires when inevitably you change your tires from stock. Also note that stock Primacy HP look narrower than many other tires in the same dimension. 225/45R17 SX2's will look less stretched on 17x8 than stock tires are on stock wheels. |
02-23-2022, 12:31 AM | #6 | |
Drives: GR86
How about these https://www.toyota.com/content/dam/t..._Ebrochure.pdf Slightly wider fitment by 5mm but Toyota are recommending it and only 17lbs , I’ve not seen a part number yet but look the same as the TRD ones sold for the GT86 Last edited by AndyRC; 02-23-2022 at 01:50 AM. |
The Following User Says Thank You to AndyRC For This Useful Post: | alex87f (02-18-2023) |
02-23-2022, 03:17 AM | #7 |
Thanks for the suggestions guys. It's weird that all my searches came up with 7.0" width for the 2nd Gen.
02-23-2022, 05:28 PM | #8 |
Drives: 2003 S2000, 2008 Fit
For the price and the weight, it's pretty hard to beat RPF1s...
02-23-2022, 05:36 PM | #9 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | Dzmitry (02-28-2022) |
02-24-2022, 10:56 AM | #10 |
Drives: '15 GT86 & '22 GR86
You limit your options trying to keep the same offset. One of the lightest wheels available...
17x8 ET42 TWS T66-F 13.93 lb These are labelled specifically for 86/BRZ fitment https://www.tws-forged.com/tws_t66-f.html |
02-24-2022, 11:41 AM | #11 | |
02-24-2022, 03:00 PM | #12 |
Drives: 2022 GR86
May I ask why you need lightest wheels possible?
Are you ok to potentially sacrifice the strength of the wheel just trying to chase down the mythical "lightest wheel = fastest acceleration"? Are you really going to feel the difference of a few % worth the risk of bending the wheel on every pothole? |
02-24-2022, 04:17 PM | #13 | |
Drives: 2022 GR86
02-24-2022, 04:46 PM | #14 | |
Drives: 2022 GR86
Also slightly compromised suspension geometry => slight negative impact on steering feedback. Also arguably better esthetics. |
The Following User Says Thank You to timurrrr For This Useful Post: | steel86gt (03-03-2023) |
Similar Threads | ||||
Lightest wheels for the $$$ - besides the RPF-1's | SubieNate | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 109 | 02-04-2016 04:50 PM |
optimal tire size for stock wheels | brillo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 12-05-2015 12:01 PM |
Wat are the lightest 17x8 track wheels $ can buy | Icanfaptothis86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 07-27-2015 11:06 AM |
What are the lightest wheels for this car? | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 10-15-2014 05:56 PM |
Best performance tire size for stock wheels? | Tenchi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 04-30-2014 06:06 PM |
