GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
01-11-2022, 02:37 PM | #29 | |
The Dictater
Drives: '13 Red Scion FRS
One thing I forgot to mention that might be important was the heat absorption and dissipation properties will be different between the two materials. (I never actually took thermodynamics [because robotics class was cooler] so I don't want to guess as to what the difference is) |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
01-11-2022, 05:51 PM | #30 |
Drives: '13 BRZ TLM Spec
Exactly what I said...
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
The Following User Says Thank You to Opie For This Useful Post: | BRZ Guy (01-21-2024) |
01-11-2022, 05:56 PM | #31 |
Drives: 2022 GR86
You said "will work fine". For most people, "will work fine" implies no compromises or modifications needed.
I'm saying the PP Brembos can only be attached to the BRZ aluminum knuckles by modification (i.e. removal of parts that I presume are otherwise useful; and changing the bolts), and who knows how much it affects the longevity of the overall system. IMO, that can only be called "fine" with a huge asterisk. |
01-12-2022, 08:28 AM | #32 | |
Let me make it clearer... PP Brembo's will bolt up to the 2022 knuckles, and I would not hesitate to use them on the street, or track. If you are concerned with using 2004 STI mounting bolts and removing the tie bar, you can instead purchase one of the seven (7) brake kits now available for the 2022 BRZ from Essex.
01-12-2022, 02:37 PM | #33 |
Drives: 2022 GR86
The Following User Says Thank You to timurrrr For This Useful Post: | PLF69 (01-12-2022) |
01-12-2022, 02:53 PM | #34 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (01-12-2022) |
01-12-2022, 02:54 PM | #35 |
Drives: 2022 GR86
01-12-2022, 03:00 PM | #36 |
Drives: Crapcan
I still have the heat shields but I may pull them. Brakes are ST 4 pots with 328mm rotors.
01-12-2022, 03:08 PM | #37 |
Drives: 2022 GR86
01-12-2022, 03:08 PM | #38 | |
The Dictater
Again, I have no idea what I am talking about. Google knows everything though lol. |
The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (01-12-2022) |
01-12-2022, 03:12 PM | #39 | |
Drives: 2022 GR86
I can imagine that if you park a car with rotors too hot some of that heat will be conducted into the ball joints and also into the damper; neither of which like excess heat. |
01-12-2022, 03:13 PM | #40 | |
Drives: Crapcan
The anodizing on my rotor hats has faded from black to a pinkish purple from the temps. I am not sure I want to run ducting to cool the hub though as it will cause more heat checking with the rotors. I was thinking the AL may help pull heat away.
01-12-2022, 07:02 PM | #41 | |
Drives: 2007 WRX
As well as the mechanical design may be understood, the forces may not. Practical experience says we should have some slight concerns. I don't have time to dig up the NASIOC thread right now, but Karen Kraus failed at least one aluminum control arm on her 2006 WRX autocross car. R-comp tires and lots of cornering may put the car in a usage space not envisioned by the designers. |
The Following User Says Thank You to gpshumway For This Useful Post: | timurrrr (01-12-2022) |
01-12-2022, 07:17 PM | #42 | |
The Dictater
And no, static and dynamic forces and their effects on materials are quite well understood. The difference is whether the maker of the part decided to spend time actually doing the math rather than slapping some parts together and saying it's good. |
Similar Threads | ||||
Drop Knuckles instead of lowering Springs or Coilovers | FRSPacNW | DIY (Do-It-Yourself) Guides | 19 | 10-09-2017 12:42 AM |
PBM modded knuckles | sid94 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 07-12-2017 05:40 PM |
Wisefab knuckles | Ryaquinn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 03-27-2014 12:28 AM |
