Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
07-18-2014, 04:53 AM | #15 |
Regional Moderator
Drives: 13' ZN6 / 00' AP1 / 20' A90/ 15 EVO
My question, which nut do I use to adjust the height of the light output?
07-18-2014, 08:58 AM | #16 |
Why exactly are these not FI friendly?
07-19-2014, 11:41 AM | #17 |
Seems Legit
Drives: Toyota
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
07-23-2014, 05:45 PM | #18 |
Drives: Vroom Vroom
07-23-2014, 08:33 PM | #19 | |
Regional Moderator
My advise do it whole the headlight is off the car. It's a pain while it's on the car Edit- clock wise for up and counter clock wide for down. Last edited by Chen; 07-23-2014 at 09:48 PM. |
The Following User Says Thank You to Chen For This Useful Post: | aznknightz17 (07-24-2014) |
10-16-2014, 01:07 PM | #20 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Sorry to bumb this thread, but I installed these earlier and hadn't seen this mentioned in any of the other threads on them. Do these not have Hi/Lo beams? I'll look to see if I see it in any other threads, but figured I'd start here. Thanks!
10-16-2014, 01:29 PM | #21 | |
Drives: Ultramarine FR-S
It's a bi-xenon projector setup. The projector inside has a shield that blocks off light above a certain threshold so you don't blind other drivers. When you turn on your high beam, this shield moves down to let all the light shine out of the projector. There's much more to it but that's a general description. |
08-17-2016, 09:53 AM | #22 |
Drives: 2013 scion frs
hi I just got these light install on my frs today but I was wondering how do you wire the led drl strip to stay on without turn on the light switch on in the daytime?!
08-17-2016, 05:30 PM | #23 | |
Regional Moderator
DRL like when you put down your e-break and the lights come on? If I remember right, you can't because you take the harness out when you install the new headlights. |
10-14-2016, 08:52 AM | #24 |
Drives: 2013 FR-S Whiteout
10-15-2016, 01:46 PM | #25 | |
Drives: 2013 Firestorm FRS
@Diode Dynamics for someone who actually knows lol |
10-17-2016, 10:28 AM | #26 | |
Those output shots with the keyholes look like OP is running an H11 in an H11B housing or H11B in H11 housing etc etc That keyhole is caused by the position of the leadwire on the HID bulb. Nick C.
The Following User Says Thank You to Diode Dynamics For This Useful Post: | continuecrushing (10-17-2016) |
10-17-2016, 06:56 PM | #27 | |
10-17-2016, 07:12 PM | #28 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
factory is h1
I run D2S in mine they fit fine (there is a adapter to fit the h1) |
Similar Threads | ||||
Springs! Post your Pics!! | stevohl | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 113 | 11-10-2016 02:30 PM |
Cat/Car pics, post yours :) | ZionsWrath | Other Vehicles & General Automotive Discussions | 18 | 08-10-2014 11:26 AM |
Post your winter pics | kidgogeta | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-16-2013 01:52 PM |
Raven Only! Post Pics! | imlevinit | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 07-06-2012 07:41 PM |
