Old 01-04-2025, 08:00 PM   #29
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I was able to grab a set of MX72+ from Blackhawk Japan for $380cad shipped. Everything else comparable is 2x-3x the price with our monopoly money exchange rate.
Old 01-06-2025, 09:12 AM   #30
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
I don't understand the excitement about some pads! Those using MX72+ could get better performance from a Hawk HP+ and at a fraction of the cost. About $125...
RETRACTION!I WAS BITTEN BY THE FAHRENHEIT VS CELSIUS BUG.
Hawk does everything in Fahrenheit. I was thinking it was C without checking.
I know I could not run HP's on the track. They can't do double-duty if you are aggressively using your brakes.
But, they are cheap!
Scargod is offline   Reply With Quote
The Following User Says Thank You to Scargod For This Useful Post:
RT-BRZ (01-06-2025)
Old 01-06-2025, 07:25 PM   #31
Xed32
Drives: '22 brz Sport-Tech
HP+ is just a street pad that can't do track. It appears to be a 300-600 F pad. I would fade those on the street. I am at the upper limit of use for the mX72+ and they are 1382°F pads. I tried Ferodo DS2500 and liked them, but they disintegrated. Also Killed GLoc G6 on track ( yes they are definitely an Autocross pad). HP+ wouldn't even do it on street for me. I have had those previously on another car. The powerstop Z26 pads are as good.
Xed32 is offline   Reply With Quote
Old 01-06-2025, 07:58 PM   #32
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I run the HP+ pads on the track and they work just fine. Admittedly, they are sitting under a set of 6 piston Wilwoods but they are still just fine.
What crazy world are you living in where they don't work on the street?
RT-BRZ is offline   Reply With Quote
The Following User Says Thank You to RT-BRZ For This Useful Post:
Breezio (01-08-2025)
Old 01-06-2025, 08:40 PM   #33
RToyo86
RToyo86's Avatar
Heat range on HP+ is half the MX72. 600f on HP+ and 1200f on mx72+.
I ran HP+ last year, they worked fine for the very light seasons I did, but wasn't a huge fan of them.
HP+ are $300cad per set. Not sure why Blackhawk Japan has MX72+ priced so aggressively compared to US retailers but an extra $80 is a no brainer to me. I was told they're made to order(1.5.month to ship)
https://www.blackhawkjapan.com/produ...S&_ss=e&_v=1.0
Old 01-08-2025, 10:25 AM   #34
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
If you are burning up Hawk HP+ on the street, you are doing something very wrong.
That being said, it's an autocross pad, not a track pad.
They have been excellent autocross pads for me. No fade ever, even at the big event I go to with 90+ second laps and 80mph top speeds. But having a factory PP car helps I'm sure.
Breezio is offline   Reply With Quote
Old 01-13-2025, 11:04 PM   #35
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
What is initial bite like on the HP+ and MX72+?
Im looking for a new street pad that has a hard initial bite like Winmax W3 or Project Mu HC800
Old 01-20-2025, 08:33 PM   #36
Breezio
Breezio's Avatar
I can only speak for the HP+, which does not have a hard initial bite.
Old 01-22-2025, 11:12 PM   #37
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I like the Stoptech 309's for better initial bite. Just be careful - last set I ordered were counterfeit from Amazon.
I like the higher initial bite for the my WRX on the street that has notoriously soft pedal feel on the normal calipers. For my autocross BRZ, I prefer less initial bite and a more progressive feel... plus the Brembos don't need any more feel really. You end up adding too much brake a lot of times.
Check out the Stoptechs if you can still find them. Not sure if they'll be in HP+ territory as those are more of a semi-track, kinda streetable pad IMO.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
finch1750 (01-26-2025)
Old 01-23-2025, 09:58 AM   #38
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
try CSG's pads. We ran them in an 8+7 hour format at COTA (big braking zones) and left with enough pad to do another 15 hours (but it would be cutting it close).
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 01-23-2025, 07:36 PM   #39
Xed32
Cross border from US is way more expensive than from Japan unfortunately.
Actually think i may try Project Mu HC-CS next.
Here are the specs and differences for me from RHD Japan (Note i have a 6 piston front kit):
MX72 Plus:
Material: Ceramic Carbon Metal
Applicable Rotor Temperature (): 50~750
Friction Coefficient (μ): 0.39 ~ 0.47
(F) MX72 Plus AP Racing 6 Pot D51 - RCP116: CA$323.08
(R) MX72 Plus BRZ\86 - EP472MXPL : CA$168.23
PMu HC-CS:
Material: Super Graphite Metallic
Applicable Rotor Temperature (): 50~800
Friction Coefficient (μ): 0.41~0.50
(F) Project Mu Type HC-CS AP Racing 6 Pot D51 - F1093: CA$175.92
(R) Project Mu Type HC-CS - ZC6 ZN6 - R914_HC-CS: CA$147.78
I wanted to try the CSG CP:
0.43 - 0.49 μ 50 - 700 °C
But the price for the stock brz is $360US per axle, which is CA$518 Canadian tire bucks each axle before shipping.
Old 01-24-2025, 09:20 AM   #40
GrandSport
GrandSport's Avatar
What the hell are you guys doing on the street that you need more aggressive pads?
I run have cheap low dust pads in everything from my 850hp suv to… pretty much all ny cars.
The Following 3 Users Say Thank You to GrandSport For This Useful Post:
Breezio (01-28-2025), Desertnate (01-24-2025), Ohio Enthusiast (01-24-2025)
Old 01-24-2025, 09:24 AM   #41
GrandSport
GrandSport's Avatar
MX72 Plus:
PMu HC-CS:
I haven’t tried the other two, but the CSG last a real long time.
They’re in a bbk but I bet they could last something like 25 HPDE days.
Old 03-11-2025, 04:37 PM   #42
Tokay444
I went CC-Rg just now to pair with the Essex Endurance kit front and stock rears.
I'm currently on PMU HC+ on factory front and rear, and if the Endless feel and handle like the PMU, I'll be ecstatic. I've been struggling to find the HC+ in the CP8350 D50 pad shape.
Search this Thread:
Advanced Search
Not Another Brake Pads Thread 2022 Edition SlowCarFast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 03-01-2022 03:19 PM
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 06:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 06:27 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
