02-21-2013, 11:17 AM | #57 |
Ridge Racerrrrrrrrr
I just bought a universal lighting harness from princes auto with a fuse, relay and on off switch built in. that cost me 10 dollars. I know a switch in the car is not the prettiest when it is not designed in an OEM fashion but really, 10 dollars is a lot cheaper than a 100 dollar stalk and a wiring headache.
The Following User Says Thank You to SkAsphalt For This Useful Post: | Sco2355 (02-21-2013) |
02-21-2013, 11:25 AM | #58 | |
Drives: 2023 WRB BRZ (MT)
02-21-2013, 11:29 AM | #59 | |
Btw stalk is only $60, not $100. Since I took the headache out of figuring out which wire to use wiring will take what, like 10-15 minutes? Appreciate the info though, it's good info for someone who wants an alternative to what I did. |
02-21-2013, 11:44 AM | #60 | |
Ridge Racerrrrrrrrr
however it would render my harness useless in its current form. would need to be rewired.
02-21-2013, 01:44 PM | #61 |
First 86 Driver Baby!
Drives: FR-S, Flex
The price differences are for 2 different stalks. The $60 is for the BRZ stalk, which has an auto headlights spot. The $100 is for the Tundra/Corolla stalk, which does not have an auto headlights spot. Since the FR-S does not have auto headlights a lot of guys prefer a stalk without the auto headlight spot.
02-23-2013, 04:48 PM | #62 |
bumpin for news. Get the prius stalk yet?
02-23-2013, 11:46 PM | #63 | |
The Following User Says Thank You to ymboc For This Useful Post: | IgnitionGundam (11-09-2013) |
02-24-2013, 01:40 AM | #64 | |
Drives: FR-S, Flex
http://www.ft86club.com/forums/showt...=27366&page=17 |
02-24-2013, 06:54 AM | #65 |
Drives: Toyota 86
Anyone know where to source the GT86/BRZ stalk with auto and front and rear fog light switch? I have front fogs on mine and I would like to retrofit the rear fog. Looks like my car is already prewired for the rear fog since I have a fuse for the rear fog, contacts on the empty slot for the rear fog relay and a third wire (yellow) on the reverse light connector in the trunk
02-26-2013, 12:24 AM | #66 |
Ridge Racerrrrrrrrr
If I have a full harness with a relay and a switch, could I tap the switches ground wire and run that that to the "white wire" so when I turn on the switch (and complete the circuit) it will activate the dashboard fog light indicator through the white wire into the BCU?
Hope that question made sense.
02-26-2013, 01:47 AM | #67 | |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
The Following User Says Thank You to FRSFirestorm For This Useful Post: | SkAsphalt (02-27-2013) |
02-26-2013, 03:37 PM | #68 | |
02-26-2013, 04:13 PM | #69 |
Drives: waiting on a 2021...
I just received the switch yesterday. It will be next week before I have time to work on it.
02-28-2013, 12:34 AM | #70 |
Drives: '14 Toyota Corolla S
It is a rear fog indicator, according to step 9 of this DIY:
http://www.ft86club.com/forums/showthread.php?t=29954 |
Similar Threads | ||||
Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 10:54 PM |
Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 12:44 PM |
BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 05:09 AM |
new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 03:20 AM |
for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 12:53 AM |
