08-16-2023, 02:24 PM | #505 | |
Just the tip
Drives: 2017 DGM BRZ
Typically you would have a metal flashing that tucks in behind the brick/concrete and extends out to allow positive drainage away from your wall framing. Only then would caulking be suitable against the metal to complete the seal to the door frame. Ideally there is building wrap/paper/membrane that can lap over the metal trim... much easier to do if siding can be removed and reinstalled. Not the case here unfortunately. Without knowing the actual assembly of your wall, it's hard to make a firm suggestion. But that door needs to come out to do it properly in any case. |
The Following User Says Thank You to wolffbite For This Useful Post: | Dadhawk (08-16-2023) |
08-16-2023, 10:23 PM | #506 | ||
ProCrastinationConsultant
i see and understand what you have now. i believe that's officially called an "oopsies" when they poured it oversized. the first/normal way to repair that would be to strip it out and use a vapor barrier(like this), and pressure treated lumber. but pressure treated lumber still rots out over time. it's not helped by the difference in expansion rates from the door, and the concrete around it. the way i would fix it is to strip out the old opening, then add rebar into the existing foundation, then pour new concrete to make an appropriate opening size. still need a gasket like above between the door and concrete, but no longer need flashing. another alternative here would be to build a small roof overhang over the door opening to divert rain away from it-- then if you were to rebuild the opening with pressure treated lumber, it would last a ton longer.
The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (08-17-2023) |
08-16-2023, 10:52 PM | #507 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
08-16-2023, 10:57 PM | #508 |
i dunno, that day of science class about differing expansion rates of different materials is just screaming at me in that picture.
if it was my house, i wouldn't be able to let it go until i re-poured, or mortared the gap...
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | Spuds (08-16-2023), Ultramaroon (08-17-2023) |
08-16-2023, 11:37 PM | #509 | |
The Dictater
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
09-03-2023, 04:34 PM | #510 |
Drives: Crapcan
Helping a friend pull wire from the house to the shop. The string broke while trying to pull the ride through the conduit. Tried to suck a new string through and getting nothing but dirt. So now…
09-03-2023, 05:47 PM | #511 | |
totaled
will you find out where it hung?
09-03-2023, 06:57 PM | #512 |
Drives: Crapcan
Yeah we got it. Coupler came apart he thinks when he used the excavator to pack it. Luckily the mini was next door since my buddy is building his neighbors house. The water and communication was over 2ft down with main power conduit 12”-18” deeper.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Spuds (09-03-2023), Ultramaroon (09-03-2023) |
09-03-2023, 07:18 PM | #513 | |
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 i've got about 2500ft yet...
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | NoHaveMSG (09-04-2023), Ultramaroon (09-03-2023) |
09-04-2023, 02:08 PM | #514 | |
Drives: Crapcan
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (09-04-2023), Ultramaroon (09-04-2023) |
09-04-2023, 03:05 PM | #515 |
The Dictater
We're still talking about wiring right?
The Following 4 Users Say Thank You to Spuds For This Useful Post: |
09-04-2023, 04:08 PM | #516 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Skeet! Skeet! 120 Feet!
"I gotta rock." -- Charley Brown |
09-04-2023, 06:14 PM | #517 |
Chicken bucket
Drives: '15 ultramarine
09-04-2023, 08:38 PM | #518 |
Drives: Crapcan
Yeah, living on the edge of the earth creates some building issues.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
Tags |
diy, home, living |
Similar Threads | ||||
Brought my BRZ home today | Smokinbuffalo | Northwest | 8 | 06-01-2012 12:49 AM |
WRB-Got it home!!! | jaytaurus | BRZ First-Gen (2012+) -- General Topics | 28 | 05-29-2012 12:33 PM |
#64 brought home today. | FujiwaraTofuShop | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 10:04 AM |
Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 04:24 PM |
