Old 05-24-2022, 12:42 PM   #1625
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Left to right.
Stock key fob, full key fob, compact key fob.
Specs are:
Stock: W42xLx69xD16
Full: W33xL63xD10
Compact: W29xL53xD10
Measurements/volume shows full & compact are less than half… but visually, it doesn’t. I’ll just make compact & other one stock.
Have you tried playing around with rounding the edges? There is a radius tool in tinkercad.
NoHaveMSG is online now   Reply With Quote
Old 05-24-2022, 01:37 PM   #1626
No I don't race or speed
What? Behind the rabbit?
It is the rabbit!
Tcoat is online now   Reply With Quote
soundman98 (05-24-2022)
Old 05-24-2022, 01:39 PM   #1627
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I would… except it’s at its limit. Of course, top part is kinda still have an option… but I use that spot to loop the key ring
The Following 2 Users Say Thank You to ichitaka05 For This Useful Post:
bcj (05-25-2022), NoHaveMSG (05-24-2022)
Old 05-24-2022, 01:46 PM   #1628
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Oh yeah, I see. You’d have to increase size to be able to radius those edges. May be worth trying. Kind of the reason I don’t carry my ridge wallet anymore. It’s too square and makes it awkward in my pocket.
Old 05-24-2022, 01:54 PM   #1629
ichitaka05
Site Moderator
ichitaka05's Avatar
Right, make it wider to soften the edge. I might update the compact ver for more softer edge.
Old 05-24-2022, 01:54 PM   #1630
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
You use a shorter dummy cabinet above the range and duct through it into the attic then out a vent. You are supposed to vent gas ranges at 24-30” above the range surface.
I'd imagine this is an easy fix for your cabinet guy though? Usually cabinet boxes are just built in modules, so in theory they can just shrink that module up to make it right. Unless they've already built things... but that's on them at this point.
wolffbite is offline   Reply With Quote
Old 05-24-2022, 02:06 PM   #1631
Sapphireho
America Goose
Sapphireho's Avatar
Drives: Costco boxer briefs
It is the rabbit!
You silly sod! You got us all worked up!
Old 05-24-2022, 02:14 PM   #1632
Well that is no ordinary rabbit
Old 05-24-2022, 02:21 PM   #1633
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, if you want it even smaller...
You could always design a more compact PCB, have someone print it, and transfer all the important bits over to the new one.
Or cut the current PCB in half, add jumper cables between the two halves, then just have buttons on both faces.
Spuds is online now   Reply With Quote
ichitaka05 (05-24-2022), NoHaveMSG (05-24-2022)
Old 05-24-2022, 02:23 PM   #1634
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
He needs to remake it. I called him this morning and told him I’d buy the correct one. I should have caught it when I verified the layout. He gives me a great deal and I can reuse the full 30” in my utility room above the washer and dryer so no harm, no foul.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (05-24-2022), soundman98 (05-24-2022), Tcoat (05-24-2022), wolffbite (05-24-2022)
Old 05-24-2022, 02:27 PM   #1635
ichitaka05
Site Moderator
ichitaka05's Avatar
That's interesting option... thanks for the idea
Spuds (05-24-2022)
Old 05-24-2022, 02:28 PM   #1636
Can you get it small enough it can be an implant?
NoHaveMSG (05-24-2022), soundman98 (05-24-2022)
Old 05-24-2022, 02:29 PM   #1637
ergs per jiffy
You tit! I soiled my armor, I was so scared!
Old 05-24-2022, 02:31 PM   #1638
ergs per jiffy
ASICs are where it's at. Everybody's doing it.
Spuds (05-24-2022)
baby kitty, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, multipass, next one is a prequel, ow my balls, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
