Old 01-23-2022, 02:26 PM   #1
brianbui23
Actively learning
brianbui23's Avatar
Drives: 2013 FRS US MT
Is it worth buying expensive toe arms?
I think the price of toe arms is ridiculous. Some places are selling them for over $500.
Wouldn't buying cheap toe arms (even god speed for example), and adding the eccentric lock out kit make them the same?
This might be a dumb thought but want to see what other people think.
2013 FRS: Tein Flex Z coilovers, Rays Gram Lights 57CR Black Chrome, Gruppes UEL headers, OFT e-85
brianbui23 is offline   Reply With Quote
Old 01-23-2022, 05:06 PM   #2
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Why do you need toe links? I'm lowered about 1.5", -3.2 front -2.7 rear camber and toe is set to zero front, 0-0.1 degrees total rear toe with the factory links.
Old 01-23-2022, 05:39 PM   #3
Code Monkey
Drives: Subaru BRZ
^ Same as above except close to -4 camber in front; still on OEM toe links.
Code Monkey is offline   Reply With Quote
Old 01-23-2022, 07:50 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS
Yeah factory toe adjustment is fine unless you’re stancing.
ineedyourdiddly
Old 01-23-2022, 11:32 PM   #5
brianbui23
Actively learning
brianbui23's Avatar
I read a few threads saying that the rear toe gets misaligned after hitting big bumps or taking aggressive corners. I haven't had the car long enough to see any changes though
Old 01-24-2022, 07:38 AM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I had OEM toe arm slip at autocross last year. Probably due to the tech not torquing it properly after adjustment.
SPC toe arms are cheap and offer more range of adjustment.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
brianbui23 (01-24-2022), Scargod (01-24-2022)
Old 01-24-2022, 08:24 AM   #7
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Yeah, I doubt that's a problem with the factory toe arms themselves. I've had alignments go out on my S2000 due to this, but never with the BRZ (now at 62k street miles and 40+ track days)
But is more range of adjustment needed? Again I'm at -1.5" ride height and -3.2 front/-2.8 rear camber, not a problem to get zero toe.
I trust factory parts a lot more than aftermarket. Factory parts have more/better analysis behind them and way way WAY more testing.
Seems like a waste of time/money/effort to me...
The Following 2 Users Say Thank You to ZDan For This Useful Post:
brianbui23 (01-24-2022), Tcoat (01-24-2022)
Old 01-24-2022, 10:35 AM   #8
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Setup for max track performance with suspension mods?
I'm not into doing something just because it looks cool. Are ALL the adjustable rear toe arms being offered just there for the stance crowd?
My track buddy says he has the rear at -2.0. The front at -3.5. Can you get there with stock adjustability, especially if I'm dropping the car 1~1.5 inches?
I have Voodoo 13 LCA's and coilovers arriving any day for my 2022 BRZ.
I'm not sure if my buddy is using adjustable arms or not, but he seems to have everything else. His setup came off a real race car that crashed.
Scargod is offline   Reply With Quote
Old 01-24-2022, 11:26 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had to run them on my car, I couldn't get the OEM arms short enough and had a hair of toe out for a bit. I am at about -2.6 rear. I am running SPC's.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
brianbui23 (01-24-2022), ZDan (01-24-2022)
Old 01-24-2022, 11:48 AM   #10
ZDan
ZDan's Avatar
Drives: '17 BRZ PP
Looks like some peeps may need them to avoid toe-out, per NoHaveMSG's post above ^^^
Maybe? Again I'm at -1.5" with -3.2 front -2.8 rear camber, no prob with stock arms.
You might not need LCAs, natural lowering will put you in the right camber range for track. While not being a problem for the street either...
Old 01-24-2022, 11:59 AM   #11
Racecomp Engineering
Most people can get the toe you need with the stock arms.
The OEM toe adjuster can slip and IMO are a little bit of a pain to adjust if you're doing your own alignments. It's not common, but it does happen.
An aftermarket arm usually uses a spherical bearing instead of the factory rubber bushing, which means a more direct connection and less "give." It's a small difference, but doing more bushings in the rear adds up to a more noticeable difference.
A "better" aftermarket arm will use a higher quality spherical bearing that lasts longer. On the lower end arms the bearing or the ball joint is more likely to develop play earlier and require replacement.
Some arms will also use a rubber booty to protect the bearing from the elements (salt).
Aftermarket toe arms are defintely not a "required" part, but I like them.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
brianbui23 (01-24-2022), norcalpb (01-24-2022), RToyo86 (02-01-2022)
Old 01-24-2022, 01:19 PM   #12
strat61caster
Drives: '13 FRS
Yes.
-2.5 in the rear, been as low as 1.5 zero issue with factory toe arms, plenty of adjustment left
ineedyourdiddly
Old 01-25-2022, 10:13 AM   #13
Adamf220
Drives: 2013 frs
Get the moog ones off of rockauto. Just simply for the ease of adjustment.
Adamf220 is offline   Reply With Quote
The Following 2 Users Say Thank You to Adamf220 For This Useful Post:
brianbui23 (01-25-2022), treedodger (01-28-2022)
Old 01-25-2022, 11:35 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe these are made by SPC for moog.
Why Buying EXPENSIVE Wings from Evasive Motorsport??? SexAs86 Cosmetic Modification (Interior/Exterior/Lighting) 4 05-06-2019 10:22 PM
Is it worth buying aftrmarket parts for the frs? sledheadguy CANADA 23 03-02-2015 11:24 AM
Worth buying joint pipe now or later? Bakemono858 Engine, Exhaust, Transmission 21 02-21-2015 02:04 PM
Buying Fr-S, this one worth checking out? Fang Scion FR-S / Toyota 86 GT86 General Forum 9 11-07-2014 02:31 PM
Series 10 - Still worth buying new? Double_Clutch Scion FR-S / Toyota 86 GT86 General Forum 16 08-14-2014 03:40 PM
Copyright ©2000 - 2022, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
