12-21-2021, 02:45 PM | #141 | |
Drives: '23 BRZ Limited
On level ground, pinch weld to ground is much easier to get consistent readings vs trying to get a tape measure straight up and down to the fender while being in the middle of the hub. |
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | timurrrr (12-21-2021) |
12-22-2021, 12:06 AM | #142 |
Drives: 2022 BRZ
Wanted to add this to the data.
I have 18x8.5 44et with 245/35/18 These are the wheel tire combo with stock suspension. Seem nice and flush. Will likely tuck in a bit more as the car is lowered, gaining a bit more negative camber. I have installed Ohlin coilovers 2 days ago. Will be adjusting and lowering more from what Ohlins came as. Waiting for them to settle. Will follow up with images when lowered, corner balanced and aligned. PS: This is my first Subaru. I had high expectations, and mostly it has been surpassed. However, installing the new coilovers, I noticed that the stock rear control arm is literally junk. This thing was warping with torque application, what a shame. I will be looking to replace this piece with an aluminum one. Subaru, not Toyota, also has the front lower control arm made of aluminum vs the same thin steel junk in the GR86. One less thing to worry. If you guys get the GR86, look into swapping with the BRZ aluminum piece. Savagegeese mentions this in his YouTube video as well. Last edited by BRZ-G1; 12-22-2021 at 01:20 AM. |
The Following 4 Users Say Thank You to BRZ-G1 For This Useful Post: |
12-22-2021, 02:01 AM | #143 | ||
Drives: 2022 GR86
12-22-2021, 02:17 AM | #144 |
Drives: 2022 BRZ
12-22-2021, 03:55 AM | #145 | |
TRACKBREAD
7.5 ET48 —> 8.5 ET44 = -16.5mm fender clearance. I expected to need roughly 10-15mm spacers to get the stock wheels where I want them, so your setup is pretty much exactly there. |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Pete (12-22-2021) |
12-22-2021, 05:01 AM | #146 | |
Drives: 2022 BRZ
Original wheel is 18x7.5 et48, yes! Last edited by BRZ-G1; 12-22-2021 at 06:09 AM. |
12-22-2021, 05:19 AM | #147 | |
Drives: '15 GT86 & '22 GR86
No he is correct, the original wheel is 18x7.5.
3min20sec into this video; That fitment looks perfect, was waiting for someone to fit a 8.5j with an ET in the 40s based on what's been done so far. Quote:
The Following User Says Thank You to Varelco For This Useful Post: | Yoshoobaroo (12-22-2021) |
12-22-2021, 06:04 AM | #148 | |
Drives: 2022 BRZ
The Following 2 Users Say Thank You to BRZ-G1 For This Useful Post: | dsc_pat (12-22-2021), Yoshoobaroo (12-22-2021) |
12-22-2021, 11:40 AM | #149 | |
My Gen 1, with appropriate camber for the tires (so like -3.5 fr -2.8 rear), with 18x9.5 ET 38 255/35 weren't flush. They still tucked in a touch at the top. But it looked mean. |
12-22-2021, 11:47 AM | #150 | |
TRACKBREAD
Im aware, true flush fitment doesn’t work anyway, especially when lowered. You need ~5-10mm (depending on the wheelarch geometry) of tuck to clear the wheel arch on compression. |
12-22-2021, 08:54 PM | #151 | |
junior mafia
Drives: ‘20 sti limited
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
12-23-2021, 02:43 PM | #152 | |
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Cheers, Colin |
12-23-2021, 03:21 PM | #153 |
Grey Man
Drives: 22 MT BRZ
P245/45WR17 on on 7.5" x 17" stock "Premium"????
My question is: Will PRIMACY MXM4 - SIZE: 245/45R17 the wonderfull drifting tire or most other 245 wide tires fit the stock 7.5 x 17 wheels?
I like the Primacy's. I intend to drive them until they are slicks. I have no prob losing traction with them unless I want them to. So, can I squeeze 245s onto the 7.5 wide 17" wheel? If not, how about 235s? I want to use the stock 7.5x17 wheel. |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
