Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-15-2021, 01:58 AM | #1 |
vroooooooom
Drives: 86
2013 VS 2017 Engine reliability
Given each one has the same FI kit and supporting mods, will the 2017 motor face less issues or are the differences negligible?
05-15-2021, 02:23 AM | #2 |
ProCrastinationConsultant
There were a lot of little rigidity improvements in '16 for that extra 5hp.
My gut says 16+ is better for Fi, but I don't believe there's any data to back it up
The Following User Says Thank You to soundman98 For This Useful Post: | Lucky21 (05-17-2021) |
05-15-2021, 02:33 AM | #3 |
Drives: brz 2017 hksv2
saw a rod snappin with boost and no knocks in 2017 engine, an european though but anyway the improvements doesnt make it unbreakable, weak points are still there
The Following User Says Thank You to tomm.brz For This Useful Post: | Lucky21 (05-17-2021) |
05-15-2021, 06:33 AM | #4 |
Drives: 2013 FR-S Argento
I doubt anything on a 2017 motor will save you if something goes wrong on an FI setup, you have cooling/oiling issues, or you load the rods too much. Motors will likely behave the same way.
Sent from my SM-G998U using Tapatalk |
The Following User Says Thank You to bfrank1972 For This Useful Post: | Lucky21 (05-17-2021) |
05-15-2021, 07:56 AM | #5 |
Rust bucket enthusiast
2013 engines are 8 years old at this point. By nature, a 2017+ should have less issues. Improvements in the valvetrain and coilpacks alone make it worth avoiding a 13
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Lucky21 (05-17-2021) |
Similar Threads | ||||
2017 fa20 engine into 2013 car? | ROADRACER | Engine, Exhaust, Transmission | 91 | 12-28-2021 11:52 PM |
2017+ Reliability Improvements? | MarkR171 | Engine, Exhaust, Transmission | 3 | 04-16-2018 10:40 AM |
2017 engine vs 2013 engine | DailyDriver86 | Engine, Exhaust, Transmission | 17 | 11-09-2016 05:16 PM |
Reliability of engine with short block replaced | ShadowTS | Issues | Warranty | Recalls / TSB | 4 | 08-22-2014 11:49 PM |
Subaru Engine reliability? | FRSCoupe | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 06-07-2012 04:11 AM |
