Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
09-24-2014, 04:09 PM | #57 | |
Drives: FRS
09-24-2014, 07:31 PM | #58 | |
Drives: '15 - WRB Brz Limited
The Following User Says Thank You to Stewie For This Useful Post: | Racecomp Engineering (09-24-2014) |
11-06-2014, 07:16 PM | #59 |
Drives: '13 Firestorm FRS
Honestly, from my research it seems to be about what your priorities are. If you want a coilover that is both comfortable on the street and decent on the track, you'll want KW V3's or Eibach Multi-Pro R2's, which are in the 2-3k range. However they make sacrifices for the street and are a bit soft on the track. They can't be re-valved from the factory for more aggressive spring options.
If you want pure track performance with no regard to street comfort, it seems Fortune Auto 510's with Swift springs will do you good, as they are the only coils I have found for <$4000 that can be custom re-valved to match your spring rate. |
11-06-2014, 07:56 PM | #60 |
Drives: 2014 Pearl White BRZ
I am pretty happy with my FEAL 441s at $1350 - swift springs - us based - Odi is a decent guy.
[ame="http://www.youtube.com/watch?v=0GsGq8TvW6E"]Odi Bakchis and Feal Suspension take on Formula D 2013 - YouTube[/ame] |
11-07-2014, 06:53 PM | #61 |
Drives: 2014 Scion FRS, Argento, 6MT
OP,
Not sure if you are still engaged with this thread any longer, but one question I don't see asked or answered is who is going to do the install? You? Tire shop? Some bro-canic of yours? What cha' got there? You will need to make sure that is in your budget. Personally, I just put on a set of B6s and RCE Yellow springs(rather, paid someone to install) and I could not be more happy with this setup. I have read other posts claiming "better daily driving than stock." Didn't believe it... Well guess what? It's better than stock. I was not directly after a lowered look, it just kinda comes with the deal, looks great. So far on any more spirited runs I feel like I have way better connection to the car and better control. This setup will run you in the neighborhood of $1100-$1200, plus install - local mileage will vary, count on $250-$400 unless you are a DIY sort. E- |
The Following 2 Users Say Thank You to NoobTron For This Useful Post: | Jar (11-08-2014), Racecomp Engineering (11-08-2014) |
11-08-2014, 12:29 PM | #62 | |
Drives: 2014 SWP BRZ Limited
I could be remembering wrong, but RCE used to sell a GTWorx/Blistein struts bundle with their yellow springs for the WRX/STi. I've not seen a similar offering for the 86 on their site. |
11-09-2014, 09:38 AM | #63 |
2nd 86 member
Drives: 2013 Asphalt AT FR-S
My FRS is my daily driver and canyon runner. This is what i did.
TRD Lowering springs TRD Anti-sway bars Bilstein B-6 Shocks (OEM replacements recommended for the TRD lowering springs) Whiteline bushings KCA416 Camber adjusting bolts KSR210 Steering- rack & pinion, KDT926 Gearbox- positive shift kit KDT925 Differential- mount in cradle & support outrigger insert bushings KDT922 Rear Crossmember- mount insert bushings Cusco Power Braces Front Tower Bar (Type ALC OS) Front Lower Control Arms Front Crossmember bar (Type ll) Rear Crossmember bar I did this earlier this year and the car has improved in handling, steering and acceleration. If this goes over $1500 (I forgot what I paid), save more money and do this package. You won't regret it. It is well worth it. |
11-09-2014, 09:42 PM | #64 | |
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Jar (11-09-2014) |
11-09-2014, 10:36 PM | #65 |
Excuse my dumbness about struts, but does "re-valving" mean that the strut is adjusted for the amount of travel that the spring permits?
11-09-2014, 10:51 PM | #66 | |
Drives: 2013 MT Asphalt FRS
11-09-2014, 11:12 PM | #67 | |
And adjustable shock with a knob will let you change these values too, but you usually don't have the same precision with the adjustments that way. Most of the time you have 1 knob and either change just rebound, or both rebound and compression together. Both are compromises. Really good shocks will add more knobs and give you more control. But cost some money. Bilsteins are great shocks internally in terms of how they're built, but most of their stuff do not have any knobs to turn. So if you want to make adjustments, a revalve is in order. BUT off the shelf though they'll still do really well with most of the springs out there. A revalve would just make them more better. There's not much you can do to make up for a drop on standard fixed perch struts other than trim the bumpstops or use shorter ones. You're still limited because you need SOME bumpstop. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Jar (11-10-2014) |
Similar Threads | ||||
Eibach Multi PRO R2 Coilovers: $1500 | FRSdrive | Brakes, Suspension, Chassis | 11 | 02-24-2014 07:00 PM |
FS: Eibach Multi Pro R2 Suspension $1500.00 | FRSdrive | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-24-2013 05:42 PM |
$1500 budget coilover - what would you choose? | smbstyle | Tracking / Autocross / HPDE / Drifting | 27 | 11-17-2013 09:35 PM |
