Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-20-2018, 01:56 PM | #1 |
When to replace brake fluid
After quite a bit of research, I cannot find when the actual time to change brake fluid. Everyone just says, "after 2 track days" or "every six months" or something like that. Is there a test or an analysis you can do to determine that it needs to be changed?
Thanks in advance |
02-20-2018, 02:04 PM | #2 |
Drives: Subaru BRZ
Whenever the brake pedal gets squishy.
02-20-2018, 02:07 PM | #3 |
Drives: '13 FRS - STX
"brake fluid test strips"
A bleed and topping off of fluid every 1-2x track days is cheap insurance, the strips to confirm that at least what's in the reservoir hasn't broken down. |
The Following 3 Users Say Thank You to strat61caster For This Useful Post: |
02-20-2018, 02:08 PM | #4 |
Drives: 2014 Scion FRS (Asphalt)
You can use a brake fluid moisture test kit. They come in strips or you can buy an electronic tester. It's sometimes hard to gauge how squishy your pedal can become over time... unless it's like right after a track day.
If you're not driving it too hard around every 30k is about right.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
The Following User Says Thank You to tyler_win_photo For This Useful Post: | Spuds (02-20-2018) |
02-20-2018, 02:08 PM | #5 |
Take a look at it. It should be almost clear. If milky, rusty coloured, or blackish then it needs to be changed. It should smell sort of sweetish (hard to describe an odour) and if there is any hint of a burnt smell it should be changed and flushed.
Everybody drives differently so there is no hard and fast time limits or operating condition that says "change it now". Rules of thumb is the harder you drive the car the more often you need to check it.
02-20-2018, 02:16 PM | #6 |
Drives: 2014 GT86
If braking heatload has never been to squishy/fading brakes and to boiled fluid, imho it may last long enough, at least i'd change never boiled fluid at most once per year. But then again if track is mentioned .. it's easy to abuse brakes above their capacity . BTW, if you boil them often enough, maybe worth considering instead of frequent flushes change fluid to one with higher boiling temps / enhance cooling (eg. airducts) / reduce braking heat load (eg. shorter sessions / pedal dance instead of with nannies / braking lessons by hpde instructors ) .. or move to BBK.
The Following 2 Users Say Thank You to churchx For This Useful Post: | strat61caster (02-20-2018), Tcoat (02-20-2018) |
02-20-2018, 02:31 PM | #7 | |
Or use Project Mu. Green turns clear if it absorbs too much moisture (aging), or turns brown if it gets too hot (tracking). PM to order. Don't forget to bleed your clutch pedal every 2 years too. |
02-20-2018, 03:45 PM | #8 |
Huge E85 fan!
Drives: 2016 Scion FRS
I switched to Motul at 30k, made a huge difference. It was easy to do and not all that expensive.
02-20-2018, 04:57 PM | #9 |
I track it about once every other month. I have heard about the moisture test strips but is there any other way to test it for being broken down? I'm not really even sure if brake fluid breaks down from heat cycling. I have three track sessions on my current brake fluid and bled them about 6 months ago. I have not noticed any decrease in pedal feel. I'm using Motul RBF600.
02-20-2018, 05:25 PM | #10 | |
The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
02-20-2018, 05:31 PM | #11 |
02-20-2018, 06:08 PM | #12 | |
Band-aid fixes include higher grade brake fluid. |
The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (02-21-2018) |
02-20-2018, 06:47 PM | #13 |
So either that or flushing brake fluid more often. I don't think a BBK is necessary for this lightweight car. I have no problem flushing brake fluid, I'm just trying to figure out how to determine that the fluid has degraded from heat.
02-20-2018, 06:59 PM | #14 | |
Why does Subaru now provide a factory Brembo setup if it's unnecessary? |
Similar Threads | ||||
Brake fluid change | guybo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 02-08-2018 12:05 PM |
How difficult is it to replace brake hard lines? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 05-27-2017 11:39 PM |
When should you replace your iron brake discs? | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 07-14-2016 12:26 PM |
brake rotor need replace? | ZHoward | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-23-2016 03:11 PM |
Brake Fluid Question... | Lebby83 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-02-2015 09:01 AM |
