Old 12-28-2018, 04:03 AM   #1373
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by sly View Post
Your engine is cold when you took this log. So you are in open loop. Try taking a log with a warm engine and let it idle a bit.
Fuel System Status = 2 in that log. That's closed loop
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-28-2018, 11:42 AM   #1374
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Ahh! So that's what that means.
sly is offline   Reply With Quote
Old 01-03-2019, 05:14 PM   #1375
Cosworth_0686
Drives: Cosworth ('17 BRZ, '76 Vega)
Everything seems to be together 100%, however it turns out that the hood and the cold air intake clamp rub. This picture is after only about 10 or so miles of driving around. I saw that some were mentioning carefully hammering their hood in to provide the needed clearance. Does anyone have pictures of this or other things they did to resolve this?
Might the short leg of the 90deg elbow be a touch too long, therefore pushing the cold air pipe up too much? It is bolted through the top mounting point, though it seems to be more stressed upward than it should be. Are these silicone elbows able to be trimmed a tiny bit without 'fraying' or something weird like that?
Cosworth_0686 is offline   Reply With Quote
Old 01-03-2019, 05:22 PM   #1376
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
This does happen on some cars, even though there's about 10mm of clearance , the hood moves around such a lot at speed it flexes enough to touch
if you want to add clearance then get the metal hot with a hot air gun ( not enough to blister the paint) and use a sand or lead shot bag to spread the load of a swift tap with a ball-peen hammer
Matt@Cosworth is offline   Reply With Quote
Old 01-27-2019, 04:52 AM   #1377
Seba
Drives: BRZ Cosworth SC MY16
Hello,
does this kit
https://www.fensport.co.uk/parts/toy...terface-kit-2/
should be enough to do data logging, and flash again my ecu if necessary?
Seb
Seba is offline   Reply With Quote
Old 01-28-2019, 07:12 AM   #1378
vagthomas
Drives: Toyota GT86
Good day to all.
Would a cosworth kit with 35000 km be trustworthy as second hand? Is there something I should look for prior proceeding with any action? And finally is the price of 3200 euros considered normal?
Thanks for any feedback in advance guys!
vagthomas is offline   Reply With Quote
Old 01-28-2019, 10:35 AM   #1379
gtengr
Drives: 2017 BRZ
Originally Posted by vagthomas View Post
Good day to all.
I bought mine second hand just because one popped up for sale local to me at the same time I was about to purchase. I've had a few teething issues with it but it's all been install related and no fault of the Cosworth parts.
gtengr is offline   Reply With Quote
Old 01-28-2019, 11:16 AM   #1380
gahooligan
Drives: 2017 BRZ Premium
Good day to all.
I would buy one used at a good discount before buying new. Be advised, you WILL need a new set of the Cosworth intake gaskets, no exceptions.
Sent from my SM-N960U using Tapatalk
gahooligan is offline   Reply With Quote
Old 01-28-2019, 12:03 PM   #1381
sly
sly's Avatar
I would pressure test the manifold and the heat exchangers just to be sure there are no cracks. You don't want antifreeze running into your engine due to a leak. These kits are designed to last the life of the car. So I would not worry about it being used. Just want to make sure it hasn't been damaged...
Old 01-28-2019, 04:28 PM   #1382
Matt@Cosworth
I feel I should say you can get a brand new kit from us for £3700...
Old 01-28-2019, 04:55 PM   #1383
vagthomas
Drives: Toyota GT86
Hello Matt.
This price if for stage 2 only? (I am not interested in stage 1 - I am already there not from cosworth)
And does this price include taxes?
Στάλθηκε από το CLT-L29 μου χρησιμοποιώντας Tapatalk
Old 01-29-2019, 04:14 PM   #1384
Matt@Cosworth
Hello
its £3700 + VAT ( so 20%) while we're all in europe
however if you wait a few more weeks we may be out of europe so no VAT to pay just whatever your customs decides is appropriate
shipping would also be on top
and this is a stage 2 kit but we also include the air filter and low temp thermostat ( stage 1) these days
the only thing you don't get is a licence or ECU tek kit but the tune is included
Old 01-30-2019, 06:12 PM   #1385
R2
The benefits of a colder thermostat on knock resistance are very apparent, but I'm curious what other effects there are. Is it possible to quantify any increase in wear and fuel consumption?
R2 is offline   Reply With Quote
Old 01-31-2019, 01:30 AM   #1386
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A bit lower oil temps. If I remember correct in the range of 5 C. I am not aware of any changes in wear or fuel consumption.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
