Old 05-09-2014, 03:29 PM   #1373
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
I just felt my rear tire lift on a tight corner cause of the new swaybar.... :/
Kostamojen is offline   Reply With Quote
Old 05-09-2014, 04:06 PM   #1374
gramicci101
Off Topic
Time for an air locker. ARB makes some nice ones.
Old 05-09-2014, 04:24 PM   #1375
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So in the dry my brz is very planted in turns, but now in the wet the car behaves more like a 1970's muscle car when it comes to cornering. The obvious answer is the rubber, I'll probably switch to 225/45r17 MPSS on the stock wheels once the stock rubber is worn out. The car sees double duty as DD and AutoX STX class. My suspension work is only Bilstein B8 shocks/struts and RCE Tarmac springs
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-09-2014, 04:43 PM   #1376
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Alignment? I've found that a little bit of camber goes a long way on this car. Also, from the alignment specs I've seen on other and my own car is that it can vary quite a bit from left side to right side. There's about 0.5 degrees difference between my left and right rear wheels from the factory.
Old 05-09-2014, 04:55 PM   #1377
Turkish
Serial Cone Killer
Turkish's Avatar
I'm on my phone and can't easily post my alignment, but it is towards the end of my build thread linked in my signature. One rear wheel is -1.8, the other is -2.0.
... his name is...
C'THULHU
Old 05-12-2014, 01:42 PM   #1378
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by Racecomp Engineering View Post
Not a bad link!
What it comes down to for me....I want good valving. A good twintube is better than a bad monotube. They each have their inherent advantages and disadvantages and for a hardcore motorsports shock I want a monotube. But at the end of the day, I just want the best shock within my budget.
- Andy
I agree completely. My post was an overgeneralization assuming at a minimum equal levels of quality and valving expertise put into each. I prefer the tradeoffs of a monotube to twin.
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Racecomp Engineering (05-12-2014)
Old 05-12-2014, 01:55 PM   #1379
SubieNate
SubieNate's Avatar
That link had a loooot of marketing. The decision between twin and monotube should not be made based on travel. If a damper is designed correctly for the application, the damper should have adequate travel. Period. Subaru puts inverted Mono's into the sti, bilstein's offerings are all inverted monotubes ( for our car at least). You can't tell me bilstein put in less engineering than tein.
Just a car in point. Rally cars almost exclusively run long travel inverted monotubes. They have prodigious amounts of travel. Specialized application? Yes. But obviously long travel can be done.
To me the advantages in strength, damping precision, resistance to foaming and cavitation, ease of rebuildability, and ease of revalving are all hugely in monotube's favor.
Old 05-14-2014, 07:23 AM   #1380
steveoexige
Drives: UK GT86 in White with alcantara
Not a bad link!
- Andy
Talking of monotubes....any opinion on the HKS SP's ? another vendor promised a review of these a few months back? Only ask as these have been highly recommended to me but I'd like to hear your thoughts 1st.
steveoexige is offline   Reply With Quote
Old 05-14-2014, 12:45 PM   #1381
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Thoughts on running no rear sway bar? I was hunting down a clunk, which turns out it was my rear endlinks. I have Hotchkis 25.4mm front bar (hollow, highest setting @ 630 lbs/in), RCE Tarmac springs, and Konis. It's been quite fun to drive around but haven't really pushed it yet.
Books is offline   Reply With Quote
Old 05-14-2014, 02:42 PM   #1382
wparsons
wparsons's Avatar
Without a rear bar it's going to want to push like crazy.
flickr
Old 05-14-2014, 04:10 PM   #1383
Kostamojen
Haven't some Auto-x folks run no rear bar?
Old 05-14-2014, 04:21 PM   #1384
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
No. Just a thicker front bar.
raul is offline   Reply With Quote
Old 05-14-2014, 04:50 PM   #1385
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yup. @Ninjin runs without a rear sway bar.
^GT5 Replay Photo Mode^
Old 05-14-2014, 10:13 PM   #1386
wparsons
wparsons's Avatar
With what spring rates though?
flickr
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
