Old 12-23-2014, 10:04 PM   #1373
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by protpibe View Post
The likelihood of a valve cover gasket leaking is extremely low.
Are you sure that's not oil that ran down the side of the engine? Is that on the passenger side? My guess would be oil scavenging pump cam plate leak, or oil feed line underneath the injector ECU cover.
Edit: i'm guessing thats the overpipe in which case I would suggest looking into the two possibilities I posted above. I'm guessing if you pull the FI ECU cover you'll notice some oil pooling beside the feed line.
Well, it's leaking from there to. I had already re sealed that cam plate once before. I'm also absolutely positive its leaking from the valve cover as well because I've been observing it every morning. I'm going to re seal both with Honda bond. This sucks, but at the same time I'm kind of looking forward to it since I'm really interested in learning how to do something like this. "Kind of" interested.
Astroboy is offline   Reply With Quote
Old 12-23-2014, 10:07 PM   #1374
Astroboy
Astroboy's Avatar
Drives: None
You can't see it in the pic; but when u look at it in person, you can see it seeping from the valve cover
Old 12-23-2014, 10:12 PM   #1375
protpibe
protpibe's Avatar
Yeah fair enough, I just know I had be exact same issue and it looked exactly the same under the car. After redoing the cam plate 3 times, I eventually traced it back to the oil feed line. Oil would collect on top of the head and then "spill over" and drip down the side. Apparently it's a somewhat common issue and the fix is running 2 crush washers
Old 12-27-2014, 02:50 PM   #1376
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Originally Posted by Simisimi View Post
My Tuner has done thousands of tunes, mostly on Subarus of all types, and tells me that the FA20 with dual fuel systems and FI is one of the most challenging tunes he has encountered. In the end we seem to have a very lively and stable car at 9PSI but he believes this is very near the edge of compromising long term reliability. My AVO went in at 2000 miles and I've got 4000 more since then. So far, aside from an issue caused by the common failure of the OEM high pressure fuel pump, it's been solid. When you consider the engine output is nearly double factory spec it's remarkable. Time will tell!
A 9psi ceiling seems pretty low but not surprising. Your numbers are very solid for that boost level though, is this on 93?
I can't imagine the headache tuning these cars must be.
Originally Posted by robr View Post
Here's one of humpre's graphs. From memory, he has an AVO kit with upgraded wastegate (still wasn't holding too well up top), 3" exhaust, whatever the normal AVO downpipe size is, Perrin intake. He can chime in if I have any of that incorrect. Tuned by ATS Racing.
Thanks for posting, I checked out ATS and it looks like they specialize in MR2's, are boxers something they deal with a lot?
Whatabouteggs is offline   Reply With Quote
Old 12-27-2014, 03:35 PM   #1377
Astroboy
Astroboy's Avatar
Drives: None
Yes, they managed to raise my power by around 250hp and 200tq on 5psi.. the owner even created his own turbo application for his car.
Old 12-27-2014, 05:22 PM   #1378
Whatabouteggs
[Citation Needed]
That's kind of amazing. This the ATS tune?
Old 12-27-2014, 06:09 PM   #1379
Astroboy
Astroboy's Avatar
Drives: None
Yup, I try to post up pictures but the Damn phone usually never lets me... I'll get one up here soon hopefully
Old 12-28-2014, 04:28 PM   #1380
robr
Drives: 2013 FRS, with boost by ATS Racing
Yes, we ARE an MR2 shop. We do random fun projects for people (Supras, Celica Alltracs, Lancia Stratos replicas, etc), usually long time good customers that have become friends. We have been doing a lot more FA tunes and work, but we don't make products for them, nor are there any immediate plans to. We will gladly replicate my turbo setup and/or install whatever parts/kit you have, but in the same way that any other shop would be willing to do a one-off project for a customer.
Tuning, yes, we will gladly give you a safe boosted tune. Until we find the limits nearly as well as we know the 3S limits, we won't push for the last bit of power, especially on pump gas. We know there are plenty of tuners putting out 300rwhp pump tunes, but we personally don't feel comfortable with that, so you'll see just about all of our pump tunes are capped at about 280rwhp.
Our website is useless. Long story short, we can only change the pages with products. Like if you look at "our cars" you'll see Aaron's green car only has like 500rwhp. It's been 820rwhp for years now. And Scott's 760rwhp orange car isn't on there I don't think...so you'll never see a mention of FRS/BRZ things on the site.
Aaron (the main owner) saw an FRS when they were brand new and bought one on impulse. He did the full NA exhaust route, but we all made fun of him relentlessly over the weekend, so he came in the next working day and threw the keys at another coworker and I, "go ahead and turbo it." So we did. I now own the car.
robr is offline   Reply With Quote
Old 01-03-2015, 10:59 AM   #1381
Simisimi
Drives: 2013 BRZ Limited w/ AVO Stage 1.5T
Yes on 93. I am going to see if I can get a chart to post.
Simisimi is offline   Reply With Quote
Old 01-03-2015, 12:20 PM   #1382
robr
I have your graphs that I can upload for you if you'd like as well.
Old 01-03-2015, 11:29 PM   #1383
Astroboy
Astroboy's Avatar
Drives: None
You can if you want. It'll be a great way to get ats out there. I was going to upload a build thread with the graphs as soon as I re sealed these oil leaks..
Old 01-04-2015, 01:35 PM   #1384
robr
Here's one of your (Astroboy) graphs. Please correct me if I have any info wrong
- AVO base kit - 5psi
- pump 93
- 2.5" SRT exhaust, no cats
- Tuned by ATS Racing
If you need help uploading them for your build thread, don't be afraid to ask. Good luck with your oil leaks.
Old 01-04-2015, 08:52 PM   #1385
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
- AVO base kit - can't remember the boost level, sorry. Assuming 8psi?
- pump 93
- 3" [Dodge Neon] SRT exhaust, no cats (?)
He notes that it is only at 5 psi
Impressive.
Old 01-04-2015, 10:04 PM   #1386
jflogerzi
jflogerzi's Avatar
Impressive tune for only 5 PSI. It must be aggressive or its the 3 inch exhaust.
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
