Old 12-14-2017, 10:39 AM   #1373
bryanttttttta
Drives:
[ame="https://www.youtube.com/watch?v=Cr39S8OzWn4"]Grange Black Friday Drift Recap 11/24 - YouTube[/ame]
Drifting at Grange Motor Circuit; Apple Valley, CA
The event was hosted by www.SlideFactory.org and is great for all driver levels from straight beginner to advance.
It's a safe track and a great place to learn dynamic car control.
Co-Founder of SlideFactoryInc Grip/Drift Events
www.slidefactory.org
bryanttttttta is offline   Reply With Quote
Old 12-18-2017, 10:38 PM   #1374
eherschend
Just had the PBM knuckle + outer tie rod installed. I realized at full lock my wheel is grinding into the outer tie rod. What offest do I need to prevent this from happening or what offset are you guys running with the knuckles? I'm currently 16x8.5 -6. I'm noticing a trend that anyone with the full kit from PBM has overfenders...
eherschend is offline   Reply With Quote
Old 12-20-2017, 11:16 AM   #1375
timandytimandy
Wanna-be
timandytimandy's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by tato.valverde View Post
Megan tie rods are exactly the same as stock on the point where they connect to the outer tie rods, so they should. You're gonna have some binding without their tie rod offset-spacer tho
The offset spacers may help prevent that. Or depending on how much it runs, a small slip on spacer might give you the clearance you need.
timandytimandy is offline   Reply With Quote
Old 01-02-2018, 06:38 PM   #1376
eherschend
5mm spacer and removing the clip on wheel weights did the job. Thanks!
Old 01-07-2018, 07:40 PM   #1377
eherschend
Noob here. I'm getting an opportunity to drift on an actual race track and I've only initiated in 2nd gear and have no experience in 3rd or above. How do they differ and any pointers?
Old 01-08-2018, 10:52 AM   #1378
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
More speed, more throttle, more commitment. That's pretty much it honestly. You'll probably want to start a bit higher on rear tire pressure and then lower accordingly depending on how the car feels.
TylerLieberman is offline   Reply With Quote
Old 01-08-2018, 11:09 PM   #1379
DaveyBonesJones
Drives: 2013 Scion FRS
^^^. This. Commitment being the key part’
DaveyBonesJones is offline   Reply With Quote
Old 01-13-2018, 10:10 AM   #1380
cheeseburger
IG: @_southwell_86
cheeseburger's Avatar
Drives: Rwd Prius.
Wishing winter was over.... sigh
cheeseburger is offline   Reply With Quote
Old 01-14-2018, 06:05 PM   #1381
TylerLieberman
Drives: '24 GR86
Nice driving
Old 01-15-2018, 12:13 PM   #1382
cheeseburger
IG: @_southwell_86
Drives: Rwd Prius.
Originally Posted by TylerLieberman View Post
Nice driving
Thanks man
Old 01-18-2018, 07:41 AM   #1383
Kouki86
Drives: 2017 86
What is everyone running for alignment? I've got some BC coilovers, SPC lcas, SPC toe bushings, and Megan racing inner tie rods. Thinking something along the lines of -4 deg camber up front with slight toe out, -1 deg rear with slight toe in.
Kouki86 is offline   Reply With Quote
Old 01-18-2018, 12:53 PM   #1384
TylerLieberman
Drives: '24 GR86
-3 to -4 is typically a good starting range up front. A bit toe out is nice as well.
For the rear, -1 to -2 is ok. If you can get under -1.5 then you should be good as far as tire wear goes. For toe, it depends on your preference. Personally, I found zero toe on the rear to be better. If you want more rear stability, a touch of toe in will help.
Old 01-18-2018, 06:07 PM   #1385
Kouki86
Drives: 2017 86
Great, I'll start with 0 toe and go from there. Thanks!
Old 01-21-2018, 08:47 AM   #1386
JayForts
Drives: 2015 BRZ
Hey guys, haven't posted in a while so I figured I'd share some stuff from last year.
Vide of me and some C group guys,
https://www.facebook.com/clubloose/v...a0&pnref=story
IMG_0286 by photography.B, on Flickr
IMG_0276 by photography.B, on Flickr
AXX_5289+ by Johnathan Cseh, on Flickr
[ame="https://www.youtube.com/watch?v=yhe3qyiMQ6o"]Club loose clinic 3/11/17 - YouTube[/ame]
Still struggling with consistency.
What is everyone running for dampening?
JayForts is offline   Reply With Quote
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
